I took my Camry in a few times for that garnish and just gave up. Out of the millions of Camrys on the road I have to be satisfied with one which has the same level of QC as an 80s era GM
There is no fix. Simply put the dashboard and the garnish do not line up. Depending on how much skill (or effort they're willing to use) the technician has you'll end up with something that's not as noticeable to something horribly ugly.
My AC fan has a rattle, my driver's side seat belt squeaks and rattles..this isn't why I paid a premium for the toyota logo
My mileage puts me over standard warranty and I didn't go for extended warranty for a few reasons, one being Toyota's quality and my history with past cars. I was definitely spoiled by my 1999 Lexus SUV which didn't incur any significant repair costs until it was well over 150k...just a heads up for Camry owners...something to potentially watch for.
When you park your car the brakes will be warmer than ambient temps. When they cool down you will get condensation and then getting a rust imprint of your brake pads on your brake rotors. Does the noise go away when you apply your brakes a few times?
Check with your warranty booklet. I think the water pump is covered under the powertrain warranty which is up to 60k miles and/or 60 months. You might get a refund if you already had it repaired somewhere else.
"slingshot effect" or, being bumped from behind, feeling, results.
Then unless you apply pressure to the gas pedal shortly before coming to a full stop the transaxle will delay the shift into 1st until the car has come to a full and complete stop.
Strange new world....
so is this the problem of the keyless receiver? can I fix it DIY? thanks!
Water pump seals ALWAYS "seep", but even if an actual failure it would be hard for coolant to compromise the crank position sensor, acid maybe.
Whoever changed your oil forgot to reset the maintenace required light - if you want to do it yourself, your owner's manual tells you how - VERY easy.
Check engine light - you need to get the codes read (Advanced Auto does for free). Typically, it is an emissions problem or fuel cap loose or fuel cap gasket not sealing. Nothing really serious, unless you have to have your emissions checked for getting your car registration, because then you cannot have a check engine light on.
My son recently had an accident driver side and frontal impact where neither the driver side or the side air bags deployed; therefore, he sustained serious head and face injuries.
We have owned toyotas for many years and are very pleased with their performance; however, in this particular time, it did not live up to the safety measures we expect.
Does anyone else know of an incident similar to this one and if there is a recall on this model and year? I looked and couldn't find anything.
RMS
