Visitor Agreement.
So you'd suggest changing the filter every time you change the oil. Given that there are no mazda dealers here I was hoping to be able to use the filters for a longer period, but I guess I'll just have to stock up. Any thoughts on synthetic vs. organic oil? I guess that with a 3000m interval I just go with organic, right?
All the best,
gts
Stock up on filters - only about US$4.25 each from Trussville Mazda.
I suggest you find a generic filter, or a Brazilian made one, that fits. Maybe take an old one and eye ball something with the same size opening and a very small overall size, because there isn't much room in there at all.
I agree with Mike that you should probably change just about all the fluids now to establish a base line. For the tranny and the rear differential, use 75w90 gear oil. That should be easy to find.
-juice
From what I have read, the Mazda filters are better than any of the aftermarket filters, so I would try and find the OEM filters unless the cost differential is too great. Just remember to change the filter with every oil change.
I would like nothing more than to drive a Miata south from Rio along BR 101. While there are Mazdas in Brazil, I have never seen a Miata there.
When we raised the car to change the oil today I found out that the car is significantly scraped on the underside with the underside slightly bent from contacts with speedbumps or garageways... I need to raise the car. (juice I got the camera and I'll send you pics this w/e just for the record).
I am not sure what I'll need to do to raise it, but that's my #1 priority now... Now I have to find some shocks that will fit here in Brazil (either that or find a way to fly to US, Argentina or Chile to get them...
As for driving it down BR101... That is what I want as well. Sadly, getting to BR101 is tough with the car this low. The road through Santa Cruz is almost destroyed (so you have to go thorugh avenida Brasil and the place I can stay in Angra has very tough access as well. When the car is higher I'll go, but for now my first planned trip is to Petropolis.
Abraco a todos,
gts
Good luck and happy driving to Petropolis.
Can you take a photo of the springs/shocks? Then I'll share it with this group (by hosting it on-line) and we'll get some more opinions.
So we might end up having to search for taller-than-stock springs. Anyone know if Protoge springs fit?
-juice
Sorry to be a drag here.
Cheers to all,
gts
Check out these, made for Subarus, just to borrow ideas, if possible:
http://isrperformance.com/main.html
Go to off road parts.
The Subaru is actually similar because it uses 4 coil springs and has a 4 wheel independent suspension.
-juice
FWIW, I looked on Cars.com when I bought my '93.
-juice
http://homepage.mac.com/tboggs/PhotoAlbum6.html
I can tell I am really going to enjoy this car.
Strange thing happened this morning to my '93 Miata. The clutch suddenly got soft, for about the first 3/4ths of its travel. Still worked, but the point of engagement was closer to the firewall than normal. I have just 41k miles, but it is more than a decade old.
It didn't quite sink to the floor, just got softer. What's bizarre is that about 10 miles later, it fixed itself.
Should I start saving for a new clutch? Is there something I can adjust? I put in synthetic in the tranny/front diff, is that fluid shared with the clutch? If not, how do I change or at least add fluid to the clutch?
-juice
if yours is hydraulic too, you could have a leaking slave cylinder but first just bleed it. I'm sure you can google up some articles on how to do this... if that doesn't work, replacing the slave cylinder is probably next. I imagine you'd take it in for that.
if it's a pressure plate issue those usually don't fix themselves... once the fingers collapse that's generally it.
-Colin
Thanks as always,
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Chuck
There is a rubber boot that covers a pushrod in the cylinder. Pull back on the boot to see if there is any cluid pooled up inside of it. If so, you have a leaky cylinder. New units are about $35-$50 and can be replaced in less than an hour. It is held on by two bolts and the nut securing the clutch fluid line to the cylinder.
Replacement instructions can be found at Miata.net
94 Miata w/ Package B
Color: Laguna Blue
Interior: Black cloth
Miles: 39,100
Trans: Manual
Condition: Mint
I sold it for $7000.00 to a friend. I think it could have gotten $7500. In your case, I would guess you will get $6500. This is adjusting for the fact that I sold last year vs. current year, Laguna Blue is more rare than Montego Blue, Manual is preferable to Auto, and lower miles. But I think it's a close range. I would start the offer at $7500 and see what bites, then adjust to $6900 after a month.
OK, so I'll check the fluid tonight. This weekend I'll try to inspect for fluid around the area Mike described (thanks).
-juice
I hope we have a great Spring and Summer so you can enjoy as much as possible.
2. GoggleHelmet: Washing liquid from cars/van in front.
2. Mask: Vehicle with Side exhaust pipes.
Not much fun at all.
-juice
The sun was shining today, but it was cold. Not to worry. I have a great Patagonia Core jacket. It is light, but nevertheless wind resistant and warm. I recommend it to people who want to have the top down in chilly weather, but do not want a heavy coat on that makes it hard to manuver.
-juice
If you want a new one, Trussville is a very good place to start looking. At a minimum, you should get the HT latches that you will need in order to add a HT to a car that has not had one in the past.
HTs from all years fit all years, although the '90-'91 HTs did not have a rear defroster (if that is important to you)..
Where are you located? What year / color are you looking for?
Good luck!
http://www.finishlineperformance.com/cgi-bin/shopper?preadd=actio- - n&key=EX1105
-juice
Thanks...
Where did you buy the parts? Roebuck's web site is bizarre now, looks like someone else stole their URL.
-juice
I hope the odometers are more accurate than that, else we're accumulating more miles for naught.
-juice
BTW: Twinpower - Wondertwins fan?
Twinpower - I have twin girls...
The car has a steering problem, one which wasn't readily apparent on my 2 test drives. She will steer a straight line on a flat road (even if I let go of the wheel).
Problem is, if I hit a pothole (small or big) or, say, a speedbump, the wheel pulls sharply left or right (depending on the side the hole/bump is on) in an unnatural way. I really have to be ready for it if I see a bump coming.
I need new bushings, says my friend.
Does any of this sound familiar to anyone? I can't think the Miata steers this way off the showroom floor... Thanks for any help... -t.
I have already bought new shocks (though they take 30 days to be delivered to Brazil) and the shock dustguards and I am now wondering if I should buy new springs as well (the cost is a concern, but the 30 day wait is just maddening).
I have not yet torn down the suspension to take a look at each part but I was wondering if anyone can help me with these questions:
*1. Has anyone ever had suspension height problems that were not due to the springs? (the service manual says I could have busted shock boots as my problem and if that is the case buying new springs will be a waste of money)
*2. Has anyone ever experimented raising the car with nylon disks? If so where shuld I put them above the springs or below the springs? Can anyone think of a reason not to use them?
*3. For online buying I've found that www.finishlineperformance.com has better prices than www.trussvillemazda.com (and better shipping prices as well because it is in VA) but neither has mazda springs (only aftermarket). I've only found the springs in an online dealer for about US$80 and I don't know if this is too much... Is this a good price?
Sorry for the long message.
Abraço a todos,
gts
