I'm not sure how this is related the LaCrosse.
The owners manual says to check oil every certain length of time. I check mine at least once a week and at gas fills on long drives. I do that for sure with a new car.
The quality name brand oil filters don't clog in 3, 4, or 5000 miles. I suspect they don't clog in 8-10,000. My leSabre manual doesn't say to change the oil filter during the time the oil goes 10,000 in ideal conditions.
The oil life does not measure the oil level. There is a separate sensor for that on SOME cars. I do not know if the Equinox 2010 is one. I would think it does have one. But the driver is responsible for reasonable care in checking oil levels.
Engines, though, are among the least prone to premature failure if the design is good, and it gets proper, regular maintenance. Very few owners actually interpret the correct oil change interval when they look at "normal usage" and "severe service". If you read carefully between the lines you will see that the vast majority of us actually fall under severe service even if we never venture onto a dusty road, for example.
You have a far greater chance of auto tranny failure or other assoc driveline issue, (especially on AWD systems) than you ever do with the engine itself.
And coolant changes are also quite important, but not as important as never ever overheating your engine even once. Once is all it takes to have huge and expensive ramifications down the road.
Anyway, I might be chatting above your heads here. I'm sorry if I am. I am a mechanic and not just talking through my hat.
This is where I will use the proverbial phrase...YMMV.
Not here. I rebuilt motors when I was in high school and have degrees that enhance my understanding of the technology.
I fail to understand how you're saying a new engine is going to clog the filter short of a catastrophic failure of something within the motor...
One thing I will mention that has changed over the years is there is less crosshatch cylinder debris on newer engines, which in years past contributed among the greatest quantity of debris. But I don't intent to get into some sort of squirting match with you. If you can't see the positive advice I have taken the time to attempt to share, then that is your loss.
>2010 Equinox owners have discovered a number of their cars burning excessive oil.
And some finally showe up at the dealer wondering what all the clattering was about. To find that there was no oil left on the dipstick.
>I think you were very wise to do 'premature' oil change at 3000 miles. 1000 to 1500 would have been better still of course. So few do nowadays, but they don't understand that as the oil filter clogs prematurely with initial engine wear, the bypass valve opens in the filter and all the unfiltered oil is free to circulate the engine.
I'm waiting for your explanation of "initial engine wear" that clogs the oil filters and causes the Equinoxes to somehow burn their oil...
I doubt the cylinder wall wear emits enough particulate matter to clog any quality filter on a modern car to a noticeable degree and especially not on a new motor during the first couple of oil changes.
My first oil change on my last new car went the normal mileage. That's what this discussion is about--how long a laCrosse owner should go for the first oil change... so the discussion is relevant to the topic at hand.
My advice drive it and change at whatever is going to be your regular change interval. GM put in quality oil at the factory and a quality oil filter.
>If you fail to do that then I won't debate further with you and will be inclined to suspect you are trolling.
I recommend you report me to the hosts as a troll. LOL.
"And yes, filters will clog prematurely from a brand new car and leaving your first oil change too long."
Key words, again.....are TOO LONG.
And please, I never once said anything about that being the reason the Nox's were burning oil. How would anyone know at this point that was the cause? So quit trying to strengthen your argument by putting words in others mouths!
And you reiterate in agreement with my crosshatch remark, yet you manipulated the way you said it to try to make it look like I wasn't acknowledging this difference in a modern day engine. If you think your oil filter is so clean after its first replacement, then set your (self-proclaimed) degrees aside for a moment and get your hands dirty enough to cut the filter open and look for yourself. If it's so clean you shouldn't have any problem spreading what's there on your toast. :roll eyes:
And yes, if your argumentative inclination is considered tolerable by whatever mods are here, then let's find out. If you are a person of honour you will report yourself. Otherwise let's publically ask others here and/or a mod whether they perceive you as attempting to b**l bust or not?
