Nissan Xterra Manual Transmission Problems
My 2006 X needs a new clutch, they say, at 23000 miles. No excessive driving habits. No fluid leakage detected upon visual inspection. What's up with that?
the dealer said that the cost for the replacement of the clutch is $1700 and not under warranty.
i just have a had time believing that i have driven so terrible to have to repace the clutch. I've been driving for over 15 years manual cars and never had this issue.
i just feel at the mercy of the dealer since they told me that they had never had a nissan xtrerra with a clutch issue....WTF :confuse: :mad:
no city driving,
no hauling,
over 10 years experience driving xterra manual trans.
over 35 years experience driving manual trans
and nissan wont pay for new clutch -- not even a dime!!!
needless to say, i will never buy a nissan again.
Does anyone know of any quality aftermarket clutches for these trucks?
I bought my 2006 Xterra new in March 2006 and have done over 70% highway driving. The truck currently has 43,000 miles. As most of you know the mileage is well below stated on the sticker. I drive 75 mph and am lucky to get 16 mpg. I don't do any off-roading and have only towed with it once while moving.
The steering column was replaced under warrantee during the first year.
I have dutifully completed oil changes and use synthetic oil. I have been driving a stick since 1985. I have not had the dealer complete the scheduled maint but was planning on it since I have owned it for 3 years without changing the rear end fluids.
I noticed the engine over-reving slightly during shifts last week and took it to a local Nissan dealer.
Once I found out that the vehicle was no longer covered under warrantee I took it to a local repair shop that does work on mostly foreign late model autos. He is a friend of mine and I have used his shop for over 12 years on Saabs, BMWs, Volvos, and Toyotas with excellent results.
The total bill came to $3,300. I'm sure the dealer bill would have been closer to $5000.
The $3,300 bill included:
Clutch replacement at 43,000 miles
Here lies the problem!!! Nissan uses a $160 clutch disc in a vehicle that makes 260 hp. I'm no engineer...but this doesn't seem like a good place to skimp.
They used to install beefy clutches in their high HP vehicles. My 1984 300zx turbo clutch lasted close to 100k.
Flywheel replacement ($800 part...surprisingly in stock at a local dealer the part was torn up pretty bad)
My repair shop said it was unusual to find a part like this in stock!!!!!
30,000 mile service (the fluids and filters were close to $400)
New battery...Too early in my opinion.
Wiper blades
Mass Inspection
total parts: $1454
Labor: $1768
Should I cut my losses and trade this puppy in now while I can get a good deal while the dealers are hurtin? Any suggestions?
Thanks for your advice.
Coach877
I'm wondering too if the clutch master cylinder set up might be a partial culprit. The 4.0L 6-Speed (only) clutch master cylinder assembly should be adjusted to a length of 120.5mm (4.74") from the hole in the clevis (where it attaches to the pedal) to the mounting surface plate of the assembly (engine side of firewall). Ya pretty much have to remove the thing to measure the set up.
My clutch master cylinder squeaked and after FOUR trips to the Dealer, they finally replaced it ..... and didn't adjust it properly before installing it. Fortunately it's set so that the travel is slightly beyond where it should be, but if it were adjusted short, I wonder if clutch slippage might occur? This being a hydraulic clutch, it's hard to say. I'm no Engineer.
Prices are $450 for the Flywheel and $485 for the Clutch Disk.
Jim Wolf Technology VQ-40 Stuff
I do not own these; I've had no trouble with my Frontier as yet, but I have only 20,000 Miles on it. I am very happy to see that there's now an alternative out there if I do have trouble.
Have you had any luck with Nissan? I am waiting to hear back from a regional manager regarding having this repaired at no cost to me. Does not sound positive though.
I am very interested in joining the fight and possibly even a class action suit if this is not taken care of by Nissan.
A regional manager is supposed to call me back after he researches with his engineering department before he can answer me if the repair will be covered under Nissan.
If anyone has an idea on how to reach a decision maker in Nissan this would be a start. Or if there is someone out their willing to lead a class action lawsuit I would certainly join. This website is likely just a small percent of owners with this problem who happened to find it, and 6-speed Xterras are a small percent of sales. Does the pickup also have the same Z-based 6-speed/clutch, or the stronger 5-speed clutch? I still feel the Z-based clutch is not designed for the much heavier Xterra and this is the root of the problem.
I've appreciated the inputs from others on beefier aftermarket clutches, and wonder why Nissan's premature clutch failure repair includes installing the same weak factory parts.
I brought it to a respected mechanic in town and after looking at it agreed that the clutch is not built for a 6 speed, high HP vehicle. The flywheel was also damaged and needs to be replaced. I am supposed to be able to pick it up this afternoon.
But here is my suggestion to everyone;
Go to the Nissan website, click on the Warranty tab, and send an email explaining your problem. A regional manager should be assigned to you and contact you directly. You have to have a "file number" before anyone will return your calls. You should receive the file number in your email confirmation. Hopefully if they receive enough of our complaints they have to document it and rectify this problem.
