Chevy TrailBlazer Loss of power
howdy all. got my 04 TB, 4.2L v6 in 06 with 13k miles, 23k miles now. was a salavage title (insurance mistake) so no warranty
everything worked fine. So few mo later had to replace the battery since it's been sitting for a 3-4month and the stock one slowly went dead on me.
I'm a computer admin with some mechanics experience from working on Ninja 900cc..can do maintenance but not much of a troubleshooter when it comes to cars
I started noticing that once in a while i'd be driving in the range of 20-65m/h and have no power regardless how I push the gas pedal. Engine runs but tranny doesn't get invloved. I'd release the pedal and just roll for a couple of sec and push again and it'd be fine.
well, it's been over a yr now, and i find it doing it almost every time I drive it. it happens when engine is cold and when it's at normal op temp (I'm in Dallas, car warms up very fast). Most of the time it happens on the ramp getting on the highway and speeding up on the hightway but mostly in that range.
I haven't had any warning lights come on or engine lights... starts everytime, even in the winter. I change oil myself every 3,500 (Castrol GTX 5w30 with AcDelco filter). Tranny oil is still from the factory.
so one day it wouldn't pull while going up a steep ramp and tried releasing and pushing the gas pedal as always but the engine just died. I was able to pull over to the shoulder... switched to neutral and SOB started just fine!
I tried scanning the computer, but the scanner can't seem to establish a connection (keeps telling me to plugin the cable).
I'll take the dash apart this week to check if I forgot to connect the OBDII jack back after I run the fog light switch from the dash into fusebox.
Some guys were mentioning bad Neutral gear switch .. can I test that in some way or only a dealer can do that (where is it anyways)? Is it possible that I cause the problem by resting my right hand on the gear selector while driving?
Since the car didn't have warranty I made following upgrades after I got it: replaced the stock stereo with a mp3/USB deck (had to buy special harness with a chip) and installed a pair of fog lights with harness (7A on the same fuse as RPM gage, only I replaced 5A rpm fuse for a splitter with 2 5A fuses)
Thanx so much in advance for any ideas and advice.
Now I started getting engine light during rainy weather .. i think one of the oxygen sensors .. but no idea which one. after i drive for an hour smth must be drying up cause the light goes away
One more thing, do a search of "reduced engine power" in the Ranier, Trailblazer, Envoy forum and see if anything sounds similar.
I've had no major problems since, other than the fact the SES light stays on all the time. Even after being reset. I seriously put black tape over it.
I have 120K miles on it now.
seriously, every time it rained, or I washed my car (underneath and under each wheel well) it seemed to trigger the SES light. I am not sure which sensor they replaced, but know that the engine hesitation and stalling went away. The truck runs great now (outside the sway bar links needing to be replaced again) but the SES light is still on. At this point, it really does not bother me anymore.
What do you want for $30,000, right
This is last american car for me
Thanks again
Try googeling "OnStar can reduce power" and read the reports.
As far as the loss of power, I don't have OnStar system .. and this car never did! I am a very concervative driver, I never floor the pedal or push it pas 2k RPM..
I am taking the vehicle into dealer on Monday to have them test the exhaust O2 sensor. I will have them check for the OnStart stuff........ will keep you posted.
So could it be the transmission? I had been getting on star to pop up in my little window above the steering wheel and I would push the buttons up above and I would hear a message from on star telling me that on star wasn't activated and to activate it I needed to call such and such number. I never have since it's an extra exspense that we can't afford right now.
I'm really frustrated as to what could be the problem.
Could it be from bad gas? The reason I ask is because I had stopped at a BP station in the outskirts of some town I was in.......yeah when I was lost......and before stopping there everything was fine with the trailblazer!!!
I do remember that when I was lost, I had my 21 yr. old son in the vehicle with me. I was trying to get him to an insurance place so he could get insurance on his vehicle and ofcourse I got lost on the way there too, but he was yelling at me and needless to say I was pretty aggravated and I would go really fast a couple of times cause I was so frustrated at him yelling at me and not knowing where the heck I was. But this was way early on, I didn't have any problems at all til after I got the gas at the BP station.
I guess I'm just wantin somebody to tell me that it isn't something serious and if it's just from bad gas then maybe it's a simple problem that I can fix myself.......probably not huh!
But if anyone of you can help me out with this I would appreciate it. I've been reading on here and I'm so upset at all the problems that everyone is having. I've been so happy to have a vehicle, I thought was going to be safe and reliable for me to travel out of state to see my family, which I have a few times since we purchased it, but now I'm just heartbroken. I couldn't even spend any holidays with any of them this year.
So I'll be prayin that somebody can help out on here! Thanks for listening!
P.S. I'm not from this state so that's why I got so lost. :mad:
Is there a certain number of times to turn the on and off key switch on and then will it tell me if there is anything wrong with it by displaying codes?
