So my questions are:
1. Does the system really improve the handling in highway and/or off road situations ?
2. How much additional maintenance will the extra fluid lines, couplings and gas chamber require over a 5 year / 100k mile period.
3. If the system failed (leaked), would you be able to drive the vehicle back to civilization or would you be stranded ?
Thanks for any insights into this feature. I would probably buy an SR5 unless the X-Reas is really a significant added value and not a reliability risk. Then the Sport model becomes my next choice.
Robert
I see your post about the new Appearance Package for the SR5. Were there any other new options announced ? (Such as maybe the X-Reas suspension on the SR5.)
Robert
As for reliability, there isn't any history with this type of suspension so there is no way of being absolutely certain. However, with that being said, the system is TOTALLY mechanical, so there should be no inherent reason for it to fail. If it does, it just will not compensate the way it does and should work like a vehicle without the system. I would guess that Toyota would not put the system on their vehicle unless they did some VERY extensive testing themselves to prove its reliability, so I wouldn't have too many concerns.
Hope this helps.
Ken
My concern about the failure modes came from seeing the rubber hoses coming from the top of the shocks which carry the fluid across to the opposing shock. Those hoses will be subjected to continuous flexing as the wheel bounces and if a hose ruptures you would lose all fluid for 2 of your shock absorbers. I guess this is no different than the brake lines on every car in the world.
At some point in the life of the truck the shocks will need replacing and I am guessing they will cost more because of the extra plumbing attachments and fluid replacement.
Thanks again,
Robert
We may be limited to Toyota replacements if we want to continue the XREAS.
Does it actually help keep the rear glass clean ?
Does it increase the wind noise heard inside the truck ?
Thanks for the help,
Robert
I'm going to specify, however, that it is a rear wind deflector that actually draws air down from over the vehicle. There are some that I have seen out there either from aftermarket places or for other manufacturers that are just extensions on the top of the hatch. All of the Toyota ones that I have seen actually come up slightly above the level of the roof and have a "pass-through" for lack of a better description to draw air down over the rear.
Hope this helps.
Ken
I had a Ford E-150 full size van many years ago. I put an after - market wind deflector on the roof of it for the same intended purpose. If I had my rear door windows popped out and it was raining, rain drops came in. That didn't happen before the wind deflector, so they do work to reduce the vacuum. That wind deflector was about the same size as the 4 Runners. As for additional noise, I am not aware of any, but I like my 10 speaker stereo up fairly loud
Thanks for the feedback on the deflector question. I can see that the Toyota deflector does have the "pass-through" shape so that it should move air down across the window. I personally prefer the looks without the spoiler but a cleaner rear window would be a plus.
I have a lot of respect for the Toyota engineering team but I must say that the fake hood scoop on the Sport model made me start to question other design features. I know it is an appearance thing that some people like and probably does no harm (other than catch dead bugs).
Thanks again. This board is a nice resource to have and I am just full of questions.
Robert
Thanks for the responses to my questions. I see you bought your '03 Sport on New Year's Eve and I got a kick out of your comment about the salesman saying you were his 1st customer to plan off-road use of your 4Runner. I am getting the same reaction to my questions about skid plates, ground clearance, mud traps, tires, etc.
I guess that is why they have built so many 2WD models. Like others on this board, I really want a 4x4 Sport model without the moonroof, running boards, 10 speakers, etc. Here in NC, all Sports have moonroofs and 10 speaker upgrade.
I hope you are enjoying the new truck.
Robert
Truth be told, I only got the spoiler because it was part of a package and I wanted the other items in the package.
In the case of the 4Runner XREAS, is it nitrogen gas that is cross-linked between the shocks ? I had the impression it was hydraulic oil that was channeled through the tubing with a low pressure nitrogen chamber in the center.
I still do not understand the mechanics of the external connections between the shocks.
Robert
Can anybody tell me why? And by the way when the light is on, the gas meter also points to almost the end.
Thank you folks,
creswei
The XREAS was a development between Yamaha and KYB Shocks. I hear ya in terms of the what the cost may be in terms of replacement. But, if they are anything like my Bilsteins on 86,92 and 97 4Runners, they should last a good 150,000 without any problems. My 92 has 197,000 with the Bilstiens from the getgo and still work very well.
Regarding the implementation of XREAS, I don't think most people realize is that Toyota had the XREAS option on the older 2001-2002 4Runners back in Japan. Therefore, I think they probably worked out most of the bugs by the time it came here on the new 2003 model.
Tak
My 2000 4runner had the same problem, and was fixed under warranty (albeit back in early 2001 while under 15,000 miles).
