2010 VW Golf
VW has decided to drop the Rabbit name for 2010. It will be renamed to Golf. This will be the official discussion for the 2010 VW Golf. There will now be a GTD trim. The GTD will be a sporty diesel trim. The engine will be the same one used in the Jetta TDI which is a 2.0L 140 HP engine. The 170 HP doesn't meet the US emission standards so they must use the 140 HP engine.
Here are the trim levels that are preliminary. You can choose between 2 or 4 doors.
2010 VW Golf GT 2.5 Auto
2010 VW Golf GT 2.5 Manual
2010 VW Golf GTD 2.0 Auto
2010 VW Golf GTD DSG
2010 VW Golf GTI DSG
2010 VW Golf GTD Manual
Option packages will be Cold Weather, Tech, and Sunroof. Sunroof is now available on the 2 door models.
For the first time non GTI Golf's will get an optional Navigation system. This new system has a high res touch screen display and a 30 GB HDD. The Hard drive stores both the maps and a 18.62 GB partition for storing your favorite tunes. VW was even nice enough to include a Media-In connector for playing your favorite tunes. The Media in does work with iPod's but you must purchase part number 000 051 446 C which is a special Media-In to iPod cable. You can't use the USB cable with the iPod sync cable since that won't work so keep that in mind. VW might deploy new radios for 2010 that support the MDI. That way you can have the MDI and not have Navigation.
Hope this helps for now.
5K129M Golf 2-DR 2.0 TDI Automatic
5K12S1 Golf 2-DR 2.5 Automatic Federal
5K12S3 Golf 2-DR 2.5 Automatic Federal
5K12Z1 Golf 2-DR 2.5 Manual PZEV
5K12Z3 Golf 2-DR 2.5 Automatic PZEV
5K149L Golf 4-DR 2.0 TDI Manual
5K149M Golf 4-DR 2.0 TDI Automatic
5K14Z3 Golf 4-DR 2.5 Automatic PZEV
5K14S3 Golf 4-DR 2.5 Automatic Federal
PZEV is only for a few states. The 2.5 4-door can't be had in a manual. Only the 4 door TDI can get a manual.
Colors are:
5R5R Reflex Blue
8E8E Reflex Silver
A1A1 Black
B4B4 Candy White
G2G2 Tornado Red
P6P6 Shadow Blue/Graphite Blue
X6X6 United Grey
Options are
3FE Power Sunroof
8JF Xenon Headlamps with AFS
P71 Navigation System
P73 Technology Package
W79 Cold Weather package
The good news is that all these options are available on the Golf TDI regardless of how many doors it has. The tech package might be the Navi, MDI, maybe dynaudio, and backup camera.
Here is the new preliminary info.
Any ideas as to timing, or pricing, that you can share? I'm in the market but can afford to be patient.
Thanks for the info. Good stuff!
I'll be waiting patiently. Hopefully, the tdi golf will barely clear 20k. I'm trying to stay @18k. The tax credit and potential govmnt bailout may make that possible.
RV, can you confirm that the 2010 Golf TDI four-door, 6-speed manual will be available with xenon headlights, cold weather package and sunroof? That would make it the perfect car for me!
Thanks for your info. Where are you getting it?
Jay
The info that I've posted is preliminary and subject to any changes without notice.
http://media.vw.com/article_download.cfm?article_id=10477
Hmm, cloth interior?
Jay
Here is the preliminary pricing. This can change at any time without notice. Only the TDI models can have Nav. Tech package is Nav, high end Bluetooth, Dynaudio, and Backup camera. This is the first time that Dynaudio is being offered in a Golf. The MKV couldn't have Dynaudio due to the speaker placements. The Golf MKVI is made for the Dynaudio system from the get go.
Golf 2.5 2 door $17,490
Golf 2.5 4 door $18,090
Golf TDI 2 door $21,990
Golf TDI 4 door $22,590
Golf GTI 2 door $23,290
Golf GTI 4 door $23,890
You have come through once again. I thank you.
I'm assuming those prices are msrp. I suspect invoice is running 1-1.5k less. Throw in the tax credit and you're knocking on 20k. A little high, but doable.
Courtesy of my-gti.com. This will be standard on the TDI models. The Premium VIII is dynaudio compatible and it's really nice. It's known as the RCD-510 in europe. It won't play DVD's. Supports Sirius, Bluetooth Audio streaming, and HD radio. More info is posted in this thread and yes it does support full iPod integration. Hope this helps.
http://www.myturbodiesel.com/images/a5/buyg/2010golfus.pdf
Answered several of my TDI questions: weight, standard equipment, options, etc.
Looks nicely equipped for the price.
Every bit of insider info. I've gleaned from my VW sources say that GTD will absolutely not be available in calendar year 2009 and there is a *possiblity* it may be offered in 2010 calendar year as either 2010 or 2011 model, most likely with the 140 hp powerplant .
Tell me this, why buy a TDI ,when gas is almost a dollar cheaper.Also, what if , let's say the fuel pump goes in a TDI won't it cost alot more to repair than a regular gas engine?
