Visitor Agreement.
Thanks, dmw
I also think of the new 3.0 V6 found in the Highlander, RX300, Camry, etc. There is a concern over a sludge build up and Toyota has issued a 8 year warranty for sludge on those engines made before 2002. If I was planning to keep the 4Runner for a long time, I would say the best bet is with the V8, especially for $800.
The V6's gearing gives 32.7 mph/thousand rpm in top, so 70 mph needs 2140 rpm.
These are calculated figures, so may be a smidgin off, but the V8 figures tally very closely with what our '03 Limited V8 actually shows on the tach at an indicated 70 mph.
Scarcely a nickle's worth of difference, I'd say.
-Karl
mitchinpa: yes it is normal for the edges of the hood on the 3rd gen to flap a bit at highway speeds - JUST A TAD. You will see it move, but if it is moving more than a little, you should make sure that the latches up there are OK.
the flip side of V-6 vs V-8: with the V-6 you can still switch to 2WD if you want to, and does the V-8 have the electronic throttle linkage, as opposed to a mechanical one? You might call that e-throttle-linkage an advantage of the V-6.
I am assuming that 4WD V-6 and V-8 SR5s are also about $800 apart?
It is actually the Diff-Lock switch on the 4WD models. When switched on it essentially shuts off the traction control.
There are so many acronyms associated with all the technology these days it's easy to get them mixed up.
What strikes me strange is why did Toyota have only 1 4WD in the whole bunch for off road test drives? It sounds stupid on their part.
Also, I hoped the factory engineers learned something when the Rockcrawler rep jumped into the stuck 4WD, turned off the electronics (VSC?) and the proceeded to unstick the 4runner using his learned tricks of the trade. He said they were amazed.
Interesting you mentioning the gross error in your Sequoia's OBC mpg function. The mpg readout in our 'Runner said 20.0 for this trip. That's 9% error, still WAAAAY more than it ought to be. Did you ever complain about your Sequoia and see if there was a fix?
-Karl
My Sequoia would consistantly squeak out 20 mpg(actual manual calculation)on fairly level terrain at an average of 60/65 mph. I would hope that the 1000lb. lighter 2003 V-8 4Runner would produce at least a couple of mpg more under the same conditions. If so, I'd be more inclined to buy the V-8 vs. the V-6 since low 20's would be OK for me. (My 2000 SR-5 A/T will deliver 22/23 mpg at steady 60/65,no A/C on.)
As far as complaining to Toyota, I never bothered since I would automatically take into consideration the error(plus, I only kept it for 14 months). It's hard to tell if you could get them to agree to a recalculated obc since they could easily take the position that the consumer generated figures can also be wrong if not done very carefully. Hard to prove, in other words.
Would you say, judging by your experience so far with the V-8, whether a lesser "torque endowed" V-6 would feel decent? In other words, did the V-8 have an over abundance of power which would imply that the V-6 could well handle the job?
Thanks for your input.
1.) 2003 Highlander V6- $23,975
2.) 2003 4Runner SR5-V8- $26,975
3.) 2003 Sequoia SR5- $31,975
Two things that caught my eye. That is the lowest price I have seen on the Highlander, maybe getting a new 4Runner help dropped the price. Second, the 4Runner price is already being discounted, that is if you believe the ad.
Also, don't you like the price points, pay a little more and get a bigger SUV. This is form the Atlanta Journal-Constitution.
However, I'd guess the V6 will do very well indeed, based on it's 34% HP and 30% torque advantage over the 3rd generation 'Runners with only about a 10% weight increase. Odd, though, that they retained the venerable 4-speed tranny for the less-torquey V6 and gave the nice new 5-speed to the V8.
Best.
-Karl
Again, thanks for taking time to calc and reply.
That's faster than the car I drive! ;-0
The way they have stacked powertrain options and outputs for the new Runner, it seems like they have bred the V-6 to fail, what with the equivalent hp and vastly higher torque of the V-8, not to mention its 5-spd auto and the fact that they are so close in price and mileage figures.
http://www.motortrend.com/features/scenes/112_0211_btssuoty/
Also, here is some SUV of the year Wallpaper.
http://motortrend.com/multimedia/wallpaper/suoty/
http://www.dawgpak.com/4Runner/
The 5 speed auto mated with the V8 is the same combo used for the LX 470, Land Cruser and Sequoia, an important upgrade this year for them. Transmissions are expensive and my guess is that a 5 speed would otherwise not be merited for the lighter 4 Runner with this torquey engine. It's a great bonus.
Look for the 4 litre 4 sp. to show up in Tacoma, Highlander, and perhaps Lexus models.
He had three concerns. First, he was afraid he damaged his new vehicle. After talking with my service director, we determined that this was not the case. There is a pawl that can break which prevents the transmission from going into park until it slows sufficiently but this didn't break in this case.
Next, he was concerned that there may be a defect which allowed the shifter to go from 5th down into park. There is no defect per se. Because it is a gated shift lever, there is no need for a button. The shifter did exactly what it was supposed to do.
His third concern was that the design is crummy. I agree with him on this. If you are in 4th, this can't happen. If you are in 5th, you can bump the shifter hard enough to drop into park.
Be careful with this.
I have major difficulty, however, over deeming this to be a "crummy design". Given even a modicum of attention and coordination, the gates do their job and make a direct shift into park virtually impossible. I've taught high-performance driving for commercial schools and sports car clubs for 15 years, and from my perspective, the shifter's design is elegant and functional. Believe me, I see and deal with many that are less so, and this includes the shifter on the 3rd gen 4Runners such as I traded in on my '03.
