Visitor Agreement.
Replace and reverse the steps.
Vic
As my title stated is enquiry about, is there ant tools, equipments or instrument to measure the air conditioning system in the car? As example any car?Is there any way that we can know how to troubleshooting the car air cond system? As example the places for the car air-cond that easy spoil and causes sound which is the blade, pump and fan. But for the car system, the air cond system is use what kind of gases, i mean the refrigerant 134 or else?
Thank you for helping me. Sorry for inconvinent. Thanks.
Does anybody remember being there?
Could you help?
Can someone tell me the Part name, and if the dashboard needs to be removed.
Anyone have this issue and a resolution?
I noticed that when I try to turn off the system, the fan appears to run even faster! Bottom line, I can't slow it down and I can't stop it!
Any ideas what has failed? I kind of expect repairs not to be cheap, but does anyone know the ballpark for repairs?
Many thanks....
---Paul
---Paul in Southern NJ
TSB Number: 2400504
Did the new resistor block solve the fan issue for you? I've same problem.
TIA,
Bob
First time they used dye and checked AC and could not find a leak - reacharge - 4 weeks later no AC again. They refilled for free can't find the leak and said the following is what they believe it to be....
in Rear cooling system
Evaporator may be leaking
Apparently not something easy to get to - great
go do dealer
Anyone else had EVAPORATOR AC issues ?
I found the part online so at least I know evaporator is not just a "go away" term - ha ha - usually just heard of condensor in AC system. What is difference between Condensor and Evaporator?
Budda 1 says Peace Out
thanks!
I am also gonna try unhooking the battery as this may reset the controls if it malfunctioning from the computer sensors.
Did you ever find an answer? Ever break down and go to the dealership?
