Isuzu Trooper Engine and Performance Problems
Hi
I have an isuzu 4jb1 tdi engine fitted on a landrover. Can any one tell me what is its bhp output. Once I had to change the head gasket because it was leaking a little coolant liquid, but after a while coolant is stil leaking again. however it seems that all of a suuden coolant liquid stopped leaking and now oil is leaking. Is this a normal problem. It also blows some oil from the valve cover. would realy appreciate any help pls.
Has anyone else had this problem and actually fixed it?
I am leaning toward replacing the crank shaft and bearings or trying to sell the thing for what ever I can get for it.
It seems to run fine except for the engine sometimes knocking. And a lot of the times when I come to a stop and am slowing down to a stop light or something, it won't idle smooth, it will kind of do a tiny rev a few times until I'm stopped. If I drive for awhile the check engine light usually comes on, then will turn off if I brake and come almost to a stop. The time I did try to take it on the highway, I made it no more than 20 miles out before there were poofs of black smoke coming out of the exhaust, and all the sudden I couldn't maintain speed even with gas pedal down, and I stopped and it was knocking like crazy, doing the little rev thing, and barely run. So of course I turned around and went home. I've never had a problem with it otherwise as far as stalling out or dying or anything. I think it stalled out once at an intersection within a couple months of buying it, but that's it. Never had an issue with in-town driving.
Does this sound like nothing but what that guy told me when I got it, a cracked valve gasket cover? Something else? If you may be able to diagnose it based on what I've set, what sort of cost we talking about for repair? Thanks!
Please let me know if there are more of us out there... no way should an engine blow with that few miles on it after an oil change.
thanks,
MT33
Are the powertrain warrantees (about which such a big deal is made) not transferable?
-mike
Hydraulic lifters normally don't need adjustment...the 2.8 is a GM engine. Isuzu did spec some diff. parts (gasket quality, etc) but main components are the same.
You can actually adjust the lifters on the 2.8 with the engine running, and normally you take the slack out (warm engine) and then tighten the rocker nut a little more.
I can't speak to how much, but if the engine has a lot of miles, then oil pressure may be a little lower and a turn and a half would be about right, but I would not do any more than that, my opinion! While there, inspect each rocker arm where it contacts the valve spring to be sure it is not worn through. Had a couple that wore there too. Usually fairly obvious once you look. Bad heat treat, I think.
good luck
Could it be the ignition coil? i checked them with a multimeter and i read 6.4 k ohm, they are ac delco d555. Its that right? i don't know the exactly value. Could it be a sensor problem?
Thanks in advance.
I have had a few suggestions from friends; catalytic converter?
fuel pump?
It has a GM engine. kidding I love my trooper, it is my 3rd one.
Transmission?
I don't believe that the engine you have is a GM unless someone put it in, as the stock engine in the trooper in 1996 was an Isuzu 3.2 or 3.5...I am not sure when the breakpoint for the difference was. Regardless, it is always best to go back to basics first......your CEL is telling you there is a code set so it should be read. I think you have an OBDll compliant ECM, so getting it read should lead you to the prime suspects. I would definitely change the fuel filter and check the fuel pressure and pump function first, given your symptoms. There is also a filter sock on the pump that could clog, so getting a fuel pressure reading is also important. If you are used to working on cars, you can jumper the fuel pump relay to keep it on so you can verify it is working properly.
Catalytic converters are expensive, and O2 sensors are also important for both emissions and the driveability of the trooper. Your CEL should help there too.
Hope this helps. If you have a different motor, then of course this info may not necessarily apply, but generally should be similar.
Good luck. On guys opinion.
at 65k miles, 5k past 60k powertrain warranty, original engine threw a rod. dealer gave me new short block ($3500 value) and paid for 1/2 labor, with me paying $700 for labor
bought a 2004 4X4 Navigator Ultimate with 39k miles (it came with a premium lincoln extended warranty, 72mo/75k miles) for $23k ($25k out the door). so far, there's been about ~$7-8k in repairs under the warranty
Question: What did you do about your trooper. We have a 99 trooper and we have been adding oil every week. No leaks.
I am trying to figure out what it is and how to fix it.
Sure, we could, but that would deprive our other members of valuable information and defeat the purpose of the Forums. Best to keep the conversation here.
SUVs and Smart Shopper
from reading other messages it seems this could of been from low oil, apprently there aremany people writing posts saying they are having to put oil in every 1000 miles which is ridiculous but none the less very well could be the problem. i had the oil changed 2000 miles prior to it going out and they said it was due to low oil.
So get it checked out.
Now i was wondering if u did change the engine already and if u could give me a good price on which you paid for it and labor or the estimates you got.