Lastly, whats the warranty,free service 36K and how much is VW's extended warranty cost ? Their realiability in the past hasn't impressed me.I'd use the tax credit for that. :shades:
Semper FI
Some additional food for thought. I consider a car with 86,538 miles to be well broken-in. My wife and I have a car (gas job in this case) with 260,000 miles on it. While at this point I consider it to be heading for the last round-up, when it was at 173,076 miles (twice your calculated break even point) it was still one of our mainstream rides.
Here is more food for thought to enjoy munching on.
Not only will you make up the difference in fuel cost's by 90,000 miles, you will actually make a PROFIT when you sell the diesel at 90,000 miles.
Example:
$9105 KBB value for 2003 Jetta GLS TDI Sedan 90,000 miles
$5855 KBB value for 2003 Jetta GLS TDI Sedan 90,000 miles
Diesel is worth $3250 more than gasoline model at 90,000 miles. Diesel retains higher resale value.
I hope Ford gets the Focus right and VW 's reliability problems have been ironed out. Ford better get off their duffs and get that Focus here or they might loose out to the competion.
I forgot to mention the Mini, nows the time to get one,if you want one.
One question . How come VW makes a quality, sort off bullit proof car in the GTI, but could never seem to get it right with the Golf? :confuse:
It should be noted that the last 2 years of gasoline Rabbit '07 and '08 have been very reliable (or above average).
NEW YORK, April 9, 2009 -- The Volkswagen Golf was honored as the 2009 World Car of the Year. A jury comprised of fifty-nine international automotive journalists from twenty-five countries around the world chose this year's World Car of the Year, which was announced this morning at a news conference during the New York International Auto Show. "It is a tremendous honor for Volkswagen to have its global best selling model, the Golf, named the 2009 World Car of the Year," said Stefan Jacoby,
I have two acquaintances with early Golf TDI models. They seem to love them. Neither would get rid of them until a better car comes along. VW did suffer from reliability issues over the last decade. My neighbor has a 98 Beetle TDI and would not trade it for anything. His wife drives it everywhere and leaves their big car in the garage.
I have not seen anything but rave reviews of the new Golf GTD (high powered TDI for EU & rest of the World) As usual we get the neutered versions in the USA.
Will the 2010 GOLF TDI engine and auto transmission be assembled in Germany?
Also, will the 2010 TDI GOLF be assembled in Wolfsburg?
Did anyone read the quote from GM vice pres who stated that There is no way to make a respectable case for diesel success in America - or something close to that... Seems like an ignorant statement to me. Very close minded.
I wouldn't drive a GM product if they gave it to me free of charge. I'd sell it and buy either a German or Japanese vehicle.
I know more about cars, and MAKING A PROFIT, than any GM VP.
I think the GOLF TDI will be a great vehicle, and I hope to purchase one.
However, that model is not coming to the USA. So,I'm really lookin' at the V dub,but I remember the auto window motors burning out in the Golf's and alot of electrical and tranny problems. I don't care if thy won an award at an auto show ,give me some owners reviews. I mean reviews of the VW Golf, forget GTI I had one, great machine. The Jetta seems to be selling well,but mostly the TDI.
If Roger Penski can raise the money you'll get the car you want. :shades:
Also VW says the Jetta Sedan tdi and Jetta Sportwagen tdi have the same curb weight?? Called VW of A and they said the same thing - they weigh the same. Impossible right? Someone shine some light on these 2 questions por favor.
There's more data for more years for the near-identical Jetta diesel, which shows a very gradual improvement overall, edging into "better than average" in the last year with sufficient data (2006).
I suspect you were looking at the "turbo" ratings (i.e., GTI or GLI), which indeed are horrendous in early years, but also showed steady but gradual improvement over the years.
Note however that the diesel engine in the new Golf, and in this year's Jetta, is almost completely different from the past VW turbodiesel engines.
Finally, my own VW diesel (96 passat TDI, but same engine as diesel Golfs and Jettas until they went to the higher-tech PD engine in, I think, 2001) has had no engine problems at all through 130,000 miles. But all four door handles have gone once, the passenger front door handle gone twice, the driver's door handle four times (no joke), the front power window regulators on both sides, the hvac controls twice, the alternator, the air conditioning compressor, and the u-joints on both sides and, most recently, the ignition switch (the electrical part, not the mechanical part). Oh, and the outside trunk lock went in the first year--I never bothered to fix it because of the cost--don't remember the amount, but it was totally ridiculous--but use the inside trunk release button. OTOH, the original brake pads on all four wheels are still (barely) hanging on. VWs in general seem to getting gradually better, but we aren't talking Honda reliability by any means even at best.
Marlyece,
Everything I hear is that it will be available in mid-late October. If I had to bet I would double down on early November.
Anyone - Is it true the 2010 jetta wagen will have the front end of the new golf?
Hatchback owners - question here from a never-had-a-hatch before: Is the versitility of the hatch more convenient than a sedan with a folding back seat? Lets hear some real life stories. I'm fired up about this golf. I have so many questions but I'll try and pace myself here. ha
