Jeep Grand Cherokee Radio Problems
                    Turned on the jeep this morning, radio will not play. cant scroll through stations or toggle AM/FM so i  know its more than just an issue with speakers. cd will not play. The CD player will take and eject a cd but will not play it. it will not switch tracks. the clock is on and working fine. Very weird... I have been through the obivous... knob is in the on position, fuses are all good.... Any ideas?
See also: Jeep Grand Cherokee Radio Removal and Installation (Video, 15:05)
I have a newer 07 GC Laredo with X package and am wondering if any out there have figured out how to keep the radio in AUX mode.
The audio system is a base single CD w/Bostons Acoustics amp adder. This REF model radio has AM/FM stereo, single-disc CD player w/bass, treble, balance, and fade control through on-screen menu -AND- front mount auxiliary audio input jack. I did not want Sirius since I have had XM for many years and own the Delphi portable XM that I dash mounted. In our 01 & 04 cars we used a cassette deck adapter to direct feed audio from the XM unit and the car audio always stays in cassette play when you turn it off/on. However this Jeep radio goes back to FM radio mode upon restarting the Jeep when you turn off the Jeep with the radio in AUX mode (the XM unit powers off/on automatically when is senses a loss of 12VDC power, 4 years old and perhaps "smarter" then the newer Jeep radio?).
Anyone with a 07 or 08 model feeding the AUX with XM or even a MP3 player ie ipod figure out how to keep this Jeep radio in AUX mode?
From Mar 14 07: I will answer my own question with what our dealer got from Jeep engineering: you must turn the radio OFF before turing off the ignition and then the radio stays in AUX mode when you start the car. But of course you have to turn the radio back on again as well.
One of the crazier answers I have ever heard. The radio does not require that operation to stay in AM,FM or CD mode as you can switch off the car with the radio on and it goes back to the mode you left it in. Seems to me a true design bug! I don't think it's worth fighting, but one of my first (minor) disappointments with this new vehicle.
the radio still lights up and i can change the channels, enter a cd etc but there is no sound. replaced the fuse but to no avail. any suggestions?? if 1 speaker is bad or the wire is disconnected will it effect all of the speakers.
You could try finding and pulling the fuse for the CD player and see it that resets it.
Last night I was sitting in my garage and it started doing it. Engine was stopped, no key in ignition. Had been parked for an hour after driving home. Only the interior lights were on while I was digging through my glove box. I was able to climb around to try and find the source of the sound, and it sounds like it's coming from *inside* the MyGig unit itself. There was no CD in the unit.
Has anyone discovered the source of this sound? Do I need a new MyGig unit? :confuse:
today I spent 2hours and 150$ to the jeep dealers here, and they said I can't mount this radio on the car.
I've read somewhere else on the web, and the person who sold me the radio told the same, that I can mount this radio.
Is there anyone who can help me?
Thanks a lot.
These cd / cassette combo units are made by Mitsubishi for Chrysler vehicles, and are extremely high quality. There are four common problems that occur to these models. When a dealer ships one to me, I address all four issues right away so their customers won't experience any of the other problems in the future. However, a dead radio is not one of these problems unless the UPS basketball team handles it; then the power supply board can be cracked when the radio gets dropped. If that happens, you won't have any display at all.
I suspect you will find a blown fuse due to the bad battery connections. The rapid repetitive voltage spikes can pop a fuse from the charging of the memory circuits in the various computers on the vehicle. This usually results in no permanent damage other than the fuse.
caradiodoc
My AM/FM portion of my 07 JeepGC worked fine but the SAT portion did not work. In fact it kept blinking on and off as if it were trying to find a signal. It appeared to be stuck on the last station that I used 184 and no volume. I tried some of the suggestions posted including disconnecting the battery but to no avail. I went on to my sirius radio account and treated the radio as if it were a new installation. I had a new activation signal sent and 5 minutes later my radio was working fine.
Can i have the nav-rear camera group package installed now or do you have to order from the factory that way. Thanks folks
SUVs and Smart Shopper
Our Radio just keeps telling us 'Please wait for 2 hr', then switching to 'wait'.
This weekend we had to travel to York, UK and a guy told us that we have to reset the code, since it was entered incorrectly.
Any hints where to go to reset it ?
:sick:
check the internet for radio codes will need your cearal number and pos barcode number off radio sould be able to get codes then
Unfortunately Chrysler Germany has no idea if they can get the code, since the Serialnumber is not in their list (E405....).
The model number is : 5269488.
Supplier: 26777
Date Code: 1304
Issue: 1
Serial Nuber; E40510134
Any ideas ?
http://www.radio-code.co.uk/chrysler-radio-codes.html
http://www.radio-code.com/
I got the code.
Are there any walkarounds to get rid of this 2 hour wait on the radio display ?
Best Regards
Michael
:confuse:
Starts always with "Please wait 2hrs", then switching to "wait"...
I never had the car running for 2 hrs, so I can't say if it works then...
Thank you anyway and kind regards from Heinsberg, Germany.
Michael
Would it be possible to use another radio in there ? :confuse:
link
I have given a bad code (because battery was low and I didn´t know something about code) My husband has a right code of course, but when I turn the radio on, there is wait for 2 hrs and then it switch to WAIT.
I dont know how can I give the correct code now, I had tried it with engine off, but still nothing, still WAIT there
pls could you help me?
thanx katarina
I didn't have time to try it until now.
I'll keep you posted.
Regards
Michael
The CD player works great as do all other features on the radio, just very poor reception.
Has anyone come across this problem and can offer suggestions on what the problem could be?
:confuse:
the mode button on my 05 grand cherokee stopped working a few weeks ago, all the fuses r intact and all the other buttons on the radio work perfectly. battery died before the button stopped working, does anyone know how i could fix this or is it something a jeep dealer will have to fix
I have a '05 Limited with the 6 disc changer with navigation. I got in my truck the other morning and the highs were the only thing that play music now. All my door speakers stopped working. I checked the fuse in the fuse box that was assigned to the amp and it was fine. The highs quit when i pulled it out. Does anyone know where the factory amp is physically located in the vehicle? Does anyone have any idea what this may be? Are there other fuses I should check?
Matt
