I'm curious whether Hyundai upgraded the transmission on the SE and Ltd. to the 6-speed unit used in the Veracruz. The current tranny, although a smooth operating unit, seems (to me) to not take full advantage of the 3.3 engine's capabilities. And with more stringent fuel economy measurement standards taking effect for 08, upgrading to the 6-speed would seem a prudent step to keep the EPA numbers from dropping.
If that's true, i will be very upset. :mad: Dealer told me that this cooler was a transmission oil cooler. I have to tow a folding camping trailer and maybe in a few years a little expendable travel trailer. I really wanted to be able to tow 3500 lbs and 2 differents Hyundai dealers told me there was no problems because the 3.3l is powerfull and there is a transmission oil cooler. Now, if it's not a transmission oil cooler on the passenger side, what is it and what about it? :confuse:
Hmmm ... I think what you are referring to as the A/C condenser is in fact the main radiator. I just looked at my 07 Limited w/ Touring. There is a large black cooling unit on the driver's side just in front of the radiator (clearly visible through the front of the grille). I assume that is the trans cooler, though I didn't have time to trace the lines. On the passenger side is a smaller, silver unit also mounted to the front of the radiator. That unit has silver metal high pressure lines and fittings, which would be consistent with it being part of the A/C system.
Anyone else have this happen?
2024 Ram 1500 Longhorn, 2019 Jeep Wrangler Rubicon, 2019 Ford Mustang GT Premium, 2016 Kia Optima SX, 2000 Pontiac Trans Am WS6
I'm not sure what you're disagreeing with, because I think you just said exactly what I said, i.e., the silver unit on the passenger side just in front of the radiator is the A/C condenser. The black one on the driver side is the trans cooler. As I said, the silver one is right in front of the radiator, and has metal lines with high pressure fittings, which makes me think it is the A/C condenser.
What am I missing?
This is what I'm disagreeing with. The A/C condenser is the part that can be seen just behind the grille. It is usually the same approximate size as the radiator in length and width, but typically not as thick. It is commonly mistaken for a radiator, which I believe is what you may have done. The radiator sits behind the A/C condenser. My occupation has had me in and out of collision repair facilities for the past 13 years so I'm pretty familiar with this.
Look again at the smaller silver unit on the passenger side, which is entirely different than the large silver unit (condenser) that is in front of the radiator. This is the piece in question. Or stated more clearly, it it the 4th unit that we are trying to figure out, now that we know there is a radiator, A/C condenser, and (sometimes) a black transmission cooler.
Still, the small silver condenser does have high pressure fittings that look to me like it is part of the A/C system. My SF is a Touring model with the 3rd row seat, so it may indeed be an auxiliary A/C condenser.
The steering wheel will lock when the steering wheel is moved a little with no key in the ignition. Once locked, the steering wheel needs to be "jiggled" in order for the key to turn in the ignition. (The wheels of the car don't have to be turned "too much" for the ignition to lock, it's steering wheel movement which locks the steering wheel and ignition.)
There is nothing wrong with a car that does this...it is supposed to do this.
While the info in your eBay link looks tempting, beware! A ClearBra installation is definitely NOT a do-it-yourself project. It takes a lot of training and experience to do the job properly. The quality of your end result is hugely dependent on the skill level of your installer. I'm fortunate to have found a great one and the quality of the installations on our cars shows it.
I highly recommend having the ClearBra installed A.S.A.P. after picking up your new car. Check their web site for installers in your area:
klik
If I can be of more help, just say the word.
- Mike
Why would they lock SE and not the limited? To be honest...never liked that feature anyway...Might stop a 6 yr old but that's about it.
If yours doesn't lock, I think something is broken.
Gord
If you are close to your dealer...go to the lot and ask to sit in a few SF's and try locks in them them!
You can also call the NTSA to find out if this is a requirement...I would bet it is! Just MHO
Limited, FWD
Touring Package
$23,780
Out-the-door price $24,716.37 (including taxes, title, processing)
I really was hoping for an AWD but that's $2K more on the base price. Is the price I'm quoted on the Limited FWD with Touring a good one?
Is it worth spending the extra $2K on the AWD when I live in Northern Virginia and don't get much snow? Would the FWD be okay driving through a couple of inches? I don't want to regret not getting it, but don't want to waste money with something not really needed in my area.
Any insight would be much appreciated!
I can't see all this fuss over map lights, my big gripe is day time running lights, I want them.
The Santa Fe is supposed to have a locking steering wheel - this is most interesting.
There is no difference in gas mileage. EPA rating for AWD is 19/24, same as FWD.
http://www.carspace.com/themoonman/Albums/2007_SF_AVIC-D3
There you go.
