Any help is appreciated in advance!
Joe
i had to replace the power outlet thats located in the bottom rear of the center console... instead of just an outlet - had to replace the entire back of the console - everything is integrated...
test mass air flow sensor operation
test air temp sensor operation
check for any leaks/cracks on intake and exhaust manifolds....
I also found the dash lights annoying at night and I also resorted to using the dark blue window film strips to dim the effect. I don't understand why they can't make a more effective dimmer switch.
And just so I know... what is the proper tire pressure for these tires?
You could mention this to your dealer just to put them on notice.
I guess there has to be something.
Of course a holiday weekend and the dealer is closed until Tues. Wonderful. Think the car is safe to drive?
The dealer has put in two radios and it has worked correctly for the last week. The outside temperature gauge has been replaced the dealer says and works correctly about 75% of the time tough once it was off by 23 degrees.`
Is there a different fix for the temperaure gauge?
