Kia Sedona Transmission Problems
About 3 weeks ago, while driving out of a parking lot, going maybe 15 MPH, car pulled back suddenly and ck engine light came on. Car was not shifting properly. Drove home (4mi) and left alone until next am. Car drove fine, engine light still on. Drove to my mechanic who pulled a trans code (0200?? Something to do with the Output -or was it input??). He did not clear the code since still under warranty. Made appt next day w/Kia dealer. Next day, ck engine light off. Dealer ck'd and found no problems. Drove fine until last night.
Same problem (and happened at practically same location - will explain later). Drove home, ate dinner. Needed to run errand, so drove it around block (after about an hour of rest) and car drove fine. Ck engine light still on. Drove this morning. Uneventful. Ck engine light finally went off at around 5pm, almost 24 hrs since problem.
I have no clue what the problem is, but I am sure there is one. The 2 times this has happened to me have been after about an hour long drive home from work where I p/u daughter at school and bring to soccer practice. Car sits for about an hour. Both events happened right after soccer practice. The 1st time I was only pulling out, maybe going about 15 mph. Last night, I was cruising down the road for a minute or so, doing about 40-45 mph when car pulled back. The problem with the gears seems like I have no 1st gear (maybe 2nd).
Can anyone shed some light on this?? How can the dearler find NOTHING?? Not even the code, which, as I said, was NOT cleared. Shouldn't they have seen that?
Sorry so long.
Thanks for reading.
Sorry so long.
Thanks for reading.
The same thing happened to my wife's Sedona just a couple of weeks ago. She was on a trip about 100 miles from home and a big "clunk" which sounded like it came from under the car occured. Then the car acted like it was stuck in 3rd gear. She limped in to a transmission shop and turned off the engine. When the mechanic got in to test drive it didn't do the same thing. They kept the car and worked on it, changing an oxygen sensor and tuning things up. They couldn't check the transmission by the computer, because the shop she was at didn't have Kia'a access code. After that it was fine until 1 week later when she was driving on another trip. About 60 miles from home the same thing happened. She had a meeting to attend and when she went to drive home it was fine.
It is comforting to know that at least one other KIA is acting this way, but would be more comforting to know what the problem is???
ULLMac
The model is F51 i think.
Mine is in a 2002 Sedona LX and I have 98K
on it with no problems.
many of these computerized transmissions have a
INPUT sensor ( which is a speed sensor from the wheels or axles)
and an OUTPUT sensor which is a device that drives your dashboard speedometer.
Looking at the DODGE INTERPID Forums ( which I also have ) they talk about losing one or the other sensor and so the computer doesnot know what to do so it limits your forward gears to 1 and 2 or 1-2-3 so you don't overspeed until the car can be fixed.
The sensors run less than $ 50 each.
I imagine you may be into this issue.
A REAL transmission shop may be of service if you are out of warranty. They do still exist.
I have been very happy with my Sedona.
Has anyone out there ever had this problem? Right now I am not really impressed with Kia and I don't know if I would ever buy another one or not.
:mad:
In the Sedona, I've noticed as I take my foot off the gas and try to coast, I can feel the engine slowing the vehicle more rapidly than I thought was normal. Even on slight downhills, the engine starts to slow the Sedona, rather than let it coast and pick up speed on the hill.
Not sure if this is normal or whether I should be heading back to the dealership ASAP.
Otherwise, have loved the van.
Anyone else notice this, or is this unusual? Thanks!
I've just bought an 04 Sedonna and haven't driven enough to notice anything yet.
Thought I'd let you know, you're not the only one who noticed this.
Jeremy
I am new to this forum and thanks for any input. My wife has an 02 kia sedona w/ 95K. When it is driven for a while and she stops, the engine will rev to 3k for no reason. This happen during the summer and i changed out the throttle position sensor, had the fuel injectors cleaned, serviced the transmission and the problem went away, yesterday it was doing it again. The van is placed in park and the rpm is about 3500. Turn off the ignition and restarted with no problems. I was wondering whether anybody has had this issue before and if yes, is there some sort of TSB from Kia since my powertrain warranty is fast approaching. Thanks :confuse:
From a cold start sometimes the forward gears will not
engage. It seems as if the linkage from the shifter lever is locked out from the transmission. When is dose engage everything runs fine and the transmission shifts as normal. I never know when it is going to happen. One
day it will connect and run fine, the next it will not.
No bangs, clangs or slippage just no connection. Reverse always works. I am scared to death of taking it to a transmishion shop when it could be a simple fix. HELP !
I have located them, (on the transmission) but I am unsure how to disconnect/separate the electrical connectors that lead to them. I don't want to break them by doing it the wrong way!
Does anyone know how to separate them on this vehicle?
I have an automatic with 140,000 miles on it. This morning it was almost impossible to shift into any gear. It is so stiff it takes two hands to make the shift. Feels like I'm trying to shift through peanut butter. There was no indication of this problem prior to this morning.
Any idea what this is all about?
George Teachman
Well at least they sprayed WD-40 type stuff all around the shift lever on top of the transmission and several weeks later the stiffness is mostly gone. I'm not complaining about the dealer, just telling a story.
Now the battery light came on and the alternator is not charging. More fun.
The dealer said the problem was a cracked fuel vacuum tube or something like that.
However, after it has been fixed, the van feels like 1) there is a lot of engine or transmission drag (my main motivation for being on this site), 2) seems to get poor gas mileage (need to verify with measurements) and 3) sometimes seems to slip or be sluggish when putting the foot on the gas at low speeds.
I'm just starting my research on this, but wanted to get this down "on the record" for what it might be worth to others.
The speed sensor detects the revolution of the idler gear parking pawl lock gear and emits a pulse signal. The pulse signal is sent to the TCM which converts it into vehicle speed.
Symptoms
Possible symptoms of OBD code P0720
- Engine Light ON (or Service Engine Soon Warning Light) - Speedometer improper reading - Possible shifting problems
Causes
Possible causes of OBD code P0720
- Speed sensor harness or connectors - Sensor circuit is open or shorted - Speed sensor The Error code is generally activated on detection of the following conditions: Diagnostic trouble code is detected when Transmission Control Module (TCM) does not receive the proper voltage signal from the sensor.
hope it helps a bit :sick:
I have a 2004 kia sedona bougt it in oct of last year. Coming up on a year now. In February i was having trouble stearing my van and had check engine light. Took it to Christian Brothers Auto in Tampa asked for inspection of reported problems. Was told o2 sensors for the light. I paid over 2,000$ to have new rack and pinion to discover it was a bolt that was recalled more than once by report e found on safecar.gov. kia would not honor the original recall 600$ more..also at original repair no slipping of transmission.mechanic noticed a small oil leak and said i need valve cover gaskets so i had them replaced .now it slips alot..slams into gear..stopped for a bit then while driving home this evening. .at around 35 i lost all acceleration and when i pputmfoot on the gas the van stalle out...i was able to restart the car over and over and it stays running untill you give it gas then stalls again..also experienced all of the above complaints of the van slowing itself down when you let off the gas and hard shifting..this is the first time it has shut off and just would not move fowards..ive yet to try reverse because i dont want to have to push it back into my driveway after having it towed home
