Other than the mpg display and the seats, we love the vehicle. The 4 cylinder has plenty of pep (in the non-eco mode) for our purposes. Only time you know its a 4 is when you're merging onto the highway because you can hear it working hard, but it still gets up to speed quickly. Other than that its very quiet and comfortable. Gets decent gas mileage (but not as good as advertised) and we love the look inside and out. Very good fit and finish. Back seats have an incredible amount of room and are comfortable. We've had to haul some furniture and other bigger items and it worked out great with the back seats down. The overall size of the vehicle seems just right for us. Not to big (and we had a Tahoe before) and not to small (we traded in an HHR-way to small). I think most people will like the red ambient interior lighting. Oh, and the cup holders work great for all sized drinks. That was a huge issue in the HHR. Another small thing we've noticed is that the AC doesn't cool you down as quickly as either the Tahoe or the HHR because the vents are smaller. Haven't had it in the real Texas heat yet, so we'll see.
So, do I give it an unqualified thumbs up? No. Do like it? Yes. If the seats were more comfortable and less contoured I think I could recommend it to anyone. As it is, it will depend on if the seating works for you.
Mike
The wraping of the doors under the car keeps mud from getting on pants when getting in and out was a good idea. But there is a mud and slush buildup that occurs at the bottom of each door that an additional weather strip can help prevent. You will see it when you open your doors and look at the very bottom.
In addition to making a better cleaner appearance, in the long run it will help stop rust and paint loss due to exposure.
You can try putting on some weather stipping yourself. The best fit will be up just a little and yet below the drain holes.
Thank you for any help.
Update with our car had us not only a louder tapping than others but we had fuel dripping on the output side of the HP pump. Working with the dealer service mgr and the region rep we got the whole pump assembly replaced. While we still have the tapping sound (high pressure pump noise) it is much softer than before. It also solved the fuel line leak. Due to the direct injection we will all have some tapping noise. We are ok with the car now.
:mad:
Any harm caused by this or is it just annoying?
Where is the GMC bulletin you mentioned?
Ours is an 2.4. The tapping sound comes from the high pressure pump under the hood ( in front to the right center). Ours was very loud, however once they replaced the whole pump assembly because of the fuel leak, it is not a loud as before.
Your service rep can provide you with the bulltin. Have them compare your car to another 2.4 for the sound. Once ours was changed, we compared and we were much better than the brand new one. Before we were louder. There is 600 lbs of pressure coming out of the pump. Best of luck!
I've been online for a couple of hours and cant find anything.
thanks for your help!
Good luck GM.
No engine noises in our Terrain.
Ride is very smooth!!
Try turning it on in the driveway with the windows down before you move. You can hear the tapping. Maybe I'm being over sensitive but I never heard the tapping noise on my other recent vehicles. It's just not acceptable to me.
I was pretty impressed with the combination of the two together –all wheel drive and Stabilitrak.
Driving back on the interstate accross SD run into 200 miles of 40 MPH cross winds - ice sheet on the road with blowing and drifting snow. Semi’s in the ditch along with an estimate of 30 – 50 cars including SUV’s and 4 wheel drives. I watched them flying into the ditch spinning around with loss of rear end traction. Once they lost traction with the rear end the wind would send them flying. 4 wheel drives without rear end posi track would loose rear end traction and wind up sideways and then in the ditch.
I sailed right along and passed everything in sight including a HP who was crawling along. I would pretty impressed with how the setup worked.
Mine is the V6. Gas mileage has been great so far. Of course everything depends on load, speed and wind. Best 100 miles is 26.5 best 300 miles is 25.4 and around town it gets 21. So far I'm pretty happy with the car.
I have not seen the 32 mpg. Around town and some hwy miles I have been getting 26 to 28.5 with the ECO on. Don't know anyone making the 32 mark.
I suppose, that's what V8 owners used to say. :surprise:
Just curious as I keep researching various possibilities for my next car.
Other than the above, so far love the car. Thanks for any input.
I am from GM Customer Service. If you are hearing strange noises then I would take the vehicle to the dealership to have it diagnosed. If you are hearing a knocking noise I would get the vehicle checked to be certain. That way you don't have to worry about it. Thank you,
Mariah GM Customer Service
My dealer has recently told me the Terrains and Equinox are sold ahead of time or as soon as they arrive at dealer.
I suggest placing an order for the Terrain you want. There are no deals.
The Equinox and Terrain are assembled in Canada in the same plant. They allocate roughly 75% to the Equiinox and 25% the Terrain. They supposedly added a third shift but delivery times haven't seemed to have changed.
The Equinox/Terrain are best sellers, dealerships can sell all they can get their hands on. Most being delivered are already sold by by order.
The 2010 model year production may have been stopped for the 2011 changeover.
Thanks in advance.
don
I am going to call my dealer. Will let you know what service department tells me.
I have never used mm.
However, I would also like to see a better explanation of the functions than the manual offers.
Both the I4 and the V6 are direct injected and at idle the fuel pressure runs around 1200 + psi.
Most cars have the injectors placed in the intake track and idle at 30 to 50 psi, but in a motor that uses direct injection the injectors are place so they fire directly into the combustion chamber.
From what I have seen the V6 get sound dampers on the injectors but the I4 does not.
You all should hear my 2008 Cobalt SS with the Turbo Charged LNF 2.0, at idle the pressure is closer to 1600 psi and the injectors are really loud.
I am going to start looking for a Terrain soon, hope I can find one.
