Have you dealer replace the A/T fluid, and reset the adaptive learning module. Then have them take you out when they do the adaptive learning procedure. Make sure they follow all the TSB, something about the ATF temperature must be above a certain temp (Trans Temp Sensor) before the "computer starts learning"
if no DTCs are set, have them hook up the GDS and do a flight record. TELL THEM YOU WANT THE PRINTOUTS!
MOST TECHS DO NOT KNOW HOW TO DO THIS...THIS CAR IS A COMPUTER ON WHEELS AND UNLESS THE COMPUTER STATES THERE IS A PROBLEM (DTCs), YOU WILL NEVER GET THIS FIXED.
I would also check my e-brake, make sure it is not dragging. Jack-up the car like you would change a tire. Make sure the e-brake is off (block the other wheels before you jack it up) see if you can rotate the rear tire with ease. Do this for both rear sides, if you feel any drag...take it back to your dealer and tell them you want to see them do the pre-inspection....It was not done correctly before you bought the car and to give you $200 refund.
Additionally where are you located? (cold weather area)
Are you a light-footed driver?
Lastly, make sure everything is documented..documented...documented.
GOOD LUCK
I now have 1700 miles on it and it seems slightly better. But then I drive another car and feel the silky smooth shifts are relize it sucks. If I am accelerating hard, it shifts smothly. It's also OK when cold. However once the engine get up to temp, under light to moderate acceleration, the 1-2 shifts are very disruptive, so mush so that I am concerned about driving in the snow.
I also have "learned" to compensate for the harsh 1-2 shifts. As I approach the 1-2 shift, I back off the gas now. This minimizes the shock. Otherwise I love the car. It really annoys me that the dealer is unwilling to concede a problem.
As a side note, the loaner drove perfectly. And that car is driven by someone new every day.
Brakes or Transmission?
When you say "shifts harder than the santa fe but better than when it was new." (your 09 Sonata, I assume)
Did the servicing Dealership give you a loaner Santa fe or do you own a Santa fe?
I HOPE YOU HAVE A COPY OF THE SERVICE WORK ORDER.
Who's your Servicing Dealership?
I'm glade to hear you think the problem is fixed.
HAPPY CAR OWNERS ARE USUALLY REPEAT CUSTOMERS
I've had my 08's transmission reprogramed 4 time now and it does not fix anything.
I was told after owning mine for 15 months now, that our (wife & I) driving style is the cause, we are 'light footed drivers." The HMA Regional has drove the car several time but it never happens to him, so they claim there is not a problem.
I go to court tomorrow, wish me luck... this is not my only problem... apparently the parking brake has been dragging for 13 months now and guess what ... the brakes are not under warranty now... It been in 4 time for the noisy brakes, but everyone just ignores the repair procedures... I'm done with Hyundia, the cars might be o.k., but the techs I've worked with do not know what they are doing!
I will keep you posted.
I just told them that my 1-2 shifts were harsh and that I heard there was a service bulletin about it.
The updated the firmware on the computer controlling the tranny and so far I am pleased. I no longer have to get off the gas as I feel a shiftpoint coming.
I was starting to regret my purchase due to the harsh shifting. Now it's smooth as silk.
If you are experiening harsh shifts please go to your dealer. The computer update was quick and effective.
http://sonata.jerrystout.us/tsb/tcm_calibration_update.pdf
(thanks to jerry)
I can't say enough how happy this has made me. I was very happy with the car but the harsh shifts were making me hate the car.
http://www.jerrystout.us/sonata/tsb/tcm_calibration_update.pdf
Don't click it.... copy and paste it into your browser.
If you still can't get it, let me know. I have the pdf, i can email it to you.
(see, that's all it takes to make the board think it's a link!!
1. Cracking and popping sounds from the dash. Sounds like a bowl of Rice Krispy Treats whenever the heater or A/C is turned on. Must be the cheap plastic expanding and contracting with a change in temperature. I know of 15 year old cars that do this, embarrassing!
2. My right speaker has developed an annoying rattle whenever music is turned up to about half way. The Infinity system stinks anyway, but this issue just makes me not want to turn it on.
3. My navigation system has frozen up on me a bunch of times, forcing me to restart the car to get it working again.
4. Various strange noises coming from suspension system. These noises started showing up at the 10,000 mile mark, and they make the car sound like a 10 year old car, not a one year old car.
