Visitor Agreement.
The 4Runner has a low range, so why the downhill assist? Is the low range not low enough?
I have a 2002 Dodge Ram Quad Cab 4x4, (considering the 4runner), put that in 4Low and even the steepest hills are a breeze, its a nice creeper for stock.
What is the 4Runners(2003)low range ratio? Anyone know?
jeffjeff - the 3rd gen has an 18.5 gallon tank, and you will probably get about 18 mpg around town, maybe 21-22 on highway trips unless you are flogging it. And yes, you can go about another 50 miles when the gas light comes on, but that is just a very rough estimate, and may vary for your truck and your driving style.
Count me for one more vote that the cladding on the 4th gen Sport does not look anywhere near as bad in person as it did in the pictures, but one thing is for sure - this truck is NOTICEABLY lower to the ground. In a couple of months I am going to get one from a friend at a dealership and take it offroad (lightly!) and see how it compares to mine.
Land Rover Discovery and Range Rover have this downhill assist too. Both have low-ranges.
Downhill assist allows you to go downhill at less than 5 mph...a very controlled descent. This is slower than what you can get via transfer case alone, unless you have a low-range of 3.5 or above. Quickly applying the brake is not the same.
Overall, i like this feature. Maybe i can retrofit it on my '02!
I don't like that dealership. The salesmen are like flies, and I feel like I'm always swatting them away. Too high pressure a place for me...
Bob
Buyers beware!!!
Mackabee
Just scroll down to post with a lot of links to videos and pics.
• Does Toyota offer an under the dash wiring harness to hook up an electric trailer brake controller? I know GM offer this for their trucks as an option, and was wondering if Toyota also offers such a device.
• Or, do you have to splice wires to in order to hook up the brake controller?
• Does Toyota offer an electronic brake controller that would mount into one of the blank dashboard pop-out accessory plugs?
Bob
Beyond that, most trailers don't need electronic brakes but use surge brakes. The 2003 has a 7 pin connector at the hitch which can accommodate disc brakes that require a cut off (like my Ranger boat trailer).
If you're comparing a good-design IRS, then you have to compare it to a good-design solid axle, right? I mean, solid axle on Sequoia doesn't articulate much...therefore, it is not fair to compare it to the '03 Range Rover.
TIRE WEAR OR VIBRATION WITH THE RIGHT TIRE WEARING MORE
Saw a 2003 Limited and was pretty impressed; $40,985 fully loaded.
Saw a 2003 SR5 and thought it looked a lot smaller than the limited. Kind of a cross between the RAV4 and the Highlander... I think when my lease runs out on the 2000 Monty Sport I'll get a 2002 Sport 4Runner.
Sorry guys, but my wife drives the 4Runner. I feel that it's safer than the Mitsubishi Montero that's why it's hers. Plus I feel safer that our 6 month old is in a 4Runner. A lot more stable and the power is there when you need it...
Yes, better on-road, and very good off-road (not necessarily better than a solid axle layout, but still very good, nonetheless). Since these vehicles spend most of their time on-road, the IRS makes the most sense, IMO.
As to towing, I know you don't want to hear this, but the IRS-equipped Expedition has the the best towing in its class, at around 8500 pounds for 2WD versions, and a bit less for 4WD versions.
<< If you're comparing a good-design IRS, then you have to compare it to a good-design solid axle, right? I mean, solid axle on Sequoia doesn't articulate much...therefore, it is not fair to compare it to the '03 Range Rover.
You could also take this "articulation" issue to an extreme and say and point out how good purpose-built solid axle rock crawlers are. For the average SUV buyer, it means little however.
Bob
Now I am wondering if the models later this year or earlier next year will show up with it on the wheel. Either that or the website and brochures are wrong. It's listed in both sources. It's even optional on the SR5 and Sport models. Go figure.
Yes and no. For boat trailers, surge brakes are popular because you don't have to worry about water shorting out the system, but for utility trailers (such as what I have) electric brakes are preferred. In fact, I've spoken to several trailer dealers who think that surge brakes may(?) be outlawed in the future. Don't ask me why, because I don't know, other than that's what they've said.
The big advantage of electric brakes for utility trailers is that you can adjust for the amount of braking needed, whether you have a fully loaded trailer, or an empty trailer. Boat trailers are normally driven "fully loaded" (carrying a boat), so that's not an issue. Also with surge brakes, because of their design, tend to apply the trailer brakes when you are backing up.
