Dodge Durango Electrical System Problems
My 2003 Durango was perfect until yesterday... the a/c went out not the fan just the cool... the ABS light, emission system light, the brake light and the air bag light all came on together. The lights went out for a little while then the a/c worked but then all the above mentioned lights came back on and no a/c!!!! Does anyone have a clue what is going on?
Scared to death but believe in Dodge Products
Thank goodness no one was hurt. Will your insurance company cover the damages?
SUVs and Smart Shopper
Any body else have this problem??? my mechanic can find nothing anywhere other than starting to throw parts (and my dollars at it)
Also my child lock for the windows located in the drivers door has broke in the locked position, which means you can not roll down any of the other windows except from the drivers controls. Is there a way to bypass this, I do not need it anyway?
Any help would be appreciated!
Wayne wkosacz@hotmail.com
The only problem with the vehicle so far is that the interior lights do not come on when the doors are opened.
We can turn them on manually (by pushing on the lights or associated buttons).
I have been through the instruction manual, but can't find anything indicating that there is a dome light override or other feature.
The lights also will not come on using the rotary switch on the instrument panel.
Any ideas?
Had the same problem this morning. Have you had any more news? In my case, it was a very cold morning (-21C or -6F). The car started fine, ran for 10 minutes. I parked to drop off the kids and came out 3 minutes later. The truck ('03 Durango) started but shut down within seconds about 3 or 4 times and then wouldn't even start. The "Security" code was flashing which generally happens when you try to start the truck with a key that is a 'copy' but does not have a chip embedded in it like the fatory keys do. My wife came with her key and the truck started fine. I drove another 10 minutes and parked at work. I restarted the truck with my key and had no problems. It's at the dealer's today but that's always a hit and miss affair when they can't reproduce the problem.
everything has been going pretty well until last night...
it was the first time ive driven at night for longer than a half hour. after i was driving for about a half hour the headlights and dash lights started flickering on and off and then they just went off for good. i pulled over for about 10 minutes and then they were fine again. until another half hour went by when the same thing happened. the dome light and rear wiper also stopped working when the lights would stop.
anybody heard of anything like this before? or know how to fix it?
i cleaned the grounds, and am pretty sure its not the relay or switch but i could be wrong.. is this a bcm problem?
I am going to keep checking
I hope this helps.
Damien
