Bob
Bob
Save it for the Navigators and Escalades.
-juice
We haven't seen a spy pic of an SE model, but the drawings first posted a while back (not the new looney tunes versions) did have painted bumpers much like the current scheme. Which, by the way, I like very much. It leaves the lower portion bare for resistance to scratches, but it has a more classy integrated look with the rest of the car. IMHO.
But the spy pics posted before shows that the spare tire is not located in such a way.
Also, with the addition of D pillars, the inside sketch shows that visibility is still good. But that's just the sketch...gotta wait until the real deal comes out.
In the meantime, I think the "surprise" is in the engine rumors...
1) ABS is only available in the EX model
2) No traction control available
3) No VSA available
4) No side-curtain airbag system available
I know safety doesn't sell that well here but I hope they make these available...
Steve
Gray body cladding- I've never seen Subaru Foresters with gray body claddings. But then again most of the Foresters I see are the newer ones (I can tell by the brighter tail lights).
I think Honda is taking the Jeep Liberty approach. Unlike the Forester, where all models have the light gray cladding (which I think looks better than the dark gray ones on the CR-V), the Libertys have body colored matching bumpers for the top of the line models.
Chrome bumpers- ugghhh! I have more than once driven behind several late model Ford/Chevy pickups with chrome bumpers at night and the reflection of my headlights coming off from their bumpers is visually distracting and dangerous. I thought it was rather puzzling that they could still do that since some were already rusted pretty badly.
I don't believe any Honda has side curtain airbags..at least not any in the US. I'm really hoping for VSA as that is such a benefit to all drivers in all driving conditions.
Steve
You can get Dynamat material for hood liner. I did but was still not satisfied. So I went to J C Whitney site and got similar material from them. I actually layered over top of Dynamat hood liner material, so I actually have two layers. I used excess to put on as much of engine firwall and sidewall of engine compartment as I could.
The only place left to do is behind dashboard, but I don't have the guts to take it apart. I have a stone chip in window, so when I get it replaced, I may try sticking some material in cowl area.
Any other thoughts?
For the remaining doors (front passenger and both rear) I only covered the body panels. You should be able to see the silver Dynamat through the holes in the door. This was much more effective than doing the inner panels as shown in the first pic. I also covered the foot wells up front and under the floor mats. I wasn't able to get up under the dash (too much work, too little know how).
I was aiming at reducing road noise and was successful to a point. I really need to do something with the wheel wells to quell it completely. If you want a completely quiet CR-V, this is not the way to go. I would recommend that you address engine noise first. Now that the road noise has been reduced, the sound of the engine is clear as day. :-)
I think I may spring for a hood liner. I may do the sides of the engine bay and the firewall eventually. Before I spend money on that, I'm going to look into using felt or other cheap materials to add an additional layer in the pilars and line the entire roof. That should help reduce wind noise.
Audi puts a faux metal skid plate on its allroad quattro.
varmit: I hope you don't get squeeks when you put all those panels back in place. Make sure to replace any broken pins or clips.
-juice
JM2C
The tough part was dealing with the plastic that covered the electricals.
The plastic was actually easy to remove, but it was held on with some of the nastiest stuff I've ever worked with. It was kinda like glue mixed with grease. I must have looked like a Norman Rockwell illustration by the time I was done. I had it on my hands, my arms, my jeans, in my hair,... The stuff was so sticky, it got everywhere.
I peeled the plastic away, but half of the goo stayed stuck to the doors. I had to work around it. I'd be reaching into the interior of the door panel to press the Dynamat against the sheetmetal and I'd accidentally place my free hand on the stuff. When I pulled my hand away, a long string of goo would stretch out between me and the door surface. It'd break and land all over some tool I was using or snap back against the door (creating a new sticky spot). I still wake up at night...
Verdict: It was expensive ($250) and the results are average. There is a substantial decrease in road noise, but most folks would be better served if they attacked the engine bay. I don't mind the engine sound, so I went about things differently.
I purchased abut 36 sq.ft. and managed to cover the foot wells, the bottom half of the firewall under the dash, a double layer on the driver's door and single layers on the remaining three doors. I also have a bit between the front seats.
For the average buyer, this is what I would suggest.
