If you have, please reply to pr@edmunds.com no later than Tuesday, September 27, 2005 with your daytime contact information and a brief description of your recent crossover/sport wagon purchase experience.
MODERATOR /ADMINISTRATOR
Review your vehicle
Have not heard of any problems with the VUE so far. Saturn quality at Spring Hill is pretty good.
Around town we get 18-19 which is really pretty decent. The tag said 20 for city and 28 for the highway.
You don't spend thousands of $'s to save a few hundred $'s / year.
It's time to change tires on our Saturn VUE, and I'm seeing that the choices are limited with the stock P235/65R16 101S M&S type.
So I'm wondering if I can go with P215/70R16's? There are a lot more and better choices in that size.
Has anybody on here switched to the 215/70 tires on their AWD VUE's?
You're probably already aware of this, but the Pxxx number is the width of the tire tread in millimeters and the /xx is the ratio of sidewall height to width.
So in the stock P235/65R16 case, you have a sidewall height of 235 * 0.65 = 152.75 millimeters (approx. 6 inches)
To get the closest varient in the 70-series tire, take 152.75 and divide by your new ratio (0.70):
152.75 / 0.70 = 218.21 millimeters.
Of course, we know that 218 is not a traditional tire size, but 215 is (as you've already noted).
Overall, the P215/70R16 will be approximately [2*(218.21-215)] = 6.42 millimeters shorter than the stock tire. (Remember to multiply by 2 since sidewall height appears twice in the height of the tire.) That's a meer 1/4 inch shorter than the stock tire, or a sidewall height difference of roughly 1/8 inch.
Basically, the trade-offs will be that your speedometer will read a tiny bit fast which will make your percieved fuel mileage "appear" to go up a fraction, and the tread width will be about 3/4 inch narrower than the P235/65R16 tires.
My guess is that a worn P235/65R16 will have about the same residual height (now that the tread is wore down) as a new P215/70R16.
Mathmatically, I don't see a reason why you COULDN'T switch to a P215/70R16 (given the trade-offs I've mentioned), but I haven't done it myself so I can't speak to whether or not it is valid solution.
But don't take my word for it. Double check my math and do your own research to verify my humble claims.
For what it's worth, now that I've completed this math exercise, I will definitely consider replacing my stock VUE tires with the P215/70R16s if this tire size is more cost-effective than the stock P235/65R16 tires...
Either you have the wrong information, or I've been living in a cave. That 3.4 V6 you mentioned...built in China? I'll have to check that one out. it's been a GM staple for years. One of their better engines. I have one in my 2001 Olds Silhouette and get close to 30 MPG hiway; of course that's under ideal conditions. The worse I ever got was 23. It's a sweet motor.
Haven't heard of the Torrent.
Cheers,
Larry
I have filled up almost every time below the 1/4 and I have only used 10-12 gallons max. 16.5 gallon tank
I have had both fuel tank sensors replaced so i am thinking a mis calibrated fuel gauge.
I am ready to call in the "lemon law"
My gas gauge does a nose dive after I get below 1/4 tank. I haven't figured out if it is a mis-calibrated gauge or if my VUE starts sucking gas like crazy, but either way I usually just fill up when I get down below 1/4. I can now get 300 miles out of a tank, which sucks overall but is an improvement over when we first bought it new.
Please report back on what you find out and/or what Saturn does for you if you contact them. Thanks.
I just traded in the ION for a used 2005 VUE (2.2L - 4cyl - 5-speed manual) from our local Saturn dealer. We wanted this car immediately after the test drive - it only has 11,000 miles on it, it was a great price, and we just loved how the vehicle felt and handled.
We bought it last week - and so far - we are relatively happy. But - we are experiencing one problem - and I was wondering if anyone has encountered this:
Over the last few days a slight "knocking" noise is coming from the engine when idling (mainly after the engine has been running for at least 5 minutes). We can only hear the knocking sound in the cabin of the car - and I can't hear it when standing outside of the car, even when listening to the engine with the hood up or listening from underneath the vehicle. The knocking is not extremely loud - but it is noticeable.
We took it to Saturn twice (since it is still under warranty) - and the first time, the technician said he couldn't hear the knocking sound. Today, the technician did hear something, and made some adjustment to the engine - but the sound is still there. I brought it back again later this afternoon, and we were told that the knocking sound is normal for all VUE's when they are idling.
