A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Then I took the SR5 V6 out. I definitely like the ride of the SR5 better. It was a little more car like, more giving over the bumps. Body roll didn't seem that bad. Of course the only test I did was to zig zag while driving down the street and go around a few sharp corners on some back roads. I didn't do any kind of high speed cornering test so maybe the roll would be more evident in that situation. The wind noise was also noticeably less in the SR5. An earlier post I read speculated that maybe it was the hood scoop generating the extra noise. This seems like a reasonable theory to me because that is the only aerodynamic difference between the two that I'm aware of. The V6 power was nice although you could tell it had to work a little harder to get you up to speed under heavy acceleration. I don't see power being a problem with either engine.
The JBL stereo sounded good and is something I would definetly want. I am a music lover though, so maybe a lot of people would be satisfied with the standard stereo.
Overall I really like the SR5 V6 better and am looking a trading my 2000 Honda CRV for one. I visited a dealership in Denver and the Internet Manager quoted me a price of $500 over invoice. How does that sound for this area? I do notice several of them on dealership lots so I wonder how well they're selling right now.
I also have what may be a dumb question to some, but what is the advantage of 17" wheels over the 16"? Also I'm looking at doing a special order because I want to get one without the sunroof but that has the JBL stereo. Will I be able to order one like this or will I have to get the sunroof to get the upgraded stereo?
MrWhipple...thanks!
-The ride will soften up considerably within the first thousand miles. I'd guess this will be true for both the standard and X-REAS suspension. If a car-like ride is a major item for you and you're going for the V6 anyway, you might want to drive a Highlander before ordering a 4Runner
-I'm guessing that when you drove the SR5, you managed to avoid headwinds, and encountered them while driving the Sport. Headwinds, even moderate ones, make a colossal difference in cabin noise, much moreso than any other vehicle I've ever experienced. Headwinds also dramatically increase fuel consumption at Interstate speeds. Wind is your enemy in this truck!
-The 17" wheel comes with slightly bigger brake rotors, always a good thing IMHO. Otherwise, the only difference is cosmetic.
-Karl
Doc fees may vary, too, so check those out.
I hope that helps.
Steve
-Jared
I have driven a Sport model and thought that the handling was very good but have not had a chance to try a Limited without the X-REAS. Is there a big difference in the handling between the two?
Roger
The Limited's around here all have X-REAS. I test drove an SR5 that didn't have it, but it was a pretty short test drive, whereas my drive in the Limited was longer. I didn't notice a huge difference during that short time, but from what others have said I believe it does make a difference.
Ken
Nippononly - my brakes used to pulse a little at highway speeds but that has subsided (I'm not sure how or why). As per the 4 technicians who have looked at the truck so far, the brakes and rotors are OK. I'm going to check further into that anyway.
KHAUG - I actually found some info about that Haweka adapter on another internet site and inquired at my dealership about it. Very interesting to find out that these factory wheels are lugcentric. Wonder why Toyo would do such a thing when they know very few tire places are capable of properly balancing them? Anyway, the service guy at my dealership said that they do have the adapter and the newest version of balancing machine, but it is in their new service building that is under construction and is due to be opened in next few weeks. He said to bring the truck back and they would work on it for free until they get it right, even if they have to take it to the new bldg.- wonder how long that will take. Stupid me, I forgot to get his name, too. We'll see how it goes.
Beagles3- the truck only has 50K on it and has never seen anything other than paved road -albeit NYC paved roads which in some spots can get pretty rough. If it needs shocks already, I'd be surprised, but I'll get them checked.
Hopefully, I'll get this resolved pretty soon- I've been dealing with it for a while and now I have the time (and $$ if nec.) to get it fixed.
Good luck....I loved mine and when i traded in last month, i got a 2002 Limited:)
The other version you are seeing are the ones the dealers are just spraying color over the gray cladding, which have the square notches in them.
The factory package is much cheaper and will hold up better.
I also got to drive another V6 tonight. I was giving some thought to going with the V8 but I think the V6 will have plenty of power for my purposes. Does anybody know if the V6 is steel sleeved? I just want to know that when I get several years down the road that boring and rebuilding is a possibility. I hope it isn't a throw away aluminum engine like the Chevy Vega was in the early 70s.
Also the salesman that I talked to tonight said the SR5s with the AP should be coming out sometime in March but that the Sport models would still have the same gray cladding. I know that people have been hearing it both ways so I guess we'll have to wait and see what the truth is. But I thought I'd pass along what I was told.
Some dealers already have them on the lots.
I also assume that it throws the speedometer off a little, is this correct?
I guess I should be careful about all this assuming... But the 17 inch wheels look pretty good.
2. I checked with other sources on the Appearance package and was told with 100% certanity that the Sport will be offered with the SR5 appearnce package. They will be available in about 1 month.
If you are very tall, with very short legs, your head may not be under the sun roof. You would be used to having such a tough time buying clothes, that having a little less head room would be a small problem by comparison. .
I am by no means mechanically inclined so I need to solely rely on your honest input here. Thanks you for hearing me out and hope you can assist me.
I'd be skeptical about adding the X-reas after the fact.
Perhaps a reasonable solution would be to trade them vehicles for one with the options you paid for. They could turn your present Limited into a demo.
I know this sounds crazy, but my wife did this exact thing. Her Saturn was totalled in an accident that was the other driver's fault. She bought a Nissan Altima while I was on a business trip. It didn't have ABS. I said, "Well here's what happens when you stop at the dealer next door to the Saturn dealer and buy a car." ( they are right next to each other) She called the Nissan dealer and said she wanted ABS. They gave her another brand new Altima with ABS and (side curtain air bags because it is an option package) and made her first Altima, with over 300 miles on it, into a demo. I was dumbfounded that any dealer would do this. They did charge her for the additional option package. So it's not a totally unreasonable request.
In Atlanta I have seen 18" tires on some 4Runners. The tires would have to be 265/60R18 in order to keep the same height and circumference.
Generally speaking the lower the overall aspect ratio of the side wall, you will have better handling on the road. That would be the 18" tire. With the higher aspect ratio you would have a better ride and with more flex in the tire, better off road handling. That would be the 16" tire.
So if you like the 17" rims, the clearance and speedometer should be the same.
-Jared
So I guess that I would say that it isn't impossible, just not very feasable.
Hope this helps.
Ken
I AM CURRENTLY IN THE MARKET FOR THE LIMITED 4RUNNER 2003...I HAVE BEEN TO THE DEALER 2X'S TO DRIVE IT....WHILE WAITING IN THE SHOWROOM, I OVERHEARD ALL THE NEGOTIATIONS GOING ON...I HATE THAT PART..I FOUND THE SALESPEOPLE NOT BUDGING MUCH AND HIGH PRESSURE. I READ THE INTERNET BUYING VS SHOWROOM..HOW MUCH DID SOMEONE PAY FOR THE LIMITED AND THE SPORT, I NEED A FIGURE SO I KNOW WHERE I MIGHT STAND BEFORE I START THIS NEGOTIATING AND TO SEE IF IT IS FEASABLE OR NOT. I REALLY DIDN'T WANT THE 2002 MODEL...I ALMOST WOULD BE WILLING TO WAIT ANOTHER HALF A YEAR IF I HAVE TO...PLEASE HELP ME. I HAVE BEEN WANTING ONE FOR TWO YEARS..I WANT TO FEEL COMFORTABLE WITH MY NEW DEBT....
(And all caps are hard to read, ergo the yelling comment)
Thanks for the help
I found better prices online than I did at dealerships themselves after talking price. Saved about $450 between discount in price and having no doc fees.