Why do people do that? They hide behind their computer, leave crucial context out of what has been said all in pathetic attempt to give some perfect stranger a hard time. It's warped and sadistic. Is that what your (self-proclaimed) degrees have done for you? I have a couple of people looking over my shoulder here that all agree to not take you for real, so we're done with you. And i have been far more considerate to your enquiring post than you have been to me. But that's all you get.
As for your LOL'ing, that is what we all did simultaneously here when you quickly pulled the degree card out into play, heeheeeheeeeee
I will bow out of interaction with you here on this thread now, you can be master of your domain again here where it sounds like you have a mod in your pocket, so don't sweat it.
You are either not aware or forgot the 10W40 issue from a number of years back. It resulted in sticking rings and excessive oil useage. What I heard was that it was only Valvoline causing the problem, factory fill as well. So as not to point the finger at Valvoline, GM said stop using 10W40.
And I damaged an engine running Mobil 1 or so I thought. The engine called for 10W30 and I used 10W40 for two years with an annual change. Then the parts store had some 10W30. I noticed that there was a big difference as I poured it in and noticed it looked more like regular oil. By 6K I had used a quart. by 8K I had used two quarts. By 10K I noticed it was looking pretty nasty on the stick and I changed it. I bought a new case and noticed this looked more like the Mobil 1 10W40 I had previously used. Engine continued to use oil. I called Mobil and after some time the guy on the phone admitted that regular and synthetic were bottled on the same line.
A cousin was an oil jobber. They took base stock and mixed in the secret ingredients per formula of the brand and then distributed. I don't know that oil is done this way anymore, but this had been a common practice with many products, especially if water is a big component. It saves on distribution costs. Example bleach. The concentrates are shipped to a local plant where it is diluted, bottled, and labeled.
Point is, if someone made a mistake would you even know what happened when you started using a quart every thousand miles?
Engine Oil - A slippery subject Part 2
Check your carspace email.
I've read the manual and cannot get the memory seat to work as described. What am I doing wrong? Tips and secrets are appreciated.
Tip 1 when set the memory, push memory button first then push #1 or #2 to set memory (reason, the index finger tends to touch the #1 button before the thumb touch the memory button) and it moves the seat instead to set the memory
Tip 2: push and hold button #1 or #2 until it gets to the final position, release halfway will stop the move.
I am still waiting on the proper Wheel Locks since 10/2009.
1. If you use the easy exit system, the seat moves back when you open the door to get out, but when you come back in the car, about 50% of the time it just stays way back, until you press and hold your memory seat position to return it back to the normal position.
2. The press and hold system is the stupidest thing possible, why not just press and release the memory button?
3. If you have programmed the key fob to the driver, that does not work either. For example, I have a key fob and my wife has one. If she unlocks the car using her keyfob, the memory should automatically adjust to her settings, and vice versa. That doesnt work.
I have a CXS which just crossed 5000 miles.
That's the way it is designed to work and that's what my car does - every time.
The seat moving back and force should be tied to the ignition being turned on / off and not to the door opening and closing.
You are using the FOB to unlock each time?
Do I have it right from the posts?
I'm hitting the unlock button on the FOB
I have had this to a dealer who says nothing wrong. I am taking to a second dealer to see if they can get to the bottom of it.
Has anyone else noticed this and if so what was done to fix it. As it is now it is somewhat on the dangerous side if I need to get out of the way of something.
If it senses you want slow easy, economical driving patterns, it will give that adapting over a period of time.
i am waiting for the new software also...it gets tiring to hear the dealer say "I've never heard that happening before!"
1. AM Radio Poor Reception
2. Memory Seats
3. Side Alert
4. Wheel Locks
5. Engine Oil %
6. .......
Thank you all for helping to identify and resolve some of these issues. My main take on these are that we should not be trouble shooting these, GM/Buick should be. Dealerships should also be aware of these issues, too.
I know these are somewhat minor issues, but they are the kind of things that make an owner loose confidence in a Company/Manufacturer/Dealership, etc.
What is your opinion?
I was hoping that others would identify and post the RFAs that they experienced.
