2007 Chevrolet Cobalt
navyyeoman
Member Posts: 4
in Chevrolet
Nice car, however, when I go to accelerate to increase speed or to pass a car, the car hesitates a few times then picks up speed.
Has anyone had this problem? Let me know. Thanks.
Clark
Joel
Appears as though the problem is resolved.
Joel
Might want to try your luck at the dealer. Took less than a hour for me.
You may need a resistor for each taillight to slow down the flashing, instead of a flasher.
I am from GM Customer Service. I apologize that you are experiencing and issue with your vehicle. Can you please email me with more information about your situation so that I can look into your situation further? You can get my email by clicking on my name. Thank you,
Mariah GM Customer Service
I apologize that you are experiencing a concern on your vehicle. Have you taken the vehicle to another GM dealership for a second opinion? Thank you,
So, to summarize:
annoying turn signal click doesn't click
ding when the keys are in the ignition when the door opens doesn't ding
driver's door speaker does not work
this intermittent although it is becoming more permanent
Any help would be greatly appreciated! Thanks
Josh
I apologize that you are experiencing concerns with your vehicle. Have you taken the vehicle in to be diagnosed? How long has the concerns been present? Thank you,
This is what I've gathered so far. The signal makes noise, the door makes noise and the speaker makes noise. Now when the signal and the door do not make noise the speaker is also silent which leads me to believe that all of the noise could possible come from the driver side speaker. There may just be a loose wire on the speaker inside the dash. I will check there for now and I look forward to any other suggestions.
Anyway, replaced the speaker with one I got from the dealership and all is well. 1st I suggest swapping the speaker with the one on the passenger side to make sure the speaker itself is actually the issue. I swapped them and the speaker was definitely dead. Hope this helps you out.
Have you had the chance to take your vehicle to the dealership to be diagnosed?
Thank you,
Caron, GM Customer Service
I would encourage you to have the vehicle diagnosed by your local GM dealership. Please keep us posted on any information from the diagnosis.
Thank you,
I believe it will be the driver side speaker. Dampness may have gotten in the speaker or the cone on the speaker has gone bad. I replaced the speaker and have not had any issue since. If you have any other issue just let me know. I have had some great help with this site and had all issues fixed to date. :shades:
The door panel has a heavy plastic sheet between it and the metal door. That sheet is glued to the metal with a heavy black mastic. IT ages and doesn't seal well in spots or it has been pulled away for service and then put back when it has aged and lost its tackiness.
The glue lines are shaped at the bottom so that water on the metal side is directed into 3 holes that let it drain back through the metal and then out the drain holes in the bottom of the door. Usually the water is seeping past the mastic at the V-point.
The solution is fresh black goopy sticky stuff from a supply place for auto shops and a new line of mastic on the plastic.
Here's a link to a write up with pictures about the H-body door setup. Good luck finding your source.
I have not had the time to really check into this matter,but glad I found this post.Has been a pretty good car for the most part.