5. The worst of all these issues is the evil transmission in this car. The 1 to 2 shift is brutal, and is rarely smooth. Makes driving the car a nauseating experience. Even more serious than that, is the extreme, violent lurch of the entire car when slowing down from freeway speeds, say coming off an exit ramp. It's like the transmission gets confused, and instead of slowly down shifting, dumps the gear to 2nd car while I'm still traveling at a good rate of speed. I can't tell you how unnerving this is. It sounds like the transmission system is just going to grenade out of the car into the street.
There are other issues, but I'm too tired to list them all, those are the main annoyances. I know some of these issues (maybe all of them) could be fixed with trips to the dealership, but what a PITA to have to do that. I bought a brand new car so I wouldn't have these problems. Otherwise I could have bought used and let some other sucker take the depreciation hit. Instead now I'm the sucker, both for buying new, and for believing Hyundai is of the same quality as Honda, Toyota, or Mazda.
This will be the last Hyundai product I own. Thankfully I also own a 2009 Honda Fit Sport that I'm sure won't have any of these issues. The Fit was supposed to be a secondary car to run errands with and take my big dog around on the weekends, but it has now become my primary vehicle. My $18,000 Honda Fit drives better, much better than my $27,500 Hyundai Sonata. The Sonata is up for sale. Anyone want a lightly used (12,000 miles) 09 Sonata Limited V6 in the Dallas area? Should be interesting to see what kind of hit I take on this car with Hyundai's stellar resale value.
I have had cars in the past that the windshield would creak over bumps and potholes.... but only a couple of times a year... My sonata couldn't go 45 seconds... it nearly drove me mad!
My nav froze up a few times and the voice command didnt work at all.
1-2 shifts made my insane, i would back off the gas just before the shift and it was almost smooth. 2-3 was a little better but not much. Tranny in general is not the most intelegent.
My dealer was able to correct these issues for the most part. Windshield squeaks and nav issues are totally resolved. He flashed the tranny as per this buttlin
and I am a happy camper. The 1-2 shifts are smooth as silk... at least by comparison.... is my wifes acura and my previous inifinti better... of course... but this is a Hyundai and overall it's amazing!.For the money, best car I ever had.
See your dealer... he can make you like your car again.
Your link in posts 126, 134 and 135 all work perfectly for me; I have tried each one individually. I can't imagine what the problem is that they don't work for you. Perhaps a browser issue? Maybe you need an updated Adobe Acrobat plug-in?
Sorry I can't be of more help.
van
Ever notice how these sorts of things never rear their ugly heads in a test drive? In my 09 test drive there was no crackling dash, no navigation freeze-up, no harsh 1-2 shift, no strange suspension noise etc. But over the course of a year I've now had all of those issues. I really believed Hyundai was at the quality level of a Honda or a Toyota but I don't think they're there yet.
I, we, specifically bought a new car so we wouldn't have to deal with issues like mine. It just has me very worried about future reliability of the car if I'm having all of these issues in the first year of ownership.
I am new to this forum, but have been lurking around at other Hyundai forums with questions. Basically, I am not happy with the performance of the car. I think my issues have been discussed before, but I will highlight the issue that is bugging me the most and making my living with this car VERY hard.
It is the transmission shift quality. The 1 -> 2 shift under slow acceleration is quite jerky and unsmooth at all times. Also 2 -> 3 shift under slow to moderate acceleration is jerky from time to time, but not all the time. It seems like on both these shifts, if I back off the gas at the shift point, it is seamless. Also under hard acceleration (not as bad a WOT), the shifts are MUCH better. Initially when I bought the car, these shifts were horrible. Last Nov, I got the latest TCM update and although the shifts have gotten better, they are still bothersome. The dealership says there is nothing they can do anymore since they can offer only what Hyundai provides them. I have had the service manager drive the car and although he understands what my annoyance is, he does not have a solution. Hyundai says there is no further TCM update available.
I do not know why I did not discover this problem during the test drive. My bad!! Do you guys have any suggestions? If the shifting was smooth I could probably live with this vehicle.
Hang in there... the dealer can fix it.
Have you done the TCM update? I did and still I have the problem.
I did the TCM firmware upgrade and it is still bothersome.
All I can say is that since I got the update I am happy with the car.
I hate to see this happen because Hyundai seemed to be making great strides for a while there.
Let's hope they get back to making progress and fixing current issues.