My plan is to sell it, trade it in and get a totally different vehicle. It is very unfortunate because this is my third Nissan and did like the Xterra very much. But since they will not even consider stepping up to the plate to help a loyal customer, I am ready to contact the local news station also and have the Consumer Guru go after them! Good luck to everyone and if anyone ever hears good news, please let us all know!
Now they have to call nissan tech support and talk with them, which is sounding a little better than oh go buy a clutch and pay us to put it in, the saga continues. FYI, my lawyer friend mentioned that if they do refuse to warranty it to file a complaint with the state Attorney General, she said she has never had a warranty claim not be honored after the AG's office makes a phone call, hopefully it won't get to that point, we shall see.
You mention some do not have this premature clutch failure. Do you know of a 2006 or later Xterra (with the 6-speed Z-based trans) clutch lasting more miles than the 20-30k typical? All my other car and truck clutches typically last 150k plus, but none are Nissans. The X is also rated for 6k lb towing, and I can imagine the clutch would fail even earlier if used for towing per the factory rating.
Bottom line is it appears to me that Nissan used a passenger car clutch design (because of the Z transmission they adapted to the X) in a much heavier truck, and didn't bother to do reliability testing in the X. Maybe this is the Renault ownership influence.
I'll have to get a sense of take up on my truck. I've never thought much about it until now.
<25,000 easy driving, no off road, but a few dirt roads
Clutch went out over the weekend, progressing from subtle, slight clutch slipping to complete failure in two days, only highway driving, but weekend stop and go traffic sped up the process.
Question for the experts: When the clutch completely failed, the car shutdown, no power brakes or power steering? Next day at local dealership, car started right up? Left me in a very dangerous highway situation.
Service said they had not heard of this issue before, would need to check to see if there was an obvious reason for failure, and then take up with Nissan to fix under warranty.
What can I expect with a new clutch, another 25K of use? No more Nissan for me.
Thank you to all that posted before me so that I know this is not an isolated incident.
"Nissan Canada has no reason to believe there exists an inherent clutch problem with the Xterra. There has not been an unusual number of warranty claims attempted or otherwise and also, and more importantly, there has not been an unusual number of parts sales for repairs that customers are paying for."
2010 will involve 2 new vehicles in my household. neither one will be a Nissan.
The outfit in S. D. ca. is called Jim Wolf Technology. They specialize in Nissan. They are the only one I could find that was up to speed on the late model nissan frontier. After shipping and taxes they charged me 1,043 bucks for the flywheel, clutch and pressure plate, throwout and pilot bearing. one day shipping. tustin transmission will install it for a little over 550. That is under 1600 bucks as opposed to Nissan putting their pos in there for 2250 plus tax and it going out in another 15 thousand miles. Nissan is cutting their own throat, slowly.
This is why I truly appreciate you taking the time to provide the info you found on an improved clutch/flywheel set. I expect my wife's Xterra factory replacement clutch to fail again in another 10k miles, and plan to contact Jim Wolfe Tech to possibly secure a replacement set to have on hand. Thanks.
If there are any negative impressions of the saviour parts I will not hold back on my coments. Tustin transmission is going to box up the oem pos and give it to me after they have taken it out. I fired off an email to bar, bureau of automotive repair complaint department. I suggest anybody else with this problem do the same.
I equivolate the dual mass flywheel with off set golf clubs to compensate for a duffer slice. Bought some of those clubs one time and immediately started hooking everything. Plus they were cast instead of forged and so I had about 2% feel of the golf ball at impact. But......, I guess the proper way to relate what this new set up feels like is to wait a spell and when my muscle memory has caught up, post a note for you all.
After spending $1500 to get it fixed (new clutch & resurfaced flywheel) while Nissan Consumer Affairs "researched" my complaint and to see if they would cover this under warranty, I finally received a call today to say after "careful" deliberation with their staff that they were not going to cover it.
I still have my burnt out clutch and other parts from the incident and plan on holding onto it in case a mass forms to move towards a class-action suit.
This is absolute BS in my mind and I know Nissan has definitely lost my business permanently (was actually about ready to purchase a Nissan or Infiniti vehicle for our second car).
with 2008froner 10k.000 miles
clutch~flywheel;Aside from warranty issues!
besides wanting to extort $1,600
I happen to go thru the same regional denial!
It must be pre~determine and they are in
koo~hootz b/the tech.!
As my little pakistan women friend would say..
"what to do? , what to do?"
prettysneaky69@yahoo.com
I have a 2005 Frontier V6 Nismo which I baby... it only has 30,000 miles in these 4 years. I've been driving 13 years now, all of which were on Manual Transmissions. I have NEVER had clutch problems before...
The clutch in the Nissan is absolutley horrible. No holding power what-so-ever. I roasted it once off road, once in San Francisco, and just recently it failed on me last week driving up a driveway with (gasp) 400 Lbs in the bed... stinky burned clutch and horrible noise...
I'm gonna do the job myself and get the flywheel resurfaced... Has anyone switched to a Daikin/Exedy clutch with good results?
Now If they would just fix my leaky rear axle seal.....