Has anyone else experienced this? Thanks so much for the help - any advice or guidance is really appreciated!
We have the same knocking problem. We just went to the garage last week and we were also told that the knocking sound is normal???? We are not very satisfied with this. They told us that we were not the only one complaining about it.
I drove our VUE yesterday and last night, and did not observe any noticeable knocking sound within the cabin at idle or under normal driving conditions. I will be on the look-out for it now though.
Just out of curiosity, how often do you all change the oil in your VUEs (especially the ones that are knocking)? I thought I read in the owner's manual that the 2004 VUE has a "oil change light" that will illuminate when the oil gets dirty, but I don't trust it so I have mine changed every 4K-5K miles no matter what.
16 days ago traded in my Black/Tan Cloth 2003 AWD 4-cyl VUE for a 2006 Bremuda Green/Grey Cloth AWD LT Equinox with Power Sunroof, 6-Cd changer & Side Airbags. I was sad to see the VUE go
Happy Holidays!
So far I have driven it about 400 miles and just love it. The Honda V6 was the big selling point for me. I am averaging just under 25 mpg which I consider to be excellent for this type of vehicle.
Now my question. I have a rather loud noise coming from the front end. It sounds like rubber rubbing together and only happens on road imperfections during slow speeds (like going over speed bumps for example). Its still under the factory warranty so it will be going to the dealer next week. I am just curious as to what it could be.
I just purchased a 2005 Saturn Vue FWD this past summer, I have just started noticing the knocking sound (which sounds like it's coming from the back) this winter. I have had my oil changed every 3500 miles. I was going to call Saturn and see what they say about the problem. I have seen on MSN.com another Saturn Vue owner has had the same problem. It's unfortunate, the car otherwise is wonderful.
we just drove from Kentucky to Massachusetts over the holidays - and the VUE was awesome. With 4 passengers and a loaded trunk-space, we got 27 mpg and the car handled awesome!
But - we still hear this annoying knocking sound when the vehicle is idling - and I agree - it is coming from the back somewhere. I had our VUE in the shop 4 times last month for this problem - and the last time they replaced something called a purge solenoid in the back of the vehicle (I probably spelled solenoid wrong - sorry if I did). It sounded better for a week - but the knocking returned, louder than ever. This leads me to belive that my service department doesn't have a clue what the problem is - or it is something major and they don't want to fix it.
We're stuck - we can't sell the car or trade it in without taking a huge financial hit - so if you hear of anything that might rectify the problem, please post a response. I will keep monitoring this board - and if I get the problem resolved - I'll also post what they did to fix the problem.
I doubt that's it. Dealers make a lot of money off of billing for warranty labor hours. If you find the cause, please let us know!
Stay tuned VUE fans.
Not bad.. government rebates would help. I think the US has them, nothing here in Canada.
Now, someone driving 20,000 miles a year would be another story...
Being a newbie I decided on the VUE due in part to what I read here. Realizing I would see more negative than positive. You can call it a discussion forum, but these things always so dings more than props. Anyway I read and studied and realized I had other choices. I called several dealerships and spoke anonymously to service managers and even some sales folks. All who seemed to own a VUE. That told me something. So here I was trying to decide between a CVR and the VUE. I called the Honda dealer up and asked for someone in sales... They must be selling crate loads of these things and didn't need to sell me one. So I opted for the great deal (or so I think) on the VUE.
Here are the stats: 2005 | 4cyl | 5 speed | Sun roof | Roof Rack option | PS | PB | PW | CD | 6 Speakers, basically loaded w/4,000 miles on it. Price $15,999 Dealer listed it for $19,999. Was it a baited price? Probably. But that's about what I paid for my 2 year old Camry in 1998. So, I was thinking better about the deal. Obviously it's too early to tell if I'll have thumping in the rear or steering wheel rub or clutch problems. But the price over everything else made it seem like a pretty good deal to me.
I was a repeat customer at the dealership, and the first car they sold me was not a Saturn. So they hooked me on good service to begin with. This experience was no different. My story will obviously unfold. So far, so good. Looking to get between 26 and 28 MPG will take a mid range trip this weekend to be sure.
If there are any hints of things to do or ensure the dealership takes care of before my 3 year 36K mile warrantee runs out, I'd appreciate the feedback. Thanks, Jeff Leitner
