Visitor Agreement.
It shakes horribly like the steering wheel wants to go off by itself but most importantly i have had an issue with it heating up for the past 2 years.
Its leaked out the antifreeze ive had the radiator replaced and alot of the insides replaced as well.
With summer coming its starting to act up again as soon as i turn it on it just kind of shakesfor a few minutes then stops
also when i turn it off and ive had the ac on it sounds weird like a loud hurricane sound.
so far ive taken it to 3 different mechanics just this month alone
but now im worried because last yr i had it straight wired and now the electrical system is whats wrong but i told the mechanics i chose to get it straight wired because of the previous problems before.
so now im not sure what to do and if its possible to get it back to the way it was before without straight wiring and what kind of mechanic am i looking for or if i need a new motor as one mechanic told me.
I HAVE REPLACE PRETTY MUCH EVERYTHING. THE PARTS ARE
FUEL PUMP
FUEL FILTER
IDLER SENSOR
THROTTLE SENSOR
MAP SENSOR
BATTERY
ALTERNATOR
DISTRIBUTOR CAP, ROTOR, AND CAM SENSOR
CRANK SENSOR
AND WELL NOTHING SEEMED HELP. IT FINALLY STARTS BUT A VERY HARD IDLE AND THEN DIES. PLEASE IF ANYBODY HAS ANY OTHER IDEAS IT WOULD REALLY BE APPRECIATED.
THANK YOU
Thanks!!
Laura
Any ideas or similar experiences?
Ever since I got my Jeep, there have been slight electrical issues, but over the past 5 years they've gotten worse, and more of them. Now that I'm seriously considering getting rid of it (which I don't wanna do) I looked you guys up. Quick, ain't I? Anyhow, the automatic lights will just randomly start flashing. As soon as I touch the panel where the control dial is for the lights, it stops. If I don't use the automatic setting, and just turn them on manually, no flashing of the headlights. I live in the city so I like the automatics - I can get in the house before they shut off. But living in the city could also get me shot if they start flashing when I'm behind someone. My radio never worked right, so I replaced the antenna several years ago, didn't help. Now the CD player doesn't work either. Just barely static. My sunroof won't open anymore. Heated seats don't heat. And now I get a message at night that says my taillights aren't working, but they are. Till I get home from work, the message is usually gone. All the gauges work, windows, work, AC blower works, dash lighting works, security alarm works, power seats work, cruise works, just the freaky things mentioned above.
Does anyone know if there has been a recall for this problem? It seems like a grounding issue. I put a new battery in it last year and nothing got worse at that time. All these things were happening waaay before the new battery except the CD player, and I feel my son had something to do with that. Any words you can offer to direct me would be appreciated.
Steve
Symptoms:
-A/C compressor does not kick on
-ALL the windows are stuck up
-Airbag light is on
-Seatbelt light is on
-Dash lights are stuck on high with no dimming
-Horn does not work
-The info center does not read temp or anything else but the compass works
-Dome light will not turn off
That is about it. To me this all relates back to those wires running through the door but they were all triple checked and came out ok. Any ideas?
three regulators were broke i replaced them one went fine but the right rear one that i replaced theres no power going to the door except the speaker [weird]
i know the reg works cause we powered it with an external source and it went up and down
Do you know what would cause this
also i found water in my trunk on driver side and 2-3 inces of water in my spare tire comp what would cause this
I am having problems with rear light failure
1. all the lights are fully functional.
2. I need a schematic showing the wiring for the plugs p1 and p2 on the light sensing module and where the supply voltage is sourced and what the outputs end up feeding, they appear to be on P1-9 wire blu with black tracer
3. I know the module has U4791B comparators in it. The comparator outputs pins 3&5 are all 10.5 to 12v- I think this is coming from the module that the output feeds
4. I have cleaned all contact and the bulb measure about 1.0 ohm of resistance.
5 Can I eliminate this module form the system as it causes more problems than it cures.
I appreciate all assistance in advance
Dashboard panel gauges - such as gas, speedometer, oil gauge, suddenly stopped working while car was driving. All gauges went to zero, as if the car was not on.
The engine was replaced 1 month ago, and had no issues till recently, gauges just stopped recognizing the car being on.
Note, the ignition key has not changed.
Also, the security system is not working, and the windows do not go up or down.
There is a indicator on the panel that I've never seen - the sentry security system (a key with a line through it) is lit up on the dashboard - as if there was no key in the ignition?
Any help with this would be appreciated. The heater and radio work? Engine also runs fine. Engine was not replaced by jeep dealer, but car runs really nice - not sure what this problem is? Could it have to do with the ignition? Does this require servicing now by a Jeep Dealership?
Any suggestions would be greatly appreciated.
Also , a small side marker bulb can also cause the warning and go unnoticed .
Don't know what the problem could be.
