Ford Escape 4x4 Help
4 wheel doesn't seem to be engaging when it should....got stuck in a few inches of snow. it's an 05 xlt with the 6. the 4x4 light on the dash didn't come on until i was finally out of the snow...took much forward and back.
Have to wait for the next snow and then I will ride along with the better half.
New here and need help. I have a 01 Escape and it is up for the annual smog check. I drove it down to the station and he said he could not pass it. He said that there were issues with the accelerator. He could not get it to go up in small increments. He said he did not know what is wrong with it. This vehicle has been a pain in the [non-permissible content removed]. It has 82k on it. I replaced the tranny at 65k, brake master, power booster, front rotors twice, and rear shocks twice. The transmission is starting to slip again. It was on a 12k 1 year warranty. I have a crap manual that does not give the details I need. I could use suggestions or a rout of trouble shooting, say from pedal to ? I have always tried to maintain my vehicles. This one is the last Ford I will every buy.
Thanks for any and all help
Moose
I don't know if this will help you, but my wife's 2004 Escape Limited 4WD V6 Auto had a recall performed back on February 2005 under Recall# 04S25 in which the Accelerator Cable was replaced because of sticking, sort of like what you described. The part# the installed was 5L8Z-9A758-AA
Moose
My husband and I are military and will be based in Minot, ND. We have been doing alot of research and test driving small-midsize SUVs. So far, our first choice is an Escape XLT with 4WD. However, I want to know if anyone has had problems with the reliability of their Escapes? I had a terrible experience with my previous Ford, a 2003 Ford Focus ZTS. I just had to have a rebuilt transmission put in it 6 months ago with 91,000 miles on the car. I've also had problems with my alternator/battery, due to inexperienced Ford mechanics. However, I am willing to put this negativity aside if I can get some positive feedback about the Escape. This will be our first SUV and we think this vehicle suits our needs the best (i.e. driving in snow, towing, hauling/moving things, etc.). Also, I just read in a previous post about the engines in Escapes stalling? That is a major concern to me and if I am getting myself into a trap, please let me know now versus after I purchase an Escape. Many Thanks!!!!
SUVs and Smart Shopper
I own a 2002 Ford Escape V6 XLT Sport. Bought it new in November, 2002. Present odometer is 151,850 miles. The vehicle has spent five Winters in Michigan, and two in Florida. Very little trailer towing (snowmobiles) and no off-roading activity.
Ownership has been mostly routine, with Lincoln/Mercury/Ford dealers performing most maintenance. The only service I did was to convert to an Amsoil program in 07-09. Back on Motocraft full synthetic, now that isn't driven 30K miles per year.
The Duretec V6 runs very well, and uses no oil.
My only mechanical (non-warranty) failure has been the power takeoff, which was replaced last week. The dealer gave me a discount on the unit, but the bill was still $1,860.
It will remain our primary driver through 2011, and then my daily "beater" until eternity.
The only surface deterioration has been underneath the optional step/running board brackets. I cleaned those up and repainted them last Summer.
I've been with Ford since early 1992, and have experienced one unpleasant service call. The rest of the dealers have been very helpful and courteous. Of course, it didn't hurt to live in Michigan, which has more Ford dealers than any other state! This is our fourth Ford/Mazda vehicle; the others being a 07 Lincoln MKZ (lease), and two 1997 Mercury Tracers. I drove the Mercs to 150K miles before I sold them.
it. The only time it has been in the shop has been for oil changes
and tire replacements (normal things.) It has 80,000 miles on it and
I still love to drive it. We just purchased a 2010 Escape Limited and
so far I love it as much as I do the other one. We have always had
very good luck with Ford products and have not had any major
problems with any of them. We live in snow country also, and even
the local police officer says that I have the best vehicle in the
parking lot. We love our Escapes!
We have an '04 that lit up the air bag light 3 flashes - pause - 7 flashes.
Did a search to find out what it meant. Came back as right front seat wiring harness.
You might get some info trying that.
You can try searching ford parts dot com to see if you can find out what part it is and list price.
2005 AWD V6 Auto
Ok, I have 4x4 issues... the dashboard 4x4 light is flashing and front wheels only spinning... I have replaced the toner rings on the cv shafts and still nothing... is there something more to this?
I have same problem. For the first few winters of my 2007 Escape, I felt the 4WD was very capable. I could drive around in 6 inches of snow and not worry about getting stuck. Due to an unrelated powertrain issue, the rear 4WD was swapped out (unnecessarily it turns out). The next winter, at the slightest wheel slip on snow, the 4WD light comes on steady, and if you persist a bit with wheel slip, the 4WD light begins to blink. Trust me, it is NOT overheating. It blinks for 5 minutes of running and then resets. The repair then was to replace the LF tone ring, and I was told to trust them, this was the problem. Well, we didn't have any more snow for 10 months (and hence no test), and once again, with the first snow and at the slightest wheel slip the light comes on. Essentially, there is no 4WD and without it, the Escape is useless in snow. I had it in the shop mid December 2013, and was told that it was fixed by replacing the 4WD electronics module located under the console. However, at the very next snow after Xmas, the light came on in exactly the same manner. Service appointment at 7am this morning, but I am losing confidence.
Mine turned out to be a broken PTU (transfer case). You can determine this by being able to turn the driveshaft when the transmission is in Park and the vehicle on a hoist.
