I did get a Honda filter and it is smaller than all the other filters for Honda's I've owned in the past but it was the same as the one I took off my V. 2200 miles and running better every day.
No one should go over 75-- okay but one of the magazines said that the 5spd top end was 99 mph let me just say that I don't believe them anymore..
ATB
http://www.edmunds.com/reviews/roadtests/roadtest/48575/article.html
tidester
SUVs
Onelife - Spyponder is correct. Don't take it out on the highway and set cruise control for hours. To properly break in an egine, you should vary the RPMs for the first few hundred miles. Use it as a chance to find more interesting roads. In fact, we have CR-V event coming up in PA. That would make a nice detour.
Honestly I do think it will help as well because some potential CR-V buyers will move up to the Pilot leaving more of what seems to be the best mini SUV (or whatever category it is in) for those of us who don't want a V6 or seating for eight (or seven). What do you think?
I expected the city mpg to improve slightly after the full break-in (now have 3000 miles on the odometer). But my first tank back in the city was 17.8 mpg.
What are others' experiences? The CR-V seems to be running smoothly (except for occasional hesitation from a stop sign that I may just be imagining). I know I'm being a bit obsessive about this but what are new cars for?
Is there a lock available for the spare? How much and is it worthwhile?
onelife - good for you, looks like you have a good plan. There is really not much to see/do in Okla(pardon me for saying that). I am not sure where you will be coming from, there is a Precious Moments town in Carthage, Missouri, which is about 2 hours from Tulsa. My wife loves that place, I found most of our female friends do too. Maybe you can take a trip there with your wife. Check out www.preciousmoments.com if you are interested.
For break-in, the general rule-of-thumb is to keep it under 4000rpm except in emergencies. That ought to allow "go with the flow" highway speeds.
-juice
In any case, wheel locks are a good investment. When you buy the Honda wheel locks, they give you five of the locking lug nuts, which includes one for the spare. Just make sure you keep the adapter somewhere inside the vehicle
5W30 has been used for years by Honda. The switch is only to improve CAFE in my opinion. Perhaps .5 MPG with the fleet and Engine wears out 5 % earliear due to increased wear. 5w20 is THIN--especially in OK. BTW I use Motorcraft 5W20 semi synthetic in my Odyssey and Acura 3.2 TL
INKY
FWIW I personally would use what they recommend (and did in my Accord which also recommends 5W20) but don't think 5W30 will hurt anything. YMMV.
1990 Jeep Grand Wagoneer - 4499 lbs - 144hp V8
1990 Chevy Suburban - 190hp V8
1990 Chevy Blazer - 160hp V8
1991 Explorer - 155hp V6
And my favorite, 2002 Land Rover Disco - 4630 lbs - 188hp V8 (ouch)
Now, granted the torque on most of these is pretty impressive, but it still cracks me up. I keep thinking of dropping the 2.0 from my CRV in a Grand Wagoneer. More horsepower. Bet that sucker would really fly.
Of course, they're so light you have to park them with a paperweight on top...
Maybe he has caller id
Try a pay phone!
tidester
SUVs
I get a feeling that my 2002 Cr-V is veering toward right, whenever I let the steering wheel slightly loose ? Has it something to do with tire pressure etc. or do I need to take it to the dealer.
Please note that this is only when I let the steering wheel loose and not otherwise.
Check your air pressure. A tire a couple of pounds low can cause this.
Road conditions play a very active role in how your V tracks.
If your wheels ride up on the "crown" of the road, this can cause a pulling condition.
Find a highway and check it again. Check your tire pressure (tire psi is on the sticker inside the drivers door) for the recommended psi.
If it persists, take it back to the dealer.
Once again, thanks for your prompt, valuable advice.
Good Day !
The street in front of our dealership has quite a crown. Some people will immediately take their hands off the wheel....IT PULLS TO THE RIGHT!!
Big difference between a normal "drift" and a "pull".
Also, the CRV has considerably smaller (diameter) tires than are found on the standard Escape, and even more so than the Escape with the 16" alloy wheels. This can also help get things going quickly..
I would guess that just by putting the automatic tranny in the CRV would make it finish behind the v6 Escape in the 0-60, but not by much..
lynnekid1: I absolutely love my 02. If I didn't have a wife and kid I would probably be out all night just driving it around. I test drove the 2001 model last year and there really isn't any comparison. I'm not aware of anything you should look out for.
-Rob
Any problems so far?
Overall I'd say if you like Honda cars and want an SUV, you will love it.
Does anyone know if there's a dealer within 5 hours of Columbus that would give me $500+ off sticker?
Also, is the outward visibility a problem for the rear, or all around? Finally, how does the handling compare with your Accord?
Here's what I would do to make it perfect for me:
- re-gear by raising both the final gearing slightly and lowering 5th a bit to get 75 mph down to 3000 rpm and make 1st a little longer
- put in a dead pedal!
- variable intermittent wipers
