GMC Yukon, Yukon XL Transmission Problems
ive got a 1998 yukon 4in lift and 2in body lift.today the transmission made a loud pop.wouldnt shift into 2nd gear unless it was to 3000rpm and i let off the gas.when i got home it had no reverse.is the tranny fried or could it be a linkage of some sort.thanks for any info.
See also: Troubleshooting Common Problems in the Yukon 4L80E Transmission
We got our truck back from the last service in June with 49,000 miles.. we now have 63,000 miles and yes... transmission problems again....
"Hard Shifting" Code 748 was the number this time.
If you are thinking of getting a GMC Yukon .... Good Luck... You will need it...
By the way, do you have the 5.3L Engine, or is this a Denali?
My 2004 Yukon XL tranny just went out at 80K miles. Never pulled anything...always treated kindly...and boom...the tranny is gone. Really makes me sick. This was a great truck until yesterday. I thought about calling GMC but I know they won't help. Oh well, I am having a Jasper remanufacture installed and will drive till it drops...which may not be too long~!
While at a meeting with some business friends, I found out another 2007 Yukon owner and a 2007 Suburban owner both had the same problem! The dealer was replacing the Chevy transmission at 15,000 miles after the transmission failed, would not come out of third, and heated up so bad the transmission was toasted. The other Yukon owner had a complete transmission failure while on vacation and the vehicle was not drivable. The dealer replaced the transmission. Coincidence or a fundamental design problem?
UPDATE:
GMC (customer service) paid me 60% of the $3000.00 tranny repair bill even with it being OUT of warranty. Gotta love those guys~!
PS: I prayed that mine was the transfer case too.....
Any ideas out there? Anyone seen this before?
Thanks in advance, walt
Any ideas as to the problem?
Any advice before I bring it to the dealer? Any suggestions on what it could be? Not sure if this is a transmission problem.. It goes forward/ reverse no problems....
Will post follow up on this issue... to be continued. :confuse:
made it 150 miles trans pump broke
trans shop rebuilt (all new parts and torque converter) ?
made it 700 miles
both times was driving about 50-55 mph let off gas for a moment and tried to resume speed
no loud sounds or anywarning just no going
anyone have any ideas?
I apologize for your frustrations. Have you spoke with a dealer? If not, I would definitely recommend doing so. Please keep me updated on your situation. Have a great weekend!
Christina
GM Customer Service
Just started slipping while driving, finally went into a like neutral position in all gears, pulled over, put in park, killed engine, waited a couple of minutes, restarted and drove and shifted perfect, then started failing again within 5 minutes.
This is obviously a VERY common problem...I feel that GM should be held liable to some extent, otherwise the power of the internet will hurt our American made manufacturer.
I apologize for your frustrations. Have you spoke with a dealer or Customer Assistance? I look forward to your response. Have a great weekend!
Christina
GM Customer Service
I think I'll just buy a Nissan......have a 93 Nissan 300ZX with 200k miles with absolutely no problems at all with it......ever!!!
I apologize for the problems you are experiencing with your vehicle. Could you please email me your VIN and current mileage? I would like to look further into your situation.
You can get my email by clicking on gmcustsvc.
Thank you,
Caron, GM Customer Service
I am experianing the same issue as others. I have looked in the forum but have seen not posed awnsers. Please help.
Yesterday I was comming back from the lake pulling a small boat with the family. we stopped to drop one member off and when I went to turn agound it was like I was in neutral. I cycled thru the gears. and nothinging. I turned off the truck for 5 min came back to move it off the road and wallah it word again. I was 20 miles from home so I decied this was a one off.
I proceed home and right after I got off the freeway it started slipping again. and doing something else I have read in other forums. chuging batch and forth like when you put a manual into to low of a gear. all in all I had to turn off wait 5 min turn back on 3 times just to get home.
I never saw any trans too hot message in the message center and yes I was looking for that As I read the entire manual when I got the truck.
I bought this truck used. it had it's transmission replaced already at 68,000 miles. ( so I figured I was in the clear ) it now has 129,000 miles on it.
I have only put 500 miles on it pulling a small boat to the lake it is a 3 vehicle for family outings
GM customer service please contact me if you see this.
and or if someone has had this issue please do let me know what this fix was.
I cannot afford a new transmission let alone the $1200 tear down inspection fee. I am keeping my fingers crossed that this is a simple fix of GM might help out.
john
I want to provide more info if someone is reading this. I was able to do a little troubleshooting the next day.
First I checked the transfluid cold and hot. cold it read like it was overfilled. I drove it around the block a few times. it drove just fine. all the gears shifted just fine. brought it back and checked it hot. it was a wee bit over full on the hole in the dip stick. so I set to drive it again to see if I could reproduce the issue.
well I got about 2 blocks and the issue stared happening again.
like it popped out of gear no, nothing in any gear. so i pulled over and did the usual turn off the key and start up and drove for about 30 seconds and it happened again. so I did the turn off. this time I started the car but did not drive off. I waited and about 30-45 seconds after ( did not have a watch to time) I heard a little clink , lite the sound of a solenoid disengauging something. I put in drive and nothing. I replaced the issue 3 times.
I turn on the car and I hear some soft of mechanical sound and then when I put in drive reverse or any gear manually nothing works.
I then turned off the ignition again turned on and stared off and drove just fine for about 30 seconds. so to me the transmission doesn't seem to be the culprit. possibly a PCM issue or maybe the tranny is hosed and this is a fail safe precaution.
if anyone could chime in I would greatly appreciated it.
john
