1. Thanks to previous post, I did locate the oil filter canister next to the dipstick. It requires a 24mm socket (which I had to purchase as I did not have one that big).
2. Thanks to post on another site, I was informed to look for a plastic cowling at the bottom of the car that covers up the oil pan (and some other things).
3. I removed the cowling (4 10mm screws), located the oil pan (plug is 15mm) toward the midpoint of the vehicle. I drained the oil.
4. I removed the oil filter canister and placed the new one in. It snaps onto the pin on one end of the canister.
5. I replaced the oil plug and after attempting to put the cowling on backwards (which did not work) turned it around and it actually lined up pretty easily. I re-applied the 10mm screws.
6. I poured in 6 quarts of synthetic 5W30 oil in spout.
7. I reset the oil life indicator by way of page 5-22 and 3-51 in owner’s manual. Press info button on dash until oil life display comes up then hold set/reset button more than 5 seconds.
8. Done
BTW, I finally got around to changing my oil at 4,291. My sensor said 68% oil remaining. So extrapolating that means that based solely on mileage the sensor would prompt up to change oil around 13,409 miles. That sounds long, so it will be my next question to my service department.
http://www.gm.com/corporate/responsibility/environment/maintenance/simplified_ma- - intenance_040104.jsp
here is the GM site with all the details
The 25% is the level on the GMOL that generally change my oil at....
But we were looking at a 08 cts di with both lux 1 and 2 for for the kbb price you have listed for the 09.
So to me personally if I were making an offer on that car, verify that it has not been titled and offer them $39,500 Remember new or not the car was at very least a demo and price needs to be reflective of that.
I know that some dealers must still be sitting on 08's and if you're not concerened about the year, the deals on on 08 should be significant. But if not at least stick with the kbb price and shop around and you will find a dealer who will be at that price if offered. But talk to the dealer and treat the car as anything more than a discounted demo and see what you get.
What is the sticker price on the car?
joe
i took the car back and they did not even drive it. they knew what was wrong. they advised me there was a service notice out on this problem and they fixed it.
joey000245
jensen beach, fl.
joe
I am not discounting the service bulletin, BUT I had a similar noise. After a lot of investigation (by me), I discovered the battery cable was hitting its enclosure. A small piece of self stick foam insulation at the point of contact solved the problem.
The noise is easily reproduced by tapping on the grill over the sub-woofer.
Has anybody seen this on their car, and known what fixed it? Thanks.
CTS09- AWD - 304HP, performance package - The Black gas hog!
I use the iPhone app Gas Cubby to track my mileage and note fill ups and MPG's. I've tried different gas stations, different octanes, etc. with no real difference. I think it's a sharp car and have had lots of complements on it.
Oh well,.... To quote Fernando "It's better to look good than to feel good", -
Cadillac has been useless on this. I get a what do you expect look. ;(
17MPG city - Not even close...
I bought the car to drive it and not fret over every mile. I've excepted it....
My wife is looking for a new Crossover, SRX? sharp!, but the gas issue is pushing us to look elsewhere.
I think your stop and go Boston traffic coupled with the DI and AWD are your cause........Im quite happy with the smaller engine, less HP.....but do have the FE2 suspension.....which I love......like many have said..the EPA estimate is just that and not gospel.....unfortunately it seems you are on the lower end of the spectrum....
I didn't think this config would have made such a difference. 200 miles per fill up. eeek.
I've heard others report mileage close to yours and it drives me crazy. 23 city... WOW! I'd be happy with 15 MPG. My concern was that my CTS had a problem. I'm still not sure if it is a problem. I haven't heard anybody report MPG's as low as mine. Anybody in Beantown with a CTS09 DI304 AWD? Whatcha gettin'?
Anyway, SRX? Sharp! Maybe they'll let us drive it for a week to check it out. maybe not.
Oh well. thx
