Mazda CX-9 Remote Start Question
baxterdown
Member Posts: 36
Hi everyone,
For those who have remote start. Once you have started the engine from the remote control, do you still have to turn the ignition when you get in the car?
Jose
Jose
1. Press the START button on the remote start transmitter to unlock all doors.
2. Enter the vehicle. Do not press the brake pedal.
3. Insert the key into the ignition (Retractable key only) and turn to the ON position.
4. Press the brake pedal. The remote start function disengages and the vehicle will operate normally.
Remote Start
Press TWICE within 3 seconds to activate Remote Start. Press and hold for 2 seconds to deactivate remote start. Press once to unlock all doors.
Enter vehicle, insert and turn ignition key to run
position and press brake pedal to deactivate remote start.
So tho it cant be intergrated into your card remotes.. .it does serve as a remote for doors it'self... ( tho not for assist should you have that ) ...
Do both scenarios require a key fob and separate starter device?
I am looking at 08's and want remote start as a feature, I assumed that if it was factory installed the start would be integrated into the key fob as is the case with Buicks I have seen. If it is not I guess that means I can take any CX-9 and have the dealer add the remote start and thus my pool of available vehicles grows... Thanks.
Factory does not install add-on accessories so that the production line can be smooth. (factory does options/packages).
1) I would not get the remote start installed as it involves taking the panels off and their mechanics were not comfortable with the install, the best way would be to purchase the vehicle with remote start installed in the first place
2) it would be expensive - close to $800
Any comments on how much you had to pay to get it installed by the dealer?
Just make sure they use the Mazda CX-9 Remote Starter and not any other Ford or aftermarket. You may lose some locking/remote functionality if the wrong model is installed.
Also, make sure your car has the TSB applied for the electrical problem with the remote car starter applied. Otherwise you'll burn out your ignition if you car falls into the serial# list. Only the dealer can perform this TSB so you might as well have them do the remote install.
http://www.finishlineperformance.com/pdf/cx-9/bulletin/01-046-08-1963.pdf
I live in the Northwest suburbs of Chicago as well, and have a 08 GT AWD CX9.
Did you get your remote starter installed (including the TSB) for $600?
Which dealer did you go to and who did you talk to at that dealer?
Did you have a good experience with them?
Are you having any problems with your new remote?
Sterling
1) Horn beeps - I want to turn that off for both when the starter starts and when you lock the doors manually w/starter.
2) Mine only runs for about 5 min. I'm in Buffalo NY - 5 min in the winter is not enough time to get ANYTHING warm. So I end up having to start it 2-3 times to get the car warm. I want it to run for 15 min before it turns off.
3) When I manually unlock the doors - I DO NOT want it to automatically lock them again. I started the car remotely the other day - walked outside unlocked the doors, put the keys in the ignition (no I didn't hit the break) and closed the doors. Minute later - the doors locked - WITH THE KEYS IN IT! I have to call home and get the other set brought out to me... talk about upsetting!
Shawn
I love my cx9 but I have to admit the service is terrible. I'm a previous multiple Honda owner and plan to spend my money there next time for the impecable service I had gotten in the past.
Hope this helps.
Before doing any work disconnect the battery. It will mean you will loose the programmed information of the radio (better write that down so you can program that back later) and chairs.
To stop door-lock and horn sound. You will need to remove the drive side kick panel. (first remove the drive side scuff plate, peel back the rubber weatherstrip, remove the plastic nut that is half way on the panel.)
Locate the BCM (body control module), which is on the front near the driver door behind the driver side panel with a lot of connections on it. (I can't upload image otherwise would have included, but if you are not sure; search on internet) The connector at the the side of the BCM at the top is a 30 pin connector. 2 wires (next to each other) leaving from the connector into the cable tree will have separate wire attached to it : G/R = green/red = HORN , V/W = violet/white = door lock. Remove the extra wire (NOT the wire that goes in the cable tree) for the function (horn or door lock) you don't want, that is going to the remote start model and tape it off."
What about changing the default run time? I think it's 10 min now - and I'd like to increase that to it's max. Thanks again!
After seeing so many posts with people having issues with remote starters messing up electronics after 4 or 5 years, I wouldn't want a remote starter in the first place, but I really wouldn't want an aftermarket one.
I live in Canada (Mississauga) and recently purchased a US 2007 Mazda cx9 that has a factory installed remote starter. However, I did not receive any FOB's and only received 1 smart card.
I have grown quite fond of my children, thus I did not want to sell them to pay the factory charge of purchasing a new card, programming and getting new remote fob's
Any ideas on how i can find them economically?
Looking for help
DJ
Look at http://www.mazdaparts.org/macxreenst1.html
There is a link documentation, on page 5, you see the diagram for the fuses.
Check both fuses HVAC1 and HVAC2.
There used to be systematic problem with this fuse blowing and a new wiring harness was required. (TSB-01-046-08). Not sure whether that had been applied to your car. The dealer should be able to tell you from the MAZDA maintenance system.
I have the same problem in my 2012 Mazda Cx-9. The remote will not start the car except when the main keyfob Smart key is in the car. Someone know how to fix this problem. I try changing the remote batterys. I disconnected the engine battery for 2 hours too. But still the problem
