Hyundai Accent Transmission Questions
in Hyundai
Recently, my car could not shift into gear when it was turned on, off it shifts fine. The car has a hydraulic clutch. So I thought it might be the clutch master cylinder, and replaced it, and that was not the case, then there was a small leak in the slave cylinder, which I replaced it. I was speed shifting it, then it got stuck in 4th gear. So it is in 4th gear, no matter if the clutch pedal is in or not. The shifter, flops between 3rd and 4th also. The dealer said to bleed the air better out of the clutch system. This problem came on fast, not gradual. What steps should I take, if the bleeding or the clutch hydraulic system, does not work?
My car will "get stuck" in low gear when you pull out into traffic, you try and accelerate but the revs go up and you stay doing 20Km/hr. Putting you foot down does nothing except increase the revs, you have to put your foot on the brake and come to a halt and they try accelerating again. As you can imagine this is dangerous if you have pulled out into heavy traffic. It has now also developed a new trick - sometimes it changes gear but around the 3oKm mark you hear a loud bang (like you have hit the car with a hammer) and the whole car jerks (hard enough for you to bang your head on headrest!). There is no particular time it happens (can be first trip of day or after many). Car is great after you get into 3rd and for long trips of accelerating past other cars great.
I purchased the Hyundi Accent in Dec 05. No problems till begining of 07 then noticed that sometimes had trouble getting into gear. Took to dealer to look at they said nothing wrong. Anyway it is now mid 2008 and problem is getting worse and my car has been in repair shop for 1 week and they say they cant find anything wrong as the on-board computer doesnt throw up a fault code!
Has anyone else had these type of problems. I am getting frightened to drive car as I am an accident waiting to happen and when someone drives into the back of me it will be my fault as they will not be expecting me to be doing 20Km/hr. I have a 5yr replacement warrenty for all the good its doing me. The repair shop says it could be a few things but refuse to try anything as computer not showing code implying that I am imagining all this. Other people have been in car with me when it gets stuck but as an intermitant fault the repair shop says it doesnt happen for them. As I am female I feel that I am not being taken seriously or they are waiting for my warrenty to expire then they will find problem!
My neice has a 2001 hyndai accent she purchased several months ago. The vehical has around 60K miles on it. I noticed the trans fluid had a burned smell to it and was discolored. Had her take it in for new filter and fluid change. After about 3-weeks past that, her over drive quit working. Now its a 3 speed. Any ideas from someone out there would be greatly appreciated.
Cystoman-
Burnt and discolored fluids are not a good thing. Is it a manual or automatic? Do you have the past service records? Even though it's low mileage I wonder if this is the first time the transmission fluid has been changed. You may need to take it into a transmission shop to get an expert evaluation of the problem.
Cystoman
Interestingly, our large Hyundai dealer here uses a synthetic base "so called" equivalent to SPIII ATF. I don't know how they can get away with this, as Hyundai corporate specifically states to use SPIII ATF. And, it also states as such as in the Owner's Manual.
You can go into any auto parts store, such as Advance Auto Parts, Autozone, etc., and you may find ATF that "claims" to be an equivalent to SPIII ATF. Don't use it, because it's not. Simply stated, if you use anything other than SPIII ATF, the automatic transmission will not work as designed, and its use will cause the transmission to fail.
Same goes with any of the Quick Lube stations, NONE of them stock or use SPIII ATF, and don't let them tell you otherwise.
Again, you must use Hyundai/Kia/Mitsubishi SPIII ATF in the transmission. Yes, it's more expensive than other ATF, but you will be rewarded in the long run by a reliable transmission.
Also, despite what anyone may tell you the hyundai certified transmission fluid is nothing different than the stuff you buy at the autoparts store, all youre paying for is piece of mind, I've seen the production charts of these chemicals and they use the same exact detergents! I've fixed this problem before, it happens due to cheap wiring in the shift handle... - to have a gear be there and suddenly not be there is unheard of, if it had anything fluid related to do with it youd feel loss of oil pressure in other gears, not just 4th..
(ASE certified technician)
Ben
My hyundai accent's automatic transmission has the following issueS:
A. When I start the car, it wont pick up easily, it takes a lot of acceleration (feels like i might be picking it up in the second gear), high RPM etc.
B. When I go past say 70 or 80 KM/HR, the engine makes a lot of noise like its struggling, and the RPM goes above 4000, which never happens!!
These two things happen most of the time now, although, on some occasions the car runs smoothly, but will start acting up on the trip back, or during the trip. Sometimes it even starts running normally AFTER Ive run it for sometimes.
Please help!
P.
P.
Problem just started today. Does not go into reverse. Hard shift and slipping when shifting into other gears while driving. Check engine light on.
What are the possible causes?
It is a Hyundai accent 1997 automatic
Every time I step on the breaks it seems as if the car has a stutter problem , at times when i push on the breaks just a little bit to slow down the car will stall out. It turns on just fine. It will also seem to get stuck in a higher gear. Example if I am going 60 mph the rpm will read 3-4 and just sit there, i can feel it in the pedal when it does that.
to add to that when it is stuck in the high rpm it takes about 10 seconds after a stop to get going up to an actual speed.
The problem started out with it just stalling out every now and then but ONLY when i push on the breaks to stop or slow down , the rpm will shoot up and then usually stall out unless i push down on the gas a little.
Email if you have any idea what i should do or why my car does this. I am a single mom and this gets very scary when im driving with my son and it will stall out as i slow down and make a turn or anything like that.
breathingintune@hotmail.com
I have a 2009 Hyundai Accent, Automatic Transmission and it has been bucking a lot, AT fluid checked and it stopped briefly but it is doing it again. I have about 25600 miles on it and the fluid level is fine. Not sure if this is a sign the tranny is starting to go? The other day it would not shift up into the next gear and the RPM's kept revving high.
I am under warranty but do not trust what the dealership will have to say. Does anyone have any knowledge of this happening to them? Thank you....
it.
Can anyone help me out?
JH
That's the free advice part of the answer.
The other part? Something is wrong with your transmission. I'm not so good with that. It could be something minor.
Maybe @thecardoc3 will stop in here with some advice.
