Toyota Highlander Tire Pressure Monitor System
I just bought a 2008 Highlander. I'm thrilled with the quality of the vehicle so far. This model has a tire pressure monitor system which I can't seem to reset. I've set the pressure in all tires at 34psi and 44 for the spare, and the indicator light will not go out. I press the reset button and the indicator light never blinks to indicate that a reset is in progress. My dealer can't help. Anybody have a clue?
I have a 2007 and the manual is really not clear about this feature. It took me a long time to just find the switch, the graphic in the manual made absolutely no sense!
I hope this helps.
Prior Highlanders sense low pressure by monitoring the ABS wheel rotation sensors. They do not monitor the spare.
My '05 is indicating low pressure every other week for no apparent reason. A manual check of pressures indicate all within 2 lbs. : (
I just replaced the tires on my 2005 Highlander limited with Goodyear Fortera Triple Treds, 225/65R17. So far I am completely satisifed with the handling and comfort of these tires. However, I am having an issue with the Tire Pressure Monitoring System.
Before I got home the first day, the TPM light appeared. I called the shop that installed the tires (Mr. Tires) and asked if they reset the TPM. They stated that it should have been done but to bring the car back. They rechecked the sensor, the air in the tires and drove it around a bit - no problems. The next day, I began a 200 mile trip. About half way, the light came on. We checked the tires, and there were sitting warm at 37-39psi. The light has remained on the entire duration of the trip.
Upon returning, I contacted the shop again, and they asked me to check the tires cold - he said that the Forteras should be at about 32-34psi and it could be that there is more than a 10% difference between the tires which would trigger the TPM. This morning I checked and three are at 34psi, one is at 33psi.
I cannot locate where the TPM is to try and reset it myself.
Any thoughts on what is happening? And if anyone could please describe where the TPM reset is and how to do this, that would be great!
Reading here, I'm wondering if the problem is that there is no sensor in the spare. Could that be the case? Is there an actual sensor in the wheel? Or is the pressure monitored some other way? Thank you for your help.
Thanks for your help
You can check our MAINTENANCE page--that would probably be helpful!
I need help to find tire pressure light reset button in 2008 Toyota Highlander limited model. I cant seem to find it.
I will really appreciate the help.
This Second Video might be the correct procedure.
An owner's manual is a good thing to have if yours is missing. You can often find them used on AMAZON. I see some for around $30 bucks. eBay might be cheaper.
