Visitor Agreement.
The truck has been starting fine all this week. The starting issue is not related to outside temperature or dry or rainy weather. It is almost like playing russian roulette. I have been checking on the internet and many people seem to have the same issue, but I have not found any solutions to this problem.
Does anyone have any suggestions? :confuse:
Have you found the trouble yet? Feeling your pain in Tennessee....
I also had a stalling problem that was caused by low coolant there is a low level sensor
I also had a stalling problem that was caused by low coolant there is a low level sensor :shades: Also camshaft sensor
98 Ram 1500 5.2 very slow crank on hot starts, cold starts fine. Measures 12.5V across battery terminals. 14V on dash gauge, if running. Can you please tell me how to troubleshoot this issue.
Ken
http://ifar.ca/support/vehicles/40-tsb_(08-007-08)_-_2006-2008_chrysler_wcm_no_start.html
Deals with the WCM and eletrostatic problem. I have 08 Dodge 3500 Diesel. Bought used at 48K, currently has 74K. Have had new key plus WCM replaced once at about 60K. AFter many many months of checking [qualified] sources, all I'd come up with is that my vehicle, because the security system was factory installed, it can't be removed or bypassed.
Truck currently has same problem and is currently at same Chrysler dealer wo did initial repair. I got the above URL tech bulletin info from an on-line Dodge specialist. He suggested if dealer can't/won't help, call Chrysler Customer Service. I'm currently in contact with them on my issue. No outcome as of yet.
LR
kcram - Pickups/Wagons/Vans+Minivans Host
Hope it helps.
Phoe
