Isuzu Rodeo No Start Stall Idle Problems
                    howdy.  the 2.3 engine in my 91 isuzu stalls and idles bad.  iam the original owner and have over 177,000 miles on her.  i have just recently replaced the spark plugs & spark plug wires, coil and fuel filter trying to fix this.  prior to this problem she ran fine (perfect).  less than a year ago i had stalling issues and replaced the distributor cap and rotor along with the fuel filter and ignition coil.  i have also just cleaned the EGR valve (dirty) trying to fix this problem.  im holding off on buying parts that will not fix the problem.  any advise that helps is welcomed.  thanks in advance.
SUVs and Smart Shopper
1. I have tried jump starting - that did not work
2. All lights - both interior and exterior work w/out having to be connected to jumper cables
3. The vehilce was completely out of oil when I checked. Took 4 quarts to almost fill
4. I don't think it is the battery or alternator.
5. The only thing I can think of is:
a. The starter is bad
b. He drove the thing dry for too long and locked up the engine.
Any suggestions? Agree or disagree?
Vehicle has leaked a lot of oil since I got it home two nights ago.
DJ
Of course. So we can now rule that out.
