2007 Dodge Charger 5.7 Hemi (add horsepower)
What can I do to give my 2007 Dodge Charger R/T with 5.7 Hemi more horsepower. I presently have 240 hp. from stand still this car will hardly burn the rear wheels.
Larry Jackson (254) 749-0149 please call
feelgoodracing
Larry Jackson
(254) 749-0148 anytime
Custom Fit Ignition Wire Set (15 hp, $150)
MSD Blaster Coils (? hp, $500)
Cold air intake (14 hp, $300)
FLASH Chip/PROGRAMMER (20 hp, $500)
Aft-Cat™ Exhaust (20 hp, $760)
Performance Headers & Exhaust (24 hp, $550)
cat Mid-pipe (n/a, $450)
UnderDrive Pulley Kit (12 hp, $230)
Cam/Spring/Pushrods Kits (60 hp, $525)
Torque Converter (N|A, $400)
Transmission Cooler (N\A, $100)
Suspension upgrade ($1100)
I'm looking for input on:
- Install Order (What has to go first and what gives the biggest HP gain for the buck)
- install hrs (how many hours to install if I take it to a speedshop or mechanic, so I can estimate installation price)
- hp gain
- Fuel efficiency gain
- Approx Cost (Hardware only)
- does it Void the Warrenty?
- Recommendation Best Value
- Recommendation Best performance (regardless of cost)
Visiting Host Just Dropping In!
It really all depends on how carefully they measured cylinder bore wear and how carefully they inspected the pistons and rings. I would think they'd be crazy to re-install worn rings or put pistons into an egg-shaped cylinder bore.
Not sure why your engine started knocking---one hopes it was not oil starvation but rather manufacturing defect or cap bolt stress.
Well of course the machine shop is going to say that, because they don't want any chance of a comeback whatsoever; on the other hand, the dealer is not going to be paid by the factory for throwing away perfectly good piston rings, and I can't see any reason to hone such low mileage cylinders. If you put in NEW rings, then yes, I'd hone probably. But the original rings, pistons and cylinder walls are old friends and very well acquainted.
Ring groove is merely a matter of placement. The ring sits in a groove in the piston. I presume a mechanic would not be so stupid as to not vary the notch in the ring grooves so they don't line up top to bottom, or at least check that.
If you're asking: could a mechanic make a mistake re-assembling my engine, the answer is SURE.
Magna-Flow exhaust and Airraid air intake unit. Low temp thermostat and new platinum plugs slightly off spark. AMAZING. Under a thousand bucks and worth every dime.
What other tune items did you change?
