It seemed like if I put my foot on the gas to accelerate (even gently) the noise would stop, however if I was coasting (when I take my foot off the gas or hold a constant speed between 70 and 75mph) it would make this rattling/clunking noise.
According to the carfax for the car, the transmission was just replaced at 28k miles, so thats why I really wonder if a brand new transmission would have problems.
Also, another question I wanted to ask all you Mustang owners is, when you start the car does the engine kind of shake or rumble? Is this normal? Sorry if this isn't the right place to ask this; this is my first sports car/Mustang so I don't really know much yet.
First Ford told me they didn't hear it. Today they said they heard it and it is normal due to shifting at low RPM. They purposely put play in there otherwise the rear end would rear out prematurely. It's due to shifting at low RPM.
I just hopped on this site tonight and read a few posts. Is there an auto mechanic out there that can tell me if this crap? Sorry, but I haven't read a lot of posts.
I'm going back next week (I haven't even had this car for a month) and test drive another "new" one on their lot and see how it sounds.
The pony wants to run and like someone said it takes a bit to get the shifting down. Face it the car wants to kick butt.
I have a 2007 Mustang V6 with a T5 manual tranny. About 50% of the time the tranny is perfect.Sometimes it won't go into first or reverse . I have pulled so hard on the stick I thought it would snap and then like flipping a switch it will fall right into place..once the car is going the transmission works and sounds perfectly. It has no noises , no grinding , no slipping and no leaks..Ford told me it is " normal operating condition" BU@%^&IT...Any suggestions would be appreciated
Thanx
RAMAMOE
the other day I started the car perfectly, waited a few minutes and left home.. I heard like the revolutions on my car went up but I thougth it was cold still. I stop in a sign and when I tried to go on it just didn't. couldn't go backwards or forward.. nothing but the engine still work
no lights came on to warn..
We checked the transmission fluid but it was good. I took it back to the dealer and they said it was the transmission, we changed it but the problem still.
can you tell me what it can be...
The problem is the SAME as our 2005 GT where pitch went way up after 40mph and got lounder and whinnier the faster you went.....it it was a noisy ring and pinion set witih pinion and carrier bearings. Total cost $500. Could have been done under warranty but Ford kept saying..."that's the way it's supposed to sound."
Bull ____. Hope you don't have the same problem, but if you do it is a warranty issue.
I have a 1996 3.8 V6 automatic Mustang with somewhere around 150,000 miles on it. Today it was 8 deg outside and I started the car and headed down the road. Well it started searching for gears and would shift up and down the spectrum.
Then it would kick out of gear or slip (not sure) then start searching for gears again. I never had a problem with this transmission till today. Do you have any ideas?
Got the car back and they said it was fixed.....and guess what it is still there and even worse, anyone else had this issue?
Let me know asap.
I just bought a 2010 Mustang V6 a week ago and I started hearing a humming/whistling noise when I am in 4th/5th gear also. My car had less than 100miles on when I started hearing it. I am not sure where it is coming from but when I hear it, it seems to come from the center console/gear box. Again, I am not sure if the sound is just been tunneled in from outside.
Does it sound similar to your situation?
is there anything else i need to change or do to dial in the transmission and i want to replace the speed sensor do i buy one for a 94 or a 95 and do i have to change the board on the car?
Does the new V-6 get a new (and hopefully improved) 6M transmission?
My current 6M (out of Marysville, OH) is damn near flawless (with a GMSFM assist), but planning ahead won't hurt.
all the best, ez....
Not saying this is your problem but just something to check if you haven't already done so.
I am on the fence for a 2011 V-6 6M.....................hope the new transmission is trouble free. My Dad told me never to buy the first new model year. Maybe he has a point.
ez....