Get a hood liner as described by Gkoff. Buy some Dynamat or similar material and apply it to the sides of the engine bay and as much of the firewall as you can. The firewall will be tricky. Next do the front doors. Then get up under the dash as far as you can (also a tough job). There is already sound dampening material under the floor mats. Don't waste the stuff covering that. Instead, use whatever you have left to cover the space between the two front seats.
I would think that the cargo area is one place to attack as well, since that's where the road noise echos.
Drew
Vans, SUVs, and Aftermarket & Accesories message boards
I hope this not the official pic!
sept. 1st.
Those interested in seeing the first photos and review of the CR-V should check out the Canadian newspaper, www.nationalpost.com. Unfortunately the National Post makes it hard to link directly to their articles. Go to the left sidebar and see the box called "special reports". Click on Driver's Edge and the CR-V review will be the 3rd item.
The styling is evolutionary (Hollywood Extra was right, even though a lot of their stuff looks like doctored crap). Styling is subjective of course, but seeing the black cladding creep up the nose gives the car an ungainly appearance, as do the thick black rails that go across the drip edges.
The article says that torque goes up to 162 ft-lbs, but doesn't mention hp changes. 0-60 times are supposedly 3-seconds faster. Handling is better, even with the change to MacStruts. I'm really happy to see that the rear seat has a fore-aft adjustment (I'm 6'5", so people behind me get squished). All SUVs and Minivans should have this feature.
There's a shot of the center console, showing the integrated parking brake lever built into the left edge of the console (rather than the floor). No word on whether the picnic table survives
Looks like it should hold its own, and provide enough reasons not to buy an Escape.
Happy motoring, eh!
http://www.nationalpost.com/specialreports/story1.html?f=/stories/20010831/677362.html
Very interesting. . . .
By the way, in case anyone is wondering, I'm not THAT Vince.
Is this true?
Most people would credit the RAV as the first cute ute, but then they don't have to think of a nifty line to fill in space for an article.
I wonder how many valets will figure out that hand brake! Looks neat, but the overall look is still "minivan".
RAV4 came first, though. The author said the CR-V was, maybe it was that way in Canada.
162 lb-ft is a hefty improvement. That's what my Forester has, and it comes in handy when you're in deep sand or towing a loaded trailer, for sure. It's way more than we expected, too.
A 3 second improvement, though? Maybe over the original autos that were hovering around 12s. Knock 3 seconds off the quickest times on the former manual tranny CR-V and it would outrun an S2000!
The rear seat fore/aft adjustment would be a big plus, too. Right now I think passenger room gets a priority over cargo (vs. the opposite on my Forester), but the adjustment would allow it to be more flexible.
Also, an LX with ABS would be a welcome change. Why save safty features for the rich? I hope that's not Canada-only.
-juice
Odman - Love the review. Thanks.
Love the parking brake. Odd that they didn't mention window switches.
But you could go back much further. Subaru was first with 4WD on a raised car platform in 1974:
Then came AMC with the Eagle, a few years later. People commonly mistake the Eagle for the first crossover, but Subaru beat them to it.
-juice
It's true that crossovers have been around for a while (back in the 1930's they were racing a small car with 4WD), but that doesn't necessarily make them a mini-ute.
If true, I think the new CR-V engine will be better suited for the task for an SUV. Torque is not only upped to a healthy 162ft-lbs, but there seems to be more available down low. That'll definetly help cut down on cabin noise.
Did anyone notice that the column mounted shifter is still there?
Ken
Bob
Bob - did you get the latest Autoweek yet? I'm not at home. There may be some more info in there. The web site links to the sister publication Automotive News article we've seen.
-juice
Bob
If you want to talk compact SUV, the Jeeps were the first ones, no doubt about it. But for 4-door models, it would be the Suzuki Samurai.
So what is this "surprise" that the Honda web site was talking about...???
The styling of that 1974 wagon may not fit the bill, but the hardware is closer to a traditional SUV than the CR-V is. It even had a low range!
Santa Fe isn't that big, it just looks that way. Optical illusion?
-juice
I'm pretty sure it eventually morphed into the Suzuki Sidekick, but I really have no factual data backing that up.
The Santa Fe is actually that big. It's closer in size to a Lexus RX300 than any other mini uts.
Some automobile sources even list it as a midsized SUV, instead of a mini.
INKY
Bob
