Dodge Durango Heating Ventilation Air Conditioning
The heater does not blow hot air just luke warm air. The coolant level is ok, the heater core hoses are not plugged, and the engine runs at good temp. What else could be causing this? Thanks
I now have the same problem with the rear heat and a/c cool but not hot with heat on and warm with the a/c running I'm fixing this one as vehicle is now out of warraty. A plastic stop piece broke on the motor turn knob, and it drives to far and it breaks the piece attached to the door.
hope you get it fixed.
ps on mine the part I needed to get has been upgraded with 6 new part numbers from the original.
can any one help with the control if it needs to be calibrated so that it does not brake this item again?
thanks Larry kman10@snip.net
Please help!!!
Did you get this fixed? I have the same problem, intermittent a/c compressor engaging on and off, a/c blows with no cooling when compressor cycles on and off. sometimes woks just fine.
Ideas ? solutions??
thanks,
THanks
did you find out whats wrong?
Merry Christmas!
The 2nd issue with the AC is that if you have the AC on and are in stop and go traffic or going slow, 25-35mph, the engine starts to sound like a diesel engine, no kidding! If it is doing this and you give it some gas to speed up it growls even louder. However once you get up to 45 or so the sound will fade out and go back to normal.
Perhaps the two issues are related. Is there a fan that might be not working?
Has anyone had a similar problem? Any help with this would be greatly appreciated!
When turning my blower switch, just blows air through top wind shield/ defrost vents. does not change vents when I go to dash or floor settings, nor does my ac turn on. Checked all fuses seem to be fine. Blower speed switch works as well as the heat when on heat setting. Just cant hear the normal opening or changing of vents under the dash. Think could be switch meaning the one dial switch of the three that switches vents and triggers ac.
any suggestions?
Ken
Ken
The compressor does not kick on.
The compressor relay is ok.
The freon is fully charged per my gauge on the refill cans I use on our other cars.
Is there something missing to reset or replace to engage the compressor.
There is also no hot air at all - always glows cool air.
feel the air when I have my hands on the steering wheel but it doesn't really blow out. Any idea what this may be? I appreciate any comments. 2001 Dodge Durango.
How to fix? Well that's another story. Sorta pain in the azz. Gotta remove dash. chances are, when you do, you'll probably need to replace your leaking heater core and A/C evaporator also
