Visitor Agreement.
I have an'03 V8 with the dipstick.
Good question for the tech. My guess would be there's more going on than just putting in lifetime fluid. Perhaps different seals are involved. Didn't think of asking, but I'm more than comfortable checking/swapping out the fluid per the owner's manual on my '03. Call me old school.
Concerning the lifetime oil and lack of dipstick, this may not be a very big change. IIRC, my dipstick says that the transmission oil does not need to be changed for the lifetime of the vehicle in normal service. It could simply be that once you have temperature and slippage monitoring of the transmission, you can depend on the computer to tell you if something is wrong. You can omit the dipstick and save some money and labor.
Seriously, transmission fluid can be judged in part by its color. If your lifetime fluid gets dark (from overheating during towing or hill-climbing or whatever) instead of it's normal color, it might be advisable to exchange it with new fluid. Don't pull the pan and replace what is in the pan, but allow the transmission to refill itself by pressure through the transmission cooler lines so that all the fluid is replaced.
Replacing all the fluid through the cooler lines prevents you from mixing fluid types which is probably a bad idea. Also, you don't disturb the pan gasket and (since you don't have a dipstick to check the level) you only put in as much fluid as was in there in the first place and can't under- or over-fill it.
Cleaning products for interior:
Be very careful what you use to clean the interior surfaces. Apparently some cleaners will ruin/discolor the soft plastics. I believe Vinylex or something like that is safe
Towing the boat on level ground on the highway probably wouldn't require anything other than the standard system. The more hilly the terrain you tow over, the more you need an aftermarket oil cooler.
If your transmission overheat light comes on, I would definitely get one. If it doesn't, then I would base it on the judgement of the terrain you tow over.
IMHO, if I towed often, I would get a cooler installed just for my own peace of mind. You should investigate the quality of the transmission oil cooler that comes standard on your vehicle and see if it will stand the load, frequency of towing, and terrain you plan to tow with your truck.
Thanks for the replies.
can you let me know what you have used on the exterior and interior areas.
I have an '03 4Runner LTD V8 and want to keep it looking great.
I heard they make great products and want to be sure to get more info before I give the "runner" it's first detailing inside & out.
Add (I'm guessing) 700lbs of furniture, and I could definitely feel it being a bit slower, though it never felt strained.
Interesting, I got pretty decent gas mileage even towing the trailer. Trip computer claimed about 16.5, which means it's probably really 15 or so. Not much worse than without a trailer, however, there are other possible reasons for this. Most of my towing was highway miles. I used mid-grade instead of regular gas. I also may have been less of a leadfoot when towing.
I know my vehicle has an auxiliary transmission cooler. It's like a mini-radiator in front of the main radiator, if you want to look for it.
The V6 has a slightly higher compression ratio, so the horsepower difference between fuel grades should be slightly greater than with the V8, but these are small differences. For more, do a search of this discussion--you'll get lots of hits.
As for the Zaino products bmc5, I like the "wax" a lot. Much more long-lasting than traditional waxes, and easy to apply. Check out the Zaino discussion in the Maintenance & Repair area here at Edmunds.com
Measuring an increase in gas mileage is one way of telling that your timing was retarded and you needed the higher octane fuel in the first place. The mileage increase seen by allowing the engine to run at a more advanced timing setting more than overcomes any small difference in fuel content between premium and regular.
Furthermore, there are greater differences between brands of gasoline than there are differences between fuel content in premium and regular gas from the same dealer.
MY QUESTION IS DID THE 03 RUNNER HAVE A LOW TIRE PRESSURE MONITOR AS THE 04 DOES,IF SO I CAN LOOK FOR AN 03 OR 04 RIM AND TIRE WHICH SHOULD MAKE THE HUNT MUCH EASIER.THE 17 INCH RIMS ARE THE SR5 OPTIONAL 5 SPOKES WHICH ARE THE SAME AS A LIMITED.
THANKS.
1) I need to see Toyota keep up with almost all other competitors regarding options in the 4runners. There is no reason that I shouldnt be able to get a 4runner with NAV, 3rd row seats, DVD system, etc. Its silly that the Toyota engineers couldnt figure out solutions to these roadblocks.
2) Ive seen photos of the 05 Pathfinder and the truck looks hot! I think it looks better than the 4runner AND it will have roomy 3rd row, NAV, DVD, etc.
Here is the link: http://www.infinitihelp.com/Nissan/Models/2005/Pathfinder/Photos.- htm
3) Toyota would be my 1st choice, but not if they fall behind with what consumers are now looking for in an SUV.
4) I doubt that they will do a design makeover for 05, but at least LOAD it up!!!
Any comments/suggestions are always welcome........
Chris
Love the 4R for what it is, if you need that much seating, you should be looking at the Sequoia.
BTW I think that 05 Pathfinder is UGLY, just like that Amarda!!! I checked out the Amarda at the auto show, and everything on it seemed VERY cheap, the controls, door handles, everything.
Just my .02
As long as we're talking opinions, I'll chime in with beanctr and gripe about the fact that Toyota seems to offer the side airbags on SR5s in only some regions--not mine. And I'll second whitney8 and agree that the Armada and next-gen pathfinder look too blocky and tacky for me. If you need a daily driver and sometimes have to tackle the city, and still want the ability to tow and go just about anywhere, the 4Runner seems to be just the right size. It seats 5 adults just fine, and I don't want to have to (every day) wrestle around a vehicle of the size necessary to seat more than that.
My opinions only, of course. It's just that I'd hate to see them dilute or bloat the 4Runner to serve those who should really be considering other vehicles.
I bought my 4Runner to go off road, it could loose some weight. And the remote could be a little louder than tweety bird.
The 4Runner is perfect.
Thanks for any input!
4WD. I have my 4Runner. The guy with the X-5 Bimmer has yet to show up this week. We are going to tell him "It's just for show.".
Just kidding. I'm an LA native and I don't miss it. Even on mornings like this when I had to defrost the Tundra for 20 minutes to get the layer of ice off it, I still prefer this to the mess of the LA basin.
I have the V6 and love it, even after test driving the V8.
No complaints or problems and the truck has been stellar all around.
As for the new Pathfinder, it looks cheap and alot like a Ford Explorer or new Dodge suv. The rear suspension is just like the Explorer meaning it is basically a minivan now. That's good for the soccer mom crowd but not for real suv owners. I'm really glad I have the 4Runner.
oh......the sulfur smell. I got it the minute I stepped out of the truck after taking it home. How many people here have the sulfur smell , how many don't ? Is it just the V8, how about the V6 ?
