All-New 2009 Toyota Matrix
1ZZFE is a high revving engine. Why I can't forget these things I used to own an 07 Matrix and during that break in period I never exceed above 3000rpm. A 60mph(101kph) speed is already at 2900rpm! So please re-check it again.
My 09 Matrix (2ZRFE) revs 3000rpm at 110kph of course in 5th gear, but right now our gasoline are oxigenated that's why the MPG became lower, but still i could get 580k at 45L fill up. The 2.4L engine is a different story, It could consume 20MPG in city driving but this engine is really smooth running like a V6! 2300rpm at 100kph.
This was the wrong time for Toyota to be engineering new models that consumed more gas than the ones they replaced.
I believe the "S", XR in Canada and XRS 2009 consumes more gas than the ones that they replaced.. Maybe this sounds make sense to you.
The 2009 model is rated 26/32. Lower.
R
But I got 09 already.
One of the director of driving television said that this new 09 Matrix is quieter than his older Matrix. One thing I notice is the water splash to the body is noisier than before (when you driving in the rainy weather) Has anyone who notice that??
Cheers.
I own an 08 Matrix and like the car, except for the harsh road noise at highway speed and the equally harsh jittery feeling on rough pavement.
I know that goes w/ the territory of a small car, but I'm wondering whether this has been abated at all in the redesign for 09. when I testdrove the 09 it didn't seem all that much different to me.
so....anyone who's upgraded to the 09 from a previous Matrix: is the new one a smoother ride?
also wondering if there are any mods that might address this.
thanks in advance for any insights!
tm
Usafrosie
Also how does 'direct-injection' assist w/. fuel economy? Any engines from Toyota getting it?
OT - I've read that the Subaru Impreza WRX and STi really need direct injection to alleviate the subpar fuel economy (or lack thereof) those models get....
Direct injection cools the combustion chamber, allowing them to up the compression ratio while continuing to run regular unleaded and boosting low-end torque and fuel economy while reducing emissions.
Just about every Lexus engine has it now that the old 4.7 V-8 is as good as gone - the SC430 and the 4Runner rebadge (GX?) may be exceptions to that.
I would expect the new 2.0 Valvematic engine in Japan to have it, which is why I DON'T expect Toyota to stick it in a U.S.-bound Corolla for a while yet......the Corolla in the States is all about being cheap and durable, not about being at the leading edge of its class in technology.
Check your engine oil level, This is not new, It was posted last year in Toyota Nation Forum. Those 09 Model manufactured in 2008 requires an ECU RE-Flash.
What happened to me was, they did an oil change to my 09 Matrix 1.8L last March this year. My odometer was 22,KM and after that I checked when it reached at 26,K I found out that the oil level was 1mm below center line of the dipstick in just 4,000 kilometers, so I bought a liter of 5W30 and I added up half a liter, and then after 2,000Km the oil level dropped again about 3mm below the max level.
I already booked a service for my car, I will let you know more details after this.
I do not know where that oil goes, It could already been burned.
Is there some reason to think that re-flashing the ECU is the answer?
http://www.toyotapartsstore.com/images/09matrixcargomat.jpg
Also, on page 255 and 257 of the owner's manual, it mentions a tie-down belts and tonneau cover bag. Does Matrix Base comes with these two accessories?
I found two inexpensive rubber-backed rugs from Wal-Mart for the cargo area ~$20.
I don't care about logos.