I know that Toyota recommends using premium unleaded on the 03 4Runners. Am I risking huge problems in the future if I ignore this recommendation and use regular unleaded? I would appreciate any input/advice.
( TB- ELO10-00 ) for this problem. (That is from post 139 on this forum.) Read posts 34, 35, 45, 59, 70, 77, 86, 87, 90, 112, 114, 132, 138, 139 from this forum.
My 2001 fuel gauge works fine, about 16 gallons when the light comes on. Read all the posts I mentioned and you will get a better idea of the fuel gauge problem.
I proposed a tire swap for (270/70/17) -or any other combination- but my Toyota dealer did not want to do it because of warranty issues.
I tried to contact Dunlop (the product manager for the SUV line) with no success to see if they will come with new type of tires for off-road use.
I'll be very surprise that Dunlop does not add new type of tires when both the 4Runner and the Lexus are using the same size/brand.
I also check the "off road history" of Dunlop/Goodyear and their are very prone to side puncture.
Pat 84,
What kind of answer did you get from your inquiries? I agree that most dealers are very surprised that some people want to take this car off road. I got the comment (after I bought it)that the 2003 4Runner is no more than a highlander on streroids.
However there is enough room under the hood for an extra battery and an air compressor. Not to void the warranty I will ask Toyota to install them as well as off-road lights and front bar.
When ask about the cranking power of the battery I got two different answers 600cc and 1000cc. As for the alternator I got 110 and 160. Do you know which one is correct? Is it the same battery that is used on the 2002 model?
Any information on off road products made for Toyota 2003 4Runner will be appreciated. Also did anyone try to buy the shop repair manual from Toyota?
SINCERELY,
Amara2
Has anyone tried it yet? I would be curious to find out.
http://www.miata.net/garage/tirecalc.html
I would go with a 60 series tire because it is fatter than the 65 series OEM. A 70 series tire is more narrow than the 65 series. I plan on taking my 4 Runner on the beach where a fatter tire would be better. The 70 series tire may be better in snow because it will have less rolling resistance. I wouldn't recommend going too far from OEM as it can effect ABS, and cause speedometer and odometer error. You wouldn't want your warranty expiring too fast.
The taller size would add a bit more height for clearance, which would be nice.
The shorter, fatter tire would be nice for handling, but might ride a little rougher due to less rubber from the wheel to the edge of the tire. For the spare, it might hang lower as well.
Internet vs. Traditional Car Buying
I work in a dealership and I see how thing go on this end. The customers who tend to be the most satisfied are the ones the hook up with one of our more intelligent salespeople. The trick is how to end up with this person. I suggest calling the dealership and asking the receptionist who the most easy going and most competent salesman is. The operator will know. Then, set an appointment with that person.
You need to do your homework before going in. Have printouts from Edmunds handy, including TMV figures. If he can get to TMV or less, and you are satisfied with the process buy it and count yourself as lucky.
The width of the fatter tire is much greater as can be seen in the End view. The white lines are the size of the OEM tire. You may be right about the traction control getting confused by an OEM spare tire. The use of a different size tire offers a greater selection of tires as well.
For those who have not figured this out yet, Toyotaken is doing a REALLY good job of answering product questions. He obviously has access to Dealer Daily (our Intranet with Toyota) and is willing to share everything he can. Not that I'm giving up posting here, but Ken has been doing a great job.
Do not get a used car extended warranty.
Get the point? The vehicle is still under the 3/36K basic warranty and therefore still qualifies for a new car extended warranty. The new car warranty from Toyota covers a ton more equipment than the used car one. Included on the list of stuff covered by the new car but excluded from the used car is the CD player, traction control system, sunroof cables (a very expensive labor job), ignition coil, speedometer, charcoal canister and the heater core. There is a LOT more.
MSRP for the 6 year or 100K Platinum warranty is $1300 on the 4WD Runner. Actual prices vary (sometimes, a lot) and you don't have to buy it from the selling dealer. If you choose to go this way, insist on only the genuine Toyota Platinum warranty.
pat84 - I was just referring to the height difference in the rubber with a taller series tire. There is more rubber to soak up the road imperfections and does a better job of flexing for off-road. There is a little bit more "cushion" in there between the rim and the road.
You're right about the width, there is more rubber on the road.
If you are not going to keep a new vehicle but three years, they are a bad idea. IMO, Ainslb's situation calls for a 'new car' extended warranty.
Hope this helps.
Ken
I know that is a stretch. I think the real reason is they don't want to admit complete failure to read the market reaction and will use the "sport" thing to justify it.
&nbs- p; &n- bsp; : )
&nbs- p; &n- bsp; Mackabee
