Hyundai Sonata Transmission Problems
I recently purchased a 2006 Sonata V6, pre-owned with around 28000 miles. It seems like a nice, dependable car (I bought it primarily for my wife to use). One thing about its driving characteristic seems unusual, however, and I would like to know if it's common with this year/model; if anyone else has experienced this or if it might be a transmission problem. When accelerating from a stop at a steady increase in speed, the shift from 1st to 2nd seems to "lag", almost like there's a noticeable pause between shifts and for a brief second the car feels like it decelerates before accelerating again. The sensation is very slight and hard to really describe accurately, but it's there, enough to be noticed. I heard that these cars have throttle-by-wire and I don't know if that has any relation to what I'm describing. Does anyone have any ideas or comments?
Could this "lag" be related to different drivers and the tranny trying to adjust to those different drivers?
Is it normal to have it hunt looking for the proper gear when traveling easily at 40 mph?
I have a 2005 Tucson. It has an rpm of 3,000 at around 60 mph. Needless to say, it gets noisy at higher speeds. At the same speed, my 1995 Camry is about 500 rpm lower. I can go around corners in 3rd gear without any problem.
Anyone notice the same problem with say, 2007 or 2008 Sonatas?
60mph " " --> 2100rpm
20-30mph climbing hill --> 2000rpm to 3000 rpm.
Life ATF which is supposed to be consistent with SP-III. I have a signed letter from Valvoline which states that use of the fluid WILL NOT INVALIDATE the Warranty and it also lists all the vehicles that it is recommended for - which includes KIA SP-II and SP-III and Hyundai. Although I voiced some concern about this - I was assured by a reputable AAA repair shop (SAMCO in San Diego) that I was OK to use the Valvoline transmission fluid.
...disappointed
http://www.hyundai-forums.com/index.php?showtopic=6559
Another with the same problem:
http://www.hyundai-forums.com/index.php?showtopic=19223
All (5 or 6) similar models i have tried here in denmark had the exact same problem, and the danish importers technical manager, who also drives a V6 has the same problem, and finally accepted that there is problem that apparently cant be resolved. And i must say that, as far as i know, all have been tried from here.
An A/T specialist even tried to deactivate the torque converter lockup by bypassing the brake-switch, but it didnt bring us closer to a solution (same shudder or even worse).
Status for now when my cars has approx 52000 km on the odo:
Get the tires optimally dynamically balanced (Hunter), and the vibration can be minimized (I have at least experienced that high tyre RFV (Radial force variation) and out-of-round can intesify the problem)
The more perfect tire - the less wobble/shudder/vibration
- But even with the most perfect tyre, as the set i have now where the RFV on all four tyre is below 2 kg, i still got a slight vibration. (Michelin PA3 winther)
The point now is, that if i not have had all these problems from the start, and really got attention to it, then i guess i wouldnt have noticed it today. With my last set of tyres it's hardly noticable.
I just hope that all my complains in the last 2½ year has been noticed by Hyundai and hopefylly has been resolved in the facelift...
I'm really looking forward to try it when it arrives to Denmark in the 2. quarter of 2008.
If it is solved - i will definately change...
In all other areas - i think the car is perfect, and i wont hesitate to buy one again.
Feels like a loss of power until it passes 2nd gear, fuel mileage is 19-21 city/hwy 60/40 hwy. Took it to the dealer and no codes in the computer. Any answers will be helpful! Thanks!
Don't try to save a few dollars per quart on ATF, just buy the real stuff!
Your Hyundai automatic transaxle is specially designed to operate with
HYUNDAI GENUINE ATF SP III, DIAMOND ATF SP III, SK ATF SP
III or other brands meeting the SP III specification approved by Hyundai Motor Co..
Now how you interpet that is up to you. I read it as they are saying a fluid that meets the SP III specification that Hyundai approves for use in their transmissions, not that Hyundai has to specifically approve an aftermarket manufacturer. But since I only have 19,000 miles on my car and have 31,000 miles (approx 11 months for me) to go before I begin to think about doing a flush and fill I have time to wait and see what happens.
I do sell Amsoil and they make a ATF that they say meets the SP III specification along with the Castrol product I saw on a store shelf this weekend and like has been said on here and other forums some people have changed out to other fluids and we will see how it goes for them. I am not having a problem currently with my transmission and hope not to but when I do change out my trans fluid I will base my decision off of a cost basis, i.e. Hyundai labled ATF, cause they do not make it do they, or one of the other ATF's out there. I can't believe Castrol, Amsoil, or any other manufacture would be selling a product that they say meets the SP III and it did not. The lawsuits would sink them rather quick and if you did use the Amsoil ATF and it ended up destroying your transmission and it was the fluid that caused the problem they would either pay for the repair or replacement of the transmission. I would think Castrol would also be required to do the same since they say SP III right on the bottle.
What have others heard?
2. Jerks and surges.....is this when it is cold? If so, yes. Depends on what you call J&S. Mine does it when it is cold. Has since purchase. Others have posted this too.
I am currently having the following problem and would appreciate any info that anyone might be able to provide.
My transmission has recently begun to "stick" in 1st or 2nd gear. When it finally shifts (after the RPM'S rev up) I have lost 1st gear and overdrive and my check engine light will be on. Once I kill the car and restart it is perfectly fine.
Please let me know if you have experienced this or something like it and what was needed to correct the problem.
also found here that some customers had the same issue.
Were you able to get your dealership to exchange your original purchase? Good for you! How did that go?
The problem is the transmission. when my car was at 40MPH it's stater (shaking a little bit) from Hyundai the service install a program and they fix it...but it was working only for 3 days. now the problem it's on 50MPH...
I just bought Hyundai sonata 2008. It has 4000 miles on it. While shifting from 1 to 2, I hear a weird noise. It doesn't happen every single time. It only happen while driving first time in a day or driving after couple of hours. Once in motion, I don't hear that noise. I don't know if it is common with the sonata since it has a stubborn transmission. Is this happens to anyone? Is this something to worry about?
please if anyone has a problem and the transmission make the car shutter around 50mph. please post here a message.
thank you,
Please look at: http://townhall-talk.edmunds.com/direct/view/.f148eb4/18!keywords=#18
I, and a lot other has noticed this shutter, and it seems that the new faceliftet 09 also has this annoyance, according to my personal experience.
Has been a TSB for the 2,4 A/T:
http://www.hyundai-forums.com/index.php?showtopic=27093
But please send them a letter of complain - maybe - even though i seriously doubt - they wil take attention...
BTW, how was the job done? Unless they used a pressure flush system, more than half of the ATF fluid does NOT get replaced. (I'm not a fan of the pressure flush systems, which attempt to flush the fluid out of the torque converter) So you have a 50%-50% mixture of old Hyundai fluid and new Valvoline fluid, which is pretty scary.
I haven't taken it to the dealer yet