For those of you considering going foreign, been there done that, good luck. I had a Kia Sorento. We loved the Kia but, it stayed at the dealer almost as much as we drove it. Always for the same problem. Always had to call Korea for permission on the minimum they could do to fix it. The last time it went in they stapled a wire on the transmission, we took it straight to the Chevrolet dealer and traded. At least with my Chevy I get service, don't have to wait on Detroit to make a decision and something always gets replaced not stapled, which at least makes me feel better.
GOOD LUCK TO ALL
My truck first starting having hesitation issues when going up hill @ 35,000 miles. Of course I took in to the dealer they kept it for 3 days and could not find anything wrong or duplicate the issue. They told me it was probably a bad tank of gas. Things were fine...nothing happened until last week. Due to "other" issues I waited to have my 30,000 mile check up done last week. I am currently at 45,000 miles. I went to get in the truck to take it in and the check engine light came on. Not a big deal as I was already on my way to the shop, they did a diagnostic test and it was coming up as a o2 senor issue. The mechanic working on my truck told me what the code was but said that he did not think this was the issue. He did the 30,000 mile check up; the check engine light went off. I picked up the truck and things were fine until the past Tuesday night. I was driving to work...sitting idle at the exit ramp my truck shakes a bit then dies. I cut the engine off, restarted it no more issues on the way to work. That afternoon...same thing happened. Waiting my turn at a stop sign, car dies. Turn it all the way off, restarts with no issues. I drove it home. Wednesday night while turning onto our subdivision street coasting at a low speed the truck looses power again. Called up my mechanic he told me to bring it in right away...just got a call from him stating that GM has a PCM update that will re-calibrate several things from the transmission to the electronic throttle control. I will repost in a few days to let you know if this does correct the hesitation and stalling issues that I have been experiencing.
:surprise:
I have a 05 TB with 60k miles. The problem that I am having is that when the engine is cold I will have power loss and as soon as I take my foot off the gas, the car will die. The engine starts right back up. The check engine light nor does any other service light come on. This problem is very sporadic. I did add some Lucas fuel treatment and we did not experience the problem, but I think it was just luck. This problem happened to my wife this morning. Any ideas???
What exactly did they do to fix your problem? I'm taking mine in tomorrow.
My TB is running like a dream! I'm also getting 18.4 MPG for everyday driving.
As honda's has a electric fan and it cuts on just when the engine is getting hot and it does not lose power. So as you guys drive you all will see you all are going to need trannies im not lying. The techs know but they are told NOT say anything about a defect and they are not going to let them waste all that time on a defect that gm did not fix. So trade out now and take a hit if you can and buy [non-permissible content removed] autos i did i got a honda and 27000 miles later no problems period.
I was towed to my mechanic (does not use computers just listens and looks) who said I need a new motor. I then spoke with another friend who is a mechanic who told me to take it back to the mechanic who did the intake, which I did. They are much more advanced than the first mechanic and have machinery that the car is being tested. So far no information.
Has this happened to anyone? What transpired? What else do I need to know? Thanks in advance!
This is our only vehicle and its been in the shop now for a week with I cant even tell you how much money sunk into it. So far they have changed the cam sensor, the crank sensor, oil change, checked the throttle sensor, and I really dont even know what else.
I have seen so many different things on here that if I had them fix all of them I would be better off just parting out the car! Not really but Im sooo frustrated!
Please please someone help! What can I do? Its been coded and everything that might have come up on the codes has been fixed. Someone suggested the O2 sensor but I have like 3 or 4, and none of them look bad.
I would appreciate any guidance!!
In Mo. Without A Car!
We decided to try and make it home, but the TB was barely given us any power to merge onto the freeway. We decided to pull into a burger joint and have it towed home and not risk any damage or have it break down on the highway somewhere.
From what I noticed, all the guages seemed normal. I did not smell anything unusual as for as gas or oil, plus I did not notice any leaks after we parked it.
When I start it up, it sounds rough, like it is gasping for air or fuel. I can hear a "putt putt" from the muffler and can feel the exhaust coming out in spurts and not a smooth flow. The vehicle was fine on the drive over, not issues, we had the a/c running as well with no issues. Any ideas what it could be? I'm thinking of changing the O2 sensors to see it that helps. We have already had the transmission replaced once about two years ago. Nothing but problems with this vehicle, don't even get me started on the window motors....lol.....all but the drivers side works now, I have replaced it twice already.
Also, does anyone have any issues with the RPM guage not working, it is useless, sometimes it works, but most times it is just all over the place when the engine is(was) running fine. When I rev up, the needle moves up, but does not come back down, the more I rev, the higher it goes until it's pegged out....pos.......lol....take care all......Eli
The RPM gauge is working now, the mechanic said he did not do anything to it, so I'm not sure what the deal is with it.
Eli
Have you had the vehicle diagnosed for the concern? How intermittent in the problem? Can you please e-mail me the VIN of the vehicle? Thank you,
Mariah GM Customer Service
I sometimes still experience some surges but the dealer says that GM tells them this is within their normal limits. They are going to think "normal limits" when this causes someone to die due to an accident.