What happened here is that someone was doing something that shouldn't be done while driving and caused himself a problem thereby. So now instead of taking personal responsibility for his mishap, he (and you) blames a perfectly good shifter. I don't think so.
IMHO, when the coffee-drinkers, cell-phone users, map readers, makeup appliers, et cetera ad nauseam while driving take responsibility for their own actions and change their behavior, we'll all be foolproofed. Until then, I get irked when someone suggests we should be making things easier for them.
-Karl
There is no "OD Off" button for the tranny, like 3rd gen 4Runners had. If you select the "4" position, it's the equivalent of turning "OD" off.
-Karl
After reading your messages, I just jumped in the car, drove for a few miles in "D" and what a difference! Now, the question is - what's the worst thing I did as a result of my stupidity?
Burnt a few extra gallons of gas I imagine...anything else?
I'm also wondering - if I did this, are there others - or am I in a class by myself? Thanks again to both of you and of course this forum which made this possible.
Now about accidentally sifting from Drive to Park. I disagree it is not "a crummy design" and it is the fault of the owners. You don't always have your hands on the wheels. Toyota provided us with air conditioning, CD player and a cigarette lighter. (Actually, I think the cigarette lighter is now a option, go figure.) It is OK to come up with a better design in case of a mistake, that is why we have air bags, side impact beams and VSC.
Regarding an earlier post re:2003 titanium paint irregularities, Friday I visited a suburban MD. dealer who had 5 titanium 4Runners and ALL 5 had the discoloration "bleeding" look. I don't know if it comes from the color coat or if maybe the poly protection sheeting somehow reacted badly with the titanium. I did not see any other color affected. All 3 models had the problem.
Lastly, I find it frustrating that I can only get the taupe interior with the gold exterior(according to the spreadsheet that lists int/ext combos, this is true). I'm sure there are others who would wish to have a choice of interior colors that the brochure lists as available but don't get built. Do others agree and if so maybe letting Toyota know as we did regarding the gray cladding might get some results?
Regards-
I actually did the same thing on my test drive of the '03 4Runner, but had figured out beforehand what the tach should be reading at 70, so knew I didn't have it right. The vehicle is so quiet it's very hard to tell any difference between 4th and 5th.
-Karl
My overall mileage for 2,565 miles is 16.521.
Regards-
Merry christmas to all..... hohoho
V8- torque, 5 speed, steel, reliable, resale, taller overdrive, towing capacity
V6- gas mileage, aluminum, VVT-i, shift-on-the-fly multimode, price, weight distribution(?)
Does anybody know what the front/rear weight distribution is? Does the V6 get it closer to 50/50? There is a 130lb. weight difference between the two engines, amounting to about 3% less weight over the front wheels on the V6. Does this make a difference in handling?
Aluminum as an engine block is a mixed blessing. Yes, it saves weight...but then the 4Runner already weigh over 4000 lbs. Aluminum MAY also be less durable (over the long haul) than an iron block engine...especially IF you plan on putting a supercharger later or do some towing (high stress on engine).
I do NOT think the V8 5-speed auto has a significant taller overdrive. What the 5-speed has is a LOW 1st gear ratio (numerically HIGH), which helps with acceleration (& torquey feeling) and towing...and great for off-roading (great crawl ratio).
super: how can the plus of the V-8 be the iron block, yet the plus of the V-6 is the aluminum block? That is a contradiction?
All-aluminum engines cool off faster, which might be a plus in some situations.
I have been telling myself that it is worth waiting for the V6, but when the cost savings didn't materialize as I had hoped, I started wondering why I should get the smaller engine. I thought that maybe the V6 would be better handling due to lower weight. But you're right, on a vehicle this size and for this purpose, it doesn't matter.
However, absolutely every one of the magazines said that most drivers who don't tow (and I don't) won't notice the difference or need the V8. I guess the final proof is in the pudding...When can we drive one? They're supposed to be on the lots, but I haven't seen one yet. If it feels moderately as good as the V8 and I can talk the price down, I'm sure I would be happy with it. Still a lot more HP than the third gen.
The problem with most magazines is that they don't know anything! Sorry. Most of these freelance writers know very little about car stuff. They believe what the manufacturer says and read only the numbers.
The difference in fuel economy and cost between the V6 and V8 is so small that i would get the V8 in a heartbeat! Why would i get an UNproven V6 engine (with aluminum block)??
Remember, the V8 is good enough to go on a Lexus. Oh yeah, and you get the 5-speed auto tranny with it too!!! That alone is worth the little extra cash you have to shell out. It's all about bragging rights!
My opinion.
I own and have run a BMW shop for over 25 yrs., and have certainly seen the negative results of complexity. That's one reason my last three new vehicles have been Toyotas. It does give me some pause to consider selling my 2000, which is relatively simple, then buying the 2003 which has way more electronics(drivetrain and chassis) and servos. It will be a real leap of faith to do so!(I do intend to, though)
Regards-
The cladding is not sealed tight against the door panel so what concerns me is the eventual penetration of water and road salt washing down the door and behind the plastic where it can't be washed off. I did not think to check for weep holes at the bottom of the door panels on my test drive, however, I'm not so sure they would be very effective. My guess is that with millions of vehicles bearing cladding, Toyota would have avoided such a problem if there was one. Any experience is welcome.
So far the only problem I've encountered is that it didn't come with a front license plate bracket (realized it when I went to put on the front plate). The dealer initially told me I would have to buy it myself...not. They also don't have the updated parts catalogs in the service department so they are having trouble ordering it for all the models on the lot that are made in Japan.
I have also found the shifter is very easy to knock between D and 4 but there is a gear light located beside the speedometer that helps.
Haven't been able to take it off-road much yet but I have a feeling it is going to be great at it. Oh what a feeling!!!
