key stuck
                    I have a 04 Saturn Ion with auto transmission. When I go to shut off the ign. sw. after driving the ign. key won't shut all the way off and you can not remove the key. The key operates just fine. I can start the car, turn the engine off but the key won't turn all the way off to release the key. I was wondering if it could have something to do with the neutral safety switch on the transmission. Does anybody know how I can access it and test it to see if that is the problem? Thank you.
I really love the car, and previously drove an SL-1 for more than 13 years. But this key situation is really disturbing to me. Any suggestions?
Prior to that, they replaced the ignition and "the computer" although I'm not sure which "computer" they were referring to. I don't beleive I have that service receipt.
I just replaced a lock cylinder on my girlfriends car because the only way she could stop the engine was to stall out her manual transmission.
When reassembling the new lock cylinder (stock OEM replacement part) I noticed there was nothing holding the retaining clip in place. The instructions indicate you need to use cylinder material on all four corners of the clip to hold it in place. This essentially means gouging and or bending existing metal material on the lock cylinder pushing it over the retaining clip to hold it in place.
BAD DESIGN!!!!!
no matter what I or how I did it even with a new cylinder I would only get a few turns out of the new cylinder until it reverted to the same problem.
Solution.
Remove tumblers, springs, and retaining clip. Install cylinder..... end of problem.... Of course any key that will fit into the slot will now start the car....
Cheap car, cheap parts..... we get what we pay for...... personally I never have nor will I ever purchase a GM.....
A possible solution is to replace the Brake Transmission Shift Interlock (BTSI) SOLENOID. The Saturn dealership pronounced it "bitsy cell-a-noid" - It is the circuit that tells the keylock mechanism that the car is parked and allows the key to rotate to Off.
I was experiencing intermittent problem whereby ignition key would not remove from ignition switch after automatic transmission is placed in Park.
Stuck key solution was to replace the Brake Transmission Shift Interlock (BTSI) SOLENOID circuit.
New BTSI solenoid fixed my 2007 Saturn Ion when the key would not rotate out of the ignition lock cylinder after car was placed in Park.
I figured it had something to do with the car not registering that it was in park, because sometimes, I was able to get the key out by shifting the gears in and out of park several times.
For a while, I was able to jiggle my key out of the ignition, which left the electrical system on while the engine was off. Eventually, I was not able to turn the electrics off at all with the key, and started having trouble with my battery due to the electrics running it down. AAA replaced my battery under warranty and jump started me several times.
I finally got sick of this, and since I found I was no longer able to remove the key at all, I broke open the owner's manual to find out about the kill switch under the steering column. Not terribly difficult to locate. There's a little panel on the underside of the steering column that I took off, and if you reach inside, there's a button that you push, and Voila, I can turn the car out and remove the key!
I know this is a temporary solution, but it's a free one until I can afford to take the car to the dealer for repairs.
And it seems a consensus that replacing the ignition switch will not resolve the issue. But is replacing the BTSI a more surefire resolution?
any ideas? thanks!
I called AAA and the driver opened the fuse box and pulled the ECM (engine control module?) fuse to shut the engine down. He replaced the fuse and we re-started the engine. The engine ran VERY rough. Hope it didn't damage the ECM. We shut down the engine and I located the battery in the trunk spare tire well to disconnect the negative lead and prevent the battery discharge. Now I'm looking for the "magic" button. I will also try replacing the BTSI solenoid. If I can remember, I'll post my results.
I was told by a locksmith that what happens is that 'a pin falls out' of the ignition and that causes the key to get stuck.
Any news on GM issuing even a bulletin on this item?? It is absolutely ridiculous that a safety item such as this is overlooked.
I had to take the car to the dealer at the behest of the locksmith, as I, unfortunately,l need my car and cannot afford to not have it..
:confuse:
Best,
Sarah
GM Customer Service
however, they were able to repair the cylinder for a very reasonable price.
thanks for your follow up.
Best,
Sarah
GM Customer Service
any suggestions? i have a 2005 Ion and I HATE IT. i have had problems with the starting since may of 2009 and finally this past may one day after driving the dog up to the fields it would not start. tried for 2 hours.
then the above and now this.... so frustrating
any advise?
Oh! I also went to the Saturnalia blog and there is a fix that some folks tried and worked for them. Basically the same - take the cylinder out from the steering column and it requires that you put a drop of superglue on some very small area of it and then installing back. I did not feel brave enough to do myself.
I hear you on the weird problems that you're having with your ION.. it does get tedious.. I don't hate mine though..
Good luck!
Be Well!
What do I do?
We're sorry to hear about this situation with your Saturn Ion. If you had planned on getting this checked into by one of our GM dealerships and wanted for us to check into this further with you, please contact us via email at socialmedia@gm.com and we would be happy to set up a Service Request to document this further and follow up with your dealer (include your name and Edmunds username, phone and address, the last 8 of your VIN and mileage, and the name of your involved dealership).
Sarah, GM Customer Service
I hope to be able to get this resolved without going to a dealer. I have heard the cost of having a dealer work on this far outweighs what it takes to fix it. I don't have a lot of money. I'm a teen, and this is my first car.
If I end up using a dealership, I will let you know.
We're sorry to hear that between Hurricane Sandy, a car accident, and now this, things have been rough. If you wanted for us to check into this further with you and your involved dealership, please contact us via email at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, the name of your dealership, and a brief recap of the situation).
Sarah
GM Customer Service
Now he says my battery and my power steering are shot (neither of which caused trouble before). He says the car is running "REALLY rough" (another new symptom). He replaced two fuses and the spark plugs, but this also didn't help.
The key/ ignition issue seems to be fairly common, and the power steering is an oddity GM and the NHTSA board investigated in later models, but is there any chance any of this could be related to the BTSI solenoid? I had printed your e-mail and casually left it on the seat in case the mechanic needed some advice, but he still seems stumped.... I really miss my Saturn! :sick:
Forget everything you have been told. There is a small micro switch on the driver's side of the shifter. This switch releases key and unlocks doors when tranmission is put in park. Replace this micro switch problem solved watch this video but don't try to repair just replace switch
Ebay listing for micro switch
https://www.ebay.com/itm/302741497377
______________________________________
https://www.howtobecomealocksmith.org/best-security-cameras/
