Rear view mirror temp and compass not working. Chevy Suburban.
Hoping someone can help. The temp and compass quit working on the rear view mirror of my 02 suburban. It worked on and off for a while and now quit completely. I'm wondering if anyone else has had this problem. I don't know if it is the mirror or maybe a sensor somewhere that is broken. Any thoughts would be great. If not I guess i'll get it to the dealer. Thanks.
See Also
How To Fix Malfunctioning Rearview Mirrors
See Also
You might check the electrical connector to the mirror. It is located just above the mirror in the cable running behind the cover attached to the window. Perhaps there is a bit of poor contact there. Are you getting any display in the mirror at all? Are any of the lights working? The Air Bag light is in the bottom of the mirror, does it still work? I do not think it is a problem with the power to the mirror as it shares power with several other things in the interior and you would know if a fuse was blown. Also do not think it is a problem with the inputs as there are two separate inputs as discussed before.
Ray
Anyone had this issue before
thedutydoctor
I have a 2007 where the compass and temp went out on the mirror. Took it to a dealer. The problem was/is the fuse block under the hood or connections. They reset the connections to the main fuse block harness and it all came back on. They said if it happens again, the main fuse block has to be replaced. It happened again after about six months.
Hi kathnrich,
Sorry to hear that the compass and temperature are out again on your vehicle. Since the dealership performed the repair not too long ago, they may be able to correct this again with no problems. We'd be happy to contact your dealership if you're thinking of going back to have this fixed if you haven't already done so. Feel free to send us a private message with your contact information and VIN if we can be of assistance.
Amber N.
GM Customer Care
OK, so a few more years later and the same thing has happened to my 2002 Avalanche Compass/Temp rear view mirror. What is the "under the hood connection" that needed to be checked on the main fuse block harness, referenced above? Or how can I tell if it is the mirror itself and not the main fuse block connection? Thanks.
Michael
There are actually more than 3 of these 4R3 resistors if you look pass the display circuit board, and on towards to the main board. I believe there are two more of these over there that we should check.
I'll post back when I fix it. 🤞
