Chrysler Cirrus Starting/Stalling Problems
I have a 97 Chrysler Cirrus and it won't start. It's spinning but won't crank. I have been told that I need to replace the coil pack but when i call to price one they say that car have a distributor. I was wanting to know if it have a coil pack or a distributor?
I have also had the car shift into 1st gear while driving, cannot shift out unless I turn off and restart.
Replaced fuel filter, pump and distributor and did not help.
Any suggestions - PLEASE!!!
Any suggestions, have over $600 in repairs already.
Rick
sorry i couldnt be of more help...
jafender
:mad:
AutoZone did a ckeck and there are 4 codes, p1493 battery tempature sensor (never heard of such), p0117 engine coolant temp sensor, p0112 intake air temp sensor (I too replaced it and the code won't clear) and p1496 5 volt supply voltage low condition which references the input sensors of the onboard computer. I really like the car other than this and wouldn't mind putting a little $ into it since it only has 79500 miles on it but I want to put only what's needed. Any advise would really help!!! p.s. also the coolant sensor or relay swith is coded and my fan constantly runs and my cage has malfuncytioned. I hope the computer hasn't went bad!!
I have checked the coil and distributor with an ohmmeter and everything checks out. I can hear the fuel pump kick in when I turn on the ignition key, and have tested absolutely everything with no spark yet to the engine. 266 000 kms, no problems whatsoever and now sudden death. I will replace a few things in an effort to resolve this issue and post if anything works.
nuts,
- Wally
2 hours ago - 4 days left to
It has been stalling mostly when I come up to a light or stop sign, coasting in general.
So far I have replaced:
distributor cap, spark plugs, wires, CAM sensor, Crankshaft Sensor (is that the same?), both belts, MAP sensor, my fuel pump was replace 10 months ago...
What is next? I have heard maybe the idle air flow sensor? I know this is a common problem...has anything helped?
Just curious if you ever resolved what was making your blow?
Mine had been pretty intermittent. it had blown three times in 7 months, but then blew three in one days with very little car movement between them. I suspect something is causing and intermittent short but I'm not sure where to look first.
I have been fortunate in that I had installed a remote car starter which ends up by passing the blown fuse as long as I but the key into the on position first. This allows me to move the car or drive a short distance when it has happened. But I can't use the brake or the auto start shuts off. Any input would be appreciated.
If you have one that starts running rough, shuts down and no check engine light, It appears that would be a good place to start with!
I just need somthing to start me off because mechanics will get you and i think my problem might be an easy fix, mabe the fuel filter needs to be cleaned , or new fuel pump relay??? somthing plz help :confuse:
cheers
Now my car is stalling again and no mney to fix it OMG!
MODERATOR /ADMINISTRATOR
Review your vehicle
If your car stops but will start again change your crank shaft position sensor.
If your car will not start again and your check engin light is on then you need a distributor.
If your car's engin light does not appear when you turn the key to the on position you need a computer. AKA PCM or Most commonly known as ECM.
Crankshaft position sensor sucks to get at. Way down under the distributor. The entire intake must come out. It's only $70 but find yourself a sideshow mechanic coupled with the book($30) and you'll save money.
Before you change the distributor: Pull the cap and check your rotor. Most likeky it's just burned up. Pull it straight out and slip in a new one. ($15)
Distributor is not easy. It's about $120 on eBay. The book tells you two methods. Use the Top Dead Center method by aligning your timing lines. This will remove all doubt. You don't need a shop but buy yourself a backyard mechanic to help. The distributor has a mark that aligns with the rotor. There is a reason for the wierd looking key. The key slops around so put some heavy grease in it to keep it centered.
ECM is super easy. You can do this yourself. Remove the filter portion of the intake. The filter box just pops out. Pull hard it will come. Disconnect Neg and Pos cable. Remone computer cables. 1 screw on each side and it pops straight up. The best thing is that the ECM is only $140 on eBay.
I did all this myself. I've been through it all. There is light at the end of the tunnel. I'll check in if you have questions just post them.
