Visitor Agreement.
I took the wire in "2" position on bottom out but didn't shut them off. I thought that's what the TSB said but guess I misunderstood. Any help??
Anyone else notice that the Toyota 4runner is considered a midsize suv, yet the Hyundia Sante Fe is consider a compact suv. Both the length and width of the Sante fe is bigger then the 4runner.
Any one have any idea what a new aluminum wheel goes for?
Joe
Joe
Thanxs!
I have a 2000 SR5 and there is a black plastic U bushing
that is located where clutch pedal arm and spring meet.
It wore out and broke off at 8k miles. I had it replaced under warranty.
It just broke again at 16,500 miles. I have to take it in again.
After the this bushing breaks, the clutch pedal becomes harder
to press, and squeaks A Lot. Anyone got any solutions or
suggestions?
As far as Toyota quality, I haven't been really impressed.
You may want to visit your dealership to get them to check the alignment and the other suspension components. I smacked a curb quite hard a few years ago (40 km/hr, downhill, black ice + snow...nothing that I could do) and managed to slightly bend back the lower control arm of my minivan, ruin the wheel bearing, as well as break a 2" chunk off the aluminum rim. Was an expensive mistake...just a few months ago when I went to get new tires, the tire shop could not align the front wheels properly + centre the steering wheel. I brought it back to the dealership and they in turn took it to a frame specialist shop. Apparently there was some very minor frame damage and they had to straighten it out a tad. No charge though, to my shock! The service guys at my Chrysler dealership are great.
Good luck,
These shocks have 5 settings, with 1 being a softer street ride.
HP
Good luck
HP
thanks,tclub
Again, I don't have any real information on the new Runner but I would be absolutely shocked if it didn't get a power upgrade. I will post any rumors I hear as soon as I hear them. I want ya'll up to date just as much as you do.
EXACTLY the same thing has just happened to me with my 2000 SR5 4WD at its 20,000 mile service. The brakes had always been absolutely silky smooth. As soon as I drove away from the dealership I noticed a very distinct pulsation or modulation that clearly felt like it was from the REAR brakes. I had asked the dealer to rotate the tires and verify the remaining brake lining thickness, so they definitely pulled ther drums. I suspect that the mechanic either did not properly torque the lug nuts, thereby distorting the drums, or did not "re-index" the drums on the axle flanges in their original orientation. I haven't taken it back yet, and the shuddering has diminished slightly, but its still quite distinct, especially at 50-70 MPH when the brakes are cold. Anyone else have additional insight?
1. I know every bump from here to Canada. This SUV is not very forgiving on rough roads.
2. The cruise control downshifted a lot on hills, sometimes getting near the red line. I turned it off after awhile.
3. After 5,900 miles, I got 19.889 miles to the gallon.
4. Gas is 75 cents a liter in New Brunswick and 89 cents a liter in Newfoundland. 40 to 50 dollar fill ups were common, (Canadian money).
5. Rest rooms are called Wash rooms and a soft drink is called a pop.
Overall the car performed beautifully. It went in a lot of out of the way places and it never had a problem. I was amazed how much it carried and how well it handled with all the weight.
I am 6'5" tall. Is the 4runner big enough for me? I have looked at the bucket seats inside the 4runner - they appear tight and narrow. Has anyone out there any information about whether or not these seats will flatten out?
BB
Now, on to your actual question. The Runner is clearly superior if you plan of doing any off roading or towing. It has a (arguable) better 4WD system and more cargo area. There are much better deals relative to invoice and most regions have rebates on them. The HL is far more comfortable on the road. It is more refined and corners better. It has more back seat room.
Decide which one best suits your needs and which one is affordable to you. I'll bet there isn't much difference in overall cost when you get down to actual transaction costs.
They rollover, they lose control too easily.
They ride like a big MACK truck or something.
It's BAD [non-permissible content removed]
Consumer Reports that they also tested the 4Runner and it did not exhibit the roll over on two wheels found in the Montero. I am sure he is upset with Consumer Reports. Having said all that, I know I cannot treat my 4Runner like my sports car. Yes it does have a high center of gravity as all SUV's and should be driven with that in mind.
I don't think it's the wheel balancing, normally when wheels are improperly balanced you feel the shimmy at highway speeds. My problem is strictly with bumps(large and small).
Countsmackula1,
Thanks for the input, I've talked with a couple of people at work who own Toyota trucks, they seem to have the same problem.
Cliff,
I have noticed that when the engine is very hot, accelerating (usually after a complete stop) makes very loud engine noise before it shifts gear. My experience with SUVs I had owned is the opposite, the engine is usually louder when it is cold.
Is this normal for 4Runners? please let me know before I take it to the dealer this weekend. It is a 2000 SR5 2WD. Thanks
