Mazda CX-9 Rear Entertainment System
                    i have an cx 9 imported to holland and now i can not use the dvd system because this has a usa coutry code
this can be changed but i cant find the code
can someone help me?
Your other option is to create region-free DVDs of the movies that your passengers want to watch. You are already half-way there with your PC. Buy a double layer DVD burner if you don't have one already. Easiest method is to RIP them to disk with software like ANYDVD from Slysoft. Then burn them to Double layer discs using several progams on the market to create region free versions.
If you don't mind video compression a bit to save cost, use DVD RW discs and you can keep using the same disc over and over.
I have sent them a couple of emails in the past. They had been very friendly and informative. It takes a couple of days for them to get back to you by e-mails.
http://www.mazdausa.com/MusaWeb/emailMazda.action
waynemazda.com
or
mazdaparts.org
for best OE prices.
Your local Mazda dealer can't wait to charge you an arm and a leg.
Any and all help would be greatly appreciated.
Occasionally one will pop up.
How is that?
http://cgi.ebay.com/ebaymotors/MAZDA-CX-9-WIRELESS-HEADSETS-DVD-PLAYER-_W0QQcmdZ- ViewItemQQhashZitem19bdd4334fQQitemZ110558982991QQptZMotorsQ5fCarQ5fTruckQ5fPart- sQ5fAccessories
PART # z38 FPC-MONI NAN241L872
I am going to go to a computer store and see if I can have the guys work on it or give me a duplicate. Some of this electrical metal strips are like power cords and many are alike.
If you find some help with MAZDA please let me know. :sick:
I thought a switch was need to make it work but this appears to be factory functionality.
Do I have a later date model when Mazda had resolved this issue? In any case, I am glad it works!
While my children are watching a movie in the back, is there any possible way for me to allow them to listen to the DVD in the back speakers while I listen to the radio in the front speakers. I know this is allowable with the headset on. However, I have 3 boys and only one headset. Therefore, I am only able to use the speakers.
Has anyone had experience with aftermarket headrest DVD-monitor set-ups for the CX-9? I've seen a few different types, including an Audiovox, but am wondering about performance & reliabilty.
If anyone has a RES system they are getting rid of for a new system please contact me, please.
Sorry, I was not much help.
I hope this help you. This is the link where I found the ribbon cable:
http://cgi.ebay.com/AWM-20624-80C-60V-RIBBON-CABLE-40-PINS-120mm-/220737165563?_- trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D2%26po%3DLVI%26ps%3D63%- 26clkid%3D446128025306067659#ht_1128wt_747
I am still looking for a DVD player if anyone want to get rid of theirs for a newer system.
Make sure to have ziploc bags nearby to separate the screws. Take a picture of everything after you take the bezel/cover off.
For the main cover - just pull it down. You will see some screws holding the unit. Unplug the power/signal connections [You'll need a thin flat head to do this].
After this it is simple. You will see a little latch holding the flat connection just pull it up and it unlocks the flat connection. Next, unscrew the monitor's bezel, and unlock the flat connection there also. Keep the black strip of tape you find inside because you can use that for the new flat connection. Put in your new strip. Buy it on Ebay from the link above...and you have yourself a working screen!
By the way, I still need a DVD player so if anyone is getting rid of their system for something different, please contact me I would like to buy it.
thanks.
http://www.ebay.com/itm/40-PIN-11-7-cm-length-AWM-2896-RIBBON-CABLE-same-side-0-- 50mm-pitch-40PIN-117mm/221055210726?ssPageName=WDVW&rd=1&ih=012&category=3668&cm- d=ViewItem
do you think it will work? and when pulling the cover off do you have any recommendations of hand position to pull?
I pull it down as hard as I can, but I can pull it down.
Can you describe more detail for this? Or if possible, can you make a video for that?
Please help me. I need to fix it ASAP. My kids is waiting for it.