Maybe I have missed seeing them on this forum. If I did miss them or you have not posted them, please let us know so we can be advised ASAP, rather than waiting until we go in for service. Thank you.
Type Number Description Posted Date
YT 09279 Trans Shift Cable Engagement Inspection 10/16/2009
YT 09295 Power Steering (PS) Fluid Leak at PS Pump 11/09/2009
YT 09319 Battery Drain 12/08/2009
Service Information Items
EI 10009 Chemical Damage on Inner Surfaces Fuel Tank 02/03/2010
EI 10030 Keyless Access System Passive Entry-Start
Key Fob Inoperative (PIE0050) 02/19/2010
But as has been mentioned, if you were more aggressive with your shifts/accelerator pedal (i.e burn more gas forcing the tranny to relearn a new acquired desire that may only last until you get to work trying to not be late) then it can learn that you want it to shift sooner. And can relearn that you want more sedate shifts later after measuring a softer touch for awhile. But this very thing is why I maintain we ALL would still be better off with manual transmissions. And if you can drive a manual and understand what it means to transfer/balance/manipulate engine torque to the wheels, and then to the road, then it proves a greater confidence behind the wheel. Anyone who can drive stick, usually are safer drivers when the roads turn slippery too.
Anyway, at least in Europe they still offer many manual trannys in a greater choice of cars. And they manage to do autobahn speeds with no more incidence of crashes than here. Imagine. Over there they drive. Here we (most) are basically only sitting behind the wheel.
Yes, I sure could see that alright. And in stop and go on freeway parking lots of course.
I meant to mention that what you described earlier seemed extra unusual though. It sounded like the engine lacked power and responsiveness to a greater degree than just caused by lazy tranny shifts. Let us know how it turns out ok? and good luck
Don't forget, you can make the tranny shift into lower gear by manually moving the shift lever, so you might try that the next time it seems extra lazy on a bad hill. Just don't forget and leave it there of course..
It really seems to in a gear and seems not to shift (up or down) or accelerate - there is a long pause and then it will kick in. It is hard to duplicate but scares one a bit when it happens. I will drive more aggressively to see if it changes anything.
car salesman about the field checks or service updates he said that they routinely check for any outstanding items not eliminated at the manufacturing plant. He had the answer right away so we felt comfortable that all outstanding RFA's had a standard procedure to make sure they were "cleared". You post alerted us to that concern so we asked. BTW, the car has been oustanding after 2K miles only.
The dealer ordered the part and it should arrive in about a week. The fix appears to be an elaborate job as it will involve removing the seat to install the new module. I hope the techs are well trained because I would be upset if they make matters worse by improperly reinstalling the seat. Nonetheless, I will give an update as soon as the problem is corrected.
http://www.sandyblogs.com/techlink/2010/01/memory-seat-functions.html
With no load the engine would rev fairly quickly. But with a load the revs are restrained and therefore the amount of fuel added. Therefore the computing for the tranny shifting would be delayed because of time lag. A faster/better computer system might be helpful.
On the shifting end of it, everyone seems to agree that using the paddle shifts has a big delay. I've tried it and find it near useless. And if you find yourself in a situation where you suddenly desire manual control, you have to reach to the shifter. My thinking would be that using the left hand paddles to engage/disengage that mode and the right ones for actually shifting would have been a much better design. And maybe incorporating in the mode one a double switch requiring activating both front and back of switch with a squeeze so you don't accidentally engage. This could eliminate a safety/durability delay that might be in play.
While in the city I was trying to park as close to the curb as possible when I scratched my brand new 19” wheels. Upset that I had damaged my wheels I left the car disoriented with the fob in my pocket but without shutting off the engine. When I returned about two hours later the car was still running. By the way, I was in a building across the street some 60 feet away.
My question, is it possible to drive the car away without the key fob (transponder) being in the car? And if so, how far away can you drive without the engine cutting off?
Don't feel bad. At least we both did it and how many more have done it or will do it?
I did the same thign to my rim. Have you looke dinto any options to have it replaced? Would this be worth an insurance claim?