The current issue of Truck Trend, besides having a 4Runner road test, has a very comprehensive section (this issue) devoted to trailering. It might be worth picking up. That's where I learned about surge brakes being applied when you are backing up.
So, Toyota does offer a under the dash wiring harness for electric trailer brakes. That's good. And it comes standard, if I understood you correctly? Do they also offer the brake control that the harness plugs into?
Bob
On the other hand, we have one on our lot right now without navi and with X-REAS. We also have a Sport model without the spoiler. Both of these are probably first run vehicles that didn't show up in the normal order bank. It is also likely that there are other dealerships with oddities like these. Once this first batch is sold, we will only be getting what is on the TVO report. Unfortunately, this means that if you want it this way, you need to get it now, wait and hope that future TVO books are more favorable to you or compromise your want list.
Ford Expedition is the first full-size SUV with IRS...there is a reason for that. We will see if this IRS will hold up to repeated towing. I think the control arms on the Expedition are ALUMINUM too. Oh yeah, that is just freaking great for towing and off-roading!
New Range Rover uses SOLID steel for the control arms...very nice! It is heavier but stronger than stamped steel...much stronger than aluminum.
I agree with you. IRS is great for most people. However, we're talking capability here, NOT what most people would use it for. I want an SUV that EXCEEDS my needs, rather than one that MEETS my need. Just my opinion.
There are some folks out there who swear you can't go off-road with IRS. I'm simply saying that's not true.
I am not saying that IRS is better than a solid axle off-road, only that a properly designed IRS can take most SUVs just about anywhere a sane* person would want to venture. That's it. Nothing more.
* = If your idea of *sane* is rock crawling on the Rubicon, then perhaps a solid axle is better for you. Is everybody happy now?
Bob
I'm definitely not an off-roader, so I'm evaluating the Limited against other vehicles such as the Volvo XC 90 (still to be seen). Anyhow, here are my impressions...
Exterior: Not bad, but nothing special. It's pretty generic, but not ugly. The textured B-pillar is a bit weird, however.
Interior: This is what I was looking forward to. Again, it's nice, but I wasn't knocked out by anything. It doesn't blow the competition away. The seats were really pretty comfortable, but I was disappointed that the passenger's seat had power forward-reverse and recline, but did not have a power height adjustment. I didn't check to see if it had a manual height adjustment. This lack is a definite negative for me.
The metal finish plastic is okay, but seems a bit cheap to me. Plastic is plastic and metal is metal, but never the twain should meet. And what's with that granite plastic around the central control cluster? That looked a bit like a bad kitchen counter.
Again, I didn't drive the Limited (which I will definitely do), so this first impression is admittedly incomplete. But my first reaction is that, while I like the new 4Runner, I haven't fallen in love with it. And, at $40K+ (with navigation), I'd better be in love before I sign on the bottom line. This may be my next vehicle, but it's going to take a little while to warm up to it.
BTW, this is my first posting on this site. Of all of the Edmunds sites I've visited, the folks here seem to be the most knowledgeable...and civil...of all. Keep up the good community!
You've got to drive this thing. I too thought it was nice but not great until I drove it. Trust me on this one.
As to the Expedition's durability, I'm sure Ford wouldn't have risked their reputation on IRS if they didn't believe in it. For what it's worth, the next F-150 is reportedly* also going to have IRS. Do you think Ford is so stupid that they would risk their sacred cash-cow F-150 with IRS, if they didn't have confidence in it.
* = The '04 F-150 was/is supposed to get IRS. However, Ford, trying to recoup losses, has been doing a slash-'n-burn to get the price down, so IRS may(?) get the ax.
Bob
But I do agree an IRS system works great if it is done right.
Question is toyota references all weather mats on their website. I would much rather have these then carpet mats.
1) When are these available?
2) Anyone know what these are. Are they rubber or plastic.
3) Include something for the cargo area?
BTW: For all who haven't driven one, certainly worth it. It is easily as quite as my BMW was and the V8 is perfect, smooth and powerful.
Yes it was crap, and I owned one. Didn't hurt Ford sales one bit however.
Bob
As for IRS on trucks...we will see! Truck owners are anal as anything! I don't think many truck owners (esp. Ford truck owners) will buy a truck with IRS. Hell, they don't even accept the Toyota Tundra as a real full-size!
Durability...we will see.
Didn't mean it was a good idea either.
Bob
tidester
SUVs; Aftermarket & Accessories