Um, EPA rating and "real" mileage are generally two different things. The AWD versions weigh more. That fact alone will contribute to worse gas mileage for the AWD versions. How much worse is unknown. I suspect they are about equal highway, but the greater weight will impact mileage a little bit in town.
FWIW, I am averaging 18.2 mpg over 3,200 miles in my '07 Limited AWD with Touring.
Don't buy the Ultimate package. Just buy a Limited and have an aftermarket stereo and speakers installed. The SF uses a standard "Double DIN" size head unit (the part in the dash). For the same price as the "Ultimate" option package, you could get a LOT better head unit and speakers installed by a car stereo shop, or even by Best Buy or Circuit City. You can even get one that plays DVD's right on a 7" screen in your dash, if you like. You could even get in-dash navigation built into it (with something like the Pioneer AVIC-D3), and still spend no more than you would have for the "Ultimate" package from Hyundai.
I have the AVIC-D3 and am glad I went that way.
With my driving habits I'm averaging 22.05 mpg over the past 1900 miles with FWD.
With odometer at 11000km, my Santa Fe 3.3L GL FWD is nimble, comfortable ride in Canadian mtns, snow and summer. Have a personal preference for the gunmetal body colour, side-panel signal lights, pale front & white rear signal lights, darker interior styling, gearbox cell phone pocket, onboard computer and selection of manual transmission and various body styles that are available in Asian market. Also, would have liked middle seat to be shiftable as in Saturn Vue and its seat underspace could have been used for clever storage as in Mercedes A and B classes. However, most notably, would have loved to buy the peppy 253lb-ft (gasoline 3.3L only 226lb-ft!), >50mpg (guilt-free fun! -link title) Diesel Santa Fe CRDi http://www6.autonet.ca/Spotlight/TestDrives/story.cfm?story=/Spotlight/TestDrive- s/2007/05/04/4157303.html - hot buy in Australia, N Zealand, Asia and S Africa (unavailable in N Am ).
Nonetheless, reading some reports on SF gasoline efficiency, even i am impressed by the fuel economy i am measuring at mainly 110km/h driving: last weekend, 8.9L/100km (26.5mpg) and then yesterday, 35L/430km = 8.1L/100km (29mpg)!
Did anyone notice a slight burning smell if you bought your car with less than 50 miles on it? The one I was looking at tonight only had 12 miles on it and I smelled a burning odor when I got out of the car after driving it both times.
The sales guy said it was due to some spray that Hyondai puts on brand new engines to preserve it in case it sits on the lot for awhile. I asked for another car and of course they don't have any more that I want in stock.
The service/parts manager came out to confirm that it's no harm and it's just some sort of spray that will wear off around 100 miles and it happens all the time. But you never know if they are all in cahoots just to get the car off their lot.
Anyone else notice a burning smell that wore off over time? If they say it happens with virtually every new Hyondai SF, I figured someone here could prove them right (or wrong).
For more info, go to post # 2272 in this thread.
Occasionally you'll read about someone still experiencing the burning smell a couple thousand miles down the road and I think those cases involve real problems.
Um, I did state facts, namely that the AWD weighs more than the FWD. All else being equal, a heavier vehicle gets worse gas mileage than a lighter one, for the simple reason that it takes more energy to accelerate the greater mass. The difference is negligible when cruising, where the greater weight means little more than tiny differences in driveline drag, but in acceleration it means a lot. And across the board, the AWD models weigh about 200 pounds more than FWD.
I also noted, as you did, that the EPA figures were the same -- for the 3.3L versions, anyway. The GLS indeed shows the expected difference between AWD and FWD mileage, with the FWD GLS rated at 21/26, and the AWD at 19/25.
The same effect (lower mileage with greater weight, especially around town) happens with options. Those of us with more options on our vehicles, like the Touring or Premium packages, can expect slightly lower mileage than a comparable SF without any options, because the options add weight. EPA tests, by the way, are done on test vehicles with no optional features. Also, carry extra weight in your vehicle will degrade around-town mileage, so a 90 pound girl driving my Santa Fe would observe better mileage than would my 300 pound cousin.
Unless Hyundai somehow figured out a way to suspend the laws of physics, the AWD vehicle will use more fuel than an otherwise identical FWD vehicle. The fact that the EPA ratings are the same tells us that the difference is probably small, which I already noted. It may well be, however, that the EPA test results were 19.483 mpg for the FWD, and 18.507 mpg for the AWD. Since EPA results are only reported to two digits, both would be rounded to 19 mpg. I don't know, but I do know for a fact that heavier vehicles get worse gas mileage than lighter ones.
