Chrysler Sebring Engine Problems
My husband and I purchased a 2006 Chrysler Sebring, with a 2.4 Liter V4 engine in it, back in November. When we bought it, it had roughly 46,000 miles on it. We have had nothing but trouble with this car since we bought it... Not even two months into owning it we had to have the transmission flushed because of some problems with it, then, just last week, we had to put new spark plugs in it because it was losing power as I was driving it! That's not all!! Two days ago, I was driving down the highway, about 65 mph, and the engine made a loud pop and started to shake. I started losing rpm's and had to pull over because I couldn't hardly make it up the road any more. As I stopped and put it in park, the engine was making a horrible clanking sound, like there was something stuck in it and it was being tossed around, hitting every inch as it moved... We towed it to the shop, and they told me that the lower part of my engine had blown. It only has a little over 53,000 miles on it!!! Has anyone else had these kinds of problems with the 2006 4-cylinder engines? There shouldn't be any sort of problems like this, not this soon (or at least I didn't think there would be...)
Tell you one thing I will never buy another Dodge or Crysler product again in my life time!
Now on the 2nd engine there is a loud rattling noise at start up until the oil pressure gets up to par..........ooops, guess what....I now have a messed up valve lifter! Stupid POS!
Since the Sebring/Avenger sedans are sales flops, it will be interesting to see how quickly the now privately owned Chrysler will redesign and improve them.
also the tach is not working,
console battery light stay on when engine is on does not run off
$5380 engine they are billing us $2690. Our warranty was only for 36,000 miles but we did not abuse the engine. It wasn't suppose to fail at 53,000. Has anyone had this experience? I really only want to buy American, but now I will have to really pray about my next car.
replacement one I got had them in a different sequence than the original
Thanks, OMB
Steam comes from under the hood sometimes - A/C compressor, evap., radiator have been replaced. Was working fine until I had the oil changed, then again started with the hot than normal. I do not want to get stuck in rush hour traffic
Mine would idle fine but when you started accellerating it would spit sputter, tach meter jumps up down, check engine light comes on and it would show code for crankshaft sensor or engine misfire. Turn you key switch on and off about 5 times and you digital odometer will show the error codes..
Hope this helps.. :sick:
* Weld all types of plastic
* Locking regulator with adjusting dial
* Gauge scale measures in 1/10ths
Includes 12 ft. hose. 110V; 1/4'' NPT inlet; 15 PSI maximum scale pressure
ITEM 41592-1VGA
You can find this at:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=41592&?utm_sour- ce=internet_email&utm_medium=email&utm_campaign=0510A&utm_content=v1
And the exhaust is pluged up !
You could have broken a rocker , remove valve cover and check to make sure !
Hope it's not your timing ! Good Luck !
My 99 sebring just dies while driving....but I can put car in neutral ...shut of ignition and start car right back up......this goes on every few miles.
