They called Acura in CA a few times, Acura first offering to pay 75% then a few days later to pay 90%. We took that offer.
Acura will pay for some costs. Make the dealer call Acura in CA. Tell them that you know these transmissions are defective. Report them to the Better Busness Bureau if they won't reduce the charges. Print out some of these blogs for documentation.
PS...your new Acura transmission will have a 3yr./36 month warranty. Use it up, then buy a Ford. That's what we'll do.
John
Michael
Michael
My Acura dealer has never found the problem, as it doesn't happen when the employee test the vehicle.
I have had the transmission repaired three times since then (by an Honda certified mechanic). That fix the problem for a day or two and then it starts to slip again.
Any ideas how to fix the problem?
The dealer just called and offered 80% off of the total service. That's $1200 plus tax. It is much better than $5000, so I took it.
He first called yesterday afternoon and offered $1800, and I told him the information I got from John, but he asked me to offer the record of the proper maintenance, which I don't have. I insisted that the problem is their defective transmission which is even on the Wiki("The 2003 - 2006 models transmissions have so far shown the same failure rates and costs thousands to repair".) and I would complain if they don't offer better number.
I think it's their stratagem to budge a little bit every time until you get tired and give up. If anybody has the same situation, just remember to argue with them. The information from this website sure can help.
I hope Acura could be honest with their products and recall the defective parts as soon as possible before any tragedy happens. Again, I will never buy another car from Acura in the future. I just paid $1200 tuition to learn that.
I have a 2002 MDX, which also got its trasmission problem. I have just 70K miles on it
Acura dealer came up with a price of $5000 in Houston Texas.
They agreed to pay 50% of the cost.
How can i make them to offer me more.
anand
I have the same problem, It's at dealer now replacing torque converter and transmission. Did it fix your problem, very curious to know if this is the solution. I had my car 2months when it started acting up so after 8 months of owning car its back in for 2nd torque and a new transmission.let me know how yours is acting.
Check light went on
D5 light started blinking
at 15, 25, 35 or so, 45 or so, and 60 mph the car would not consistently kick into gear - the engine would rev up in rpms - I would ease off gas and then gear would engage often with a lurch
Took to a gas station off the highway and they diagnosed with error code P1750
in dealer right now
worried that I am looking at a transmission job on a car worth at most $10K - where the job could cost up to $5600.
Thoughts please?
As far as the steering wheel shaking, could be that they did not re-align the front end properly and just needs to be adjusted. Also something as simple as a balancing weight on a front wheel may have fallen off when they removed the transmission. Nothing major on either scenario.
Good Luck !!!!
Ah, finally, someone who got a good one!
Get into it your 100% in the right and never mind about warrenties, its their problem all the way. Good Luck
1. Open a case file with Honda America at 1-800-382-2238 then press 5.
2. Mention that you have researched this issue on the internet and that their are a large number of reports of this very same problem with both Honda Pilots and Acura MDXs. Also state that the nhtsa.gov complaint site has 29 complaints of which 14 are for transmission and 11 are for the 30-40 mph grinding/vibration issue for the 2005 Acura MDX.
3. They may offer to pay 50-75%, but continue to press the issue and ask for a district manager to review your case. Also, if that does not work, ask what the next level of appeal is and state that you want to take your complaint to the next level.
Unfortunately, you basically have to "wear them down". If all else fails, state that you are considering initiating a "class action law suit" given the large number of complaints you have read for this very specific problem. In almost all cases, the fix is to replace the transmission torque converter.
Good luck!
Nearly 3 years back I started this thread on my concerns on my 2004 Acura MDX vehicle. It currently has 85 k miles, but I am worried that my car's tranny might soon go out like many other MDX's. I already knew of the recall of affected MDX transmissions, but only from 2001-2003 year ranges. But from this thread now, I can easily conclude that this is a bigger problem. I am seeing from what I read that there are some 2005's and 2006's with the same tranny problem...but curiously, if I am not mistaken, no 2004's? So from the years 2001-2006 (first gen MDX's) , all the years except 2004 are affected??? Its too confusing...because in my understanding, all these first gen MDX's use basically the same 5 speed automatic transmission!
good luck yaar
Unless there is a class action suit, the only fix is to trade it in for another vehicle.
That's what I did when it started for a third time. Get rid of it before it materializes to a regular basis again.
http://www-odi.nhtsa.dot.gov/index.cfm
Also, the NHTSA has issued a "service bulletin" for this exact same problem for all Acura's for model years 2003-2004. To view the service bulletin, go to the following web site:
http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm
Enter NHTSA item# 10022468 in the "quick search" box. Once you get the record, click "get summary" and you will see the exact explanation as follows:
"Torque converter shudder or vibration between 35-40 mph"
This is exactly the same problem that is so prevalent with the 2005 and on Acura MDX and Honda Pilots. Do not understand why a service bulletin has not been issued for more recent model years???????
