Ford Expedition Electrical Problems
Hello,i have a problem with my 01 expedition it seems that my headlights stay on even with my car off my windshield wipers are not functioning and my a/c stays on when i turn my car off even if i leave the a/c on but have car off they seem to stay on i dont know what is causing it to do this but i would like some helping in resolving my problem i am very greatful if someone can help me.
Thank you!!
Thank you!!
It should come off relatively easily once you pop a couple of the connectors. Then the switch itself is held in by a screw. Unscrew it, and disconnect it. Then you should be able to get a replacement from Ford.
Good luck!
SUVs and Smart Shopper
Usually, the fuse panel and GEM do just fine being dried out and then send the vehicle to a glass shop to fix the windshield gasket. Sometimes, they require a new fuse panel and GEM. The GEM comes blank and has to be programmed by use of a dealer level scan tool.
Cause is poor factory windshield seal. Water gets blown in thru gap in seal, travels down the windshield pillar and drops onto the GEM/fuse box then on to your foot!
Dealer has service bulletin for repair. Fed. govt. NHTSA has looked into it and decided its an inconvenience, not a safety issue. Go to NHTSA and look into Action Number : EA05015 . Their test vehicle leaked in the upper left side of windshield!
Good luck!
So far as reimbusement, there's always small claims court....
Good Luck
I did place a complaint with NHSTA but have not heard from them either.
Since this problem in not just with Expeditions, mine is a F150, and have seen the problems with Taurus too, it is a defect in Ford products in general.
I do not see why they are not reliable in making restitution to their customers.
Contacting the BBB probably won't do any good either. Maybe a class action suit would be the way to go?
I haven't had the windsheild looked at yet. Would I be wasting my money on having this resealed? What about the cowl? If anyone knows, I would appreciate your input. Thanks in advance.
Additionally, does anyone have a diagram of the interior and engine compartment fuse identification? Thanks
one being a relay relay but know nothing about relays. My expedition has the door ajar on the message center but no doors are ajar. This in turn causes the lights to not go out and the door locks to not lock automatically and when you take the key out of the ignition the radio goes off instead of staying on until you open the door.
Secondly, we also have problems with the cruise control not working.
Thirdly, the foot pedal that moves the pedals forward or backward.
Last the cd player keeps the cd and will not release it I push the eject but it shows no cd but I know for a fact there is a cd in area 1 and a cd in area 2.
any help would be appreciated.
1:The 7-8 and 9-0 Keypad buttons will not work anymore.
2:The Truck will not turn over. When the Key is turned to the ON position, it just makes a loud buzzing sound from the Glovebox and it will not even turn over tostart.
3: The interior lights won't turn off. In the Computer screen, it says Door Ajar but all doors are closed. The lights soon go off... Then comes back on!! Eventually goes off and then comes back on and the cycle continues. At night, this becomes very distracting...
4:Rear Driver Window will power down, but not power back up unless pressed from drivers seat.
I had to replace my relay switch which is on passenger side below the glove box. It worked for months, then weeks and now days. For a temporary fix you can replace the relay switch. I am trying to find a permanet fix.
I've have heard for the last time how service tech can not make car act up and they've "never heard of anything like this" before. I guess non of them service techs, dealers or Ford pay any attention to the communications (emails sent to them or blogs)
If they can't repeat problem.... Can I sell car without problems??
:mad:
If anyone has listing and info on previous parts problems fixes, I am printing tons of pages out to take with me to the dealer to show them of the "non-existing" problems with electrical system(s).
I have replaced the battery and alternator. My mechanic said my alarm system was malfunctioning so he disconnected it. That did not solve the problem. And off course when I try to show my mechanic what is wrong it doesn't do it. Very frustrated !!!!!!
I love driving the Expy but gas is really becoming a threat. We put in $75 and only got 3quarters worth of gas... But the MPG is improving! I was driving and I was getting nearly 16mpg City! Big Baby never revs but it is a beast when it does!
As much as we hate paying for gas... and we HATE, we love our truck more! Being paid off only adds insult to injury! :shades:
-Cj
Have you found a solution or like me, are you just replacing the starter relay?
I have had the vehicle in for service 4 times, each time they replaced the symptom but never fixed the cause.
Now that I know what to change, I found the starter relay at Napa for $10.00
Any input would be helpful.
Item 1 fixed. popping in rear passenger wheel well, was plenenun mototr for lowere and upper air cox was sheared had to replace whole unit $65
Item 2, interior lights coming on , door adjar and locks on and off, fix for this was wd40 in all door mechanisms one of teh doors had gummed up and was flaking out, but ever since I sprayed them and opened them and closed them seveal times to get the lubricant throughout, have not had this problem again
Item 3 Pending problem. Radio goes off and on intermittently, can sometimes hear relays when this occurs sometimes not, at the same time this occurs the power windows and door button illumination goes out.
What I have done so far, removed and inspected the Fuse block and the VSM, no water or traces of water, opened every relay and cleaned all the contacts no resolve, there were solder on relays on the underlying board of teh fuse block so I thought maybe one of those had wigged out, so I replaced the entire fuse block, $178 this did not fix the problem. I even cleaned all the battery cables and replaced the battery. ANother $109(recommneded by Ford Tech, I was due for a new battery any way, but once again this did not fix it.
SO isolate time, is it the buttons on teh door for the window controls? Is it the Radio or is there a short
I was so upset, I started to remove the dash cover firs tthe faceplate that covers the steering whell gages and before I could get it out as I was trying to Jimmy over the steering whell column, I noticed that as I shook it the radio came back on, seem to happen off and on as I was shaking it then it stopped, tried to shake each indivisual wire harnes still connected to this but could not isolate it, in fristration I hit the center of teh dash over the radio, walla the radio came on then it wnet off and every time Ihit the dash the same thiing, SO is it in the radio or is there a short under the dash, this is where I am now trying to trouble it, but I am pretty sure it is in the dash or radio, if anyone has already figure it out let me know before I pull the whole dash apart looking for an open , burnt or broke wire, see sometimes when I hit bumps or turn hard I notice the radio will do the same ting, remember I said the windows stop functioning at the same time. How many more grey hairs Ron
