Looks interesting but I wonder if wind noise will be an issue. Pavement Ends make a similar one but I think you have put the removable section inside.
Back to the rebuild. I found a supposedly "complete" rebuild kit online for $198. But, this kit does not include the synchro's or key/keys that mine are most likely in need of. Does anyone have an idea of what these would cost?
I don't have any problem attempting a rebuild. I have never done anything like this before, but I consider myself to be a fairly perceptive DIY'er with a decently equipped garage. But, if I'll only save around $300, then the rebuilt unit is an attractive choice. However, saving $1,000 would be no contest, plus I'd gain some invaluable experience in the process. Tom, the FSM manual you let me use is in .pdf format. I don't have that on my 'puter. I'll have to download it somewhere before I can look at it. Does this FSM have all the tolerances and specialized info included? The only tool I can think of that I might need would be a different sized/shape puller than the three I already have.
Anyway, back to the original question: Will the two swap out with no problems?
http://www.adobe.com/products/acrobat/readstep2.html
I don't know if the AX-5 can be interchanged with the AX-15, but the supplier of your parts should be able to tell you. I'm not sure it would give you any real advantage behind an 2.5 though. The AX-5 doesn't have any more of a bad rep than the AX-15. I would expect to pay around $20 each for syncro rings.
Just give it back to me next time we hook up, and I will take it home and print out the AX-5 stuff for ya.
Or, I think you could download the right program from the Net, and maybe it will even be free... some of that stuff is free.
Don't know if the AX-15 will swap right in or not. Good chance it would, I think.
Tom
Have you hugged your Jeep today?
Tom
http://www.novak-adapt.com/knowledge/transmission_gateway.htm
Gary
They talk about the AX-5 being a minimal tranny. That concerns me a little considering this Jeep will spend more time off-road and on. But, unless I start to mod the engine, which I have no plans to do at this point, maybe I'll be OK.
Mac, thanks for the adobe link and info on the synchro's. Am I correct in assuming a five speed has five synchro's? Or would it be six, because of reverse? And what about the "key" in fifth gear? The guy I bought it from thought the "key" in fifth gear was broken. Is there only one "key" in these trannies? Or are there "keys" for each gear?
http://www.usatoday.com/travel/vacations/destinations/2003/2003-1- 0-10-suv.htm
Check it out!
-twylie
Tell your father to take his Jeep up the backside of Lions back if he wants a challenge. He saves the $5 going that way also. I wish I had the directions and description handy. I am not sure I would ever go that way. I do plan on driving up the front of it when I make it out there.
mtngal- modular hardtop
I thought this top was suppose to be out in '07 when a lot of changes to the wrangler are happening for the latest saftey laws. They are suppose to no longer offer the softop also. That is what I heard last.
Lugnuts
I always recheck my lug nuts when I get back home or within a week from the tire shop to make sure I can get them off.
-twylie
Fifth gears, like all the gears, locate on their shafts with splines, not keyways. My guess would be that either a snap ring has come off and allowed a gear to move out of alignment and just 'float' on its shaft, or it's a problem with the fifth gear fork becoming loose on its rail. I think that the guy you bought it from was making an optimistic guess about something he had little knowledge of.
You'll find the information in the FSM to be very complete. While it's nice to have all the replacement parts sitting on the bench ready to go, you won't actually know what parts will be finally be required until you have it torn down. I'd study the manual, then strip the transmission slowly (keeping thing as clean as is possible), and photograph things as you go, if you can. Then decide what can stay and what has to go.
Bear in mind that this a mainly offroad vehicle. No point in replacing all the bearings if only one is bad, but you do want all the synchros working. Doesn't matter too much if some of the gears show a little wear are noisy, or if reverse has a few chips. This is not what I'd advise for a daily driver though, for obvious reasons.
-twylie
Jim did real well and tried some things he didn't want to try the first time he wheeled, which was last Saturday. Both Jim and that pretty red YJ did a fine job today.
You can see some pics at http://itsajeep.org in the photo gallery.
(Well, they ain't there yet... gonna do that right now, though).
Tom
Anyway, that basically stock YJ of mine really surprised me. It did a few things that I really didn't expect it to do so easily. I did get the wheels off the ground though. But, as usual, I left the nasty stuff to Tom. Barrett, age 3, did really well. In fact, he was enjoying the scenary so much that he pointed out a small box turtle that was scampering out of our way. But as 3 year olds tend to do, he wore out fairly early in the day and actually fell asleep bouncing down the side of a ridge.
Hey Trey, I hear you are going to join us.
That reminds me of the wreck two turtles had at a trail intersection. They were each telling the cop that it was the other one's fault. The cop saw a snail and asked him if he could say what actually happened. The snail said, "No sir, it all happened so fast."
You did great today, Jim!
Tom
Tom
You'll never guess what my wife said today. "If we can find someone to watch the boys Saturday, I'm going with you." Tom, she really liked the pictures you took. She may actually like it.
I would have had that back seat tonight, but my connection hiccupped and I didn't get my last bid in. Dagnabit! Oh well, there will be others.
Like you said, there will be others. Any news on the tranny yet? Did ya get a chance to check out that rebuilder you mentioned to me Saturday?
Get yer spare back yet?
That's super that Janna liked the pics and wants to go with ya!!!! I was hoping this would become a family thing for ya, and I mean THE WHOLE FAMILY. Jeepin' can be a great thing for the entire family. Ain't a whole lot of things in this world that are fun for the whole family... seems like each family member has his/her "own thing" any more, and the entire family does very few things together. When they do, at least one or two family members are just there cause they have to be, not because they want to be. Jeepin' can be something that each and every family member can really put his/her heart into.
Tom
However, this weekend might have changed my mind a bit. Here it is October, supposed to be off season, and we were up by Hetch Hetchy Reservoir (yes, that really is the name and it is a real spot on the map) in Yosemite National Park. While I wasn't expecting to be the only person there, I was surprised to see as many people as there were up there. While the area is lovely, it isn't exactly well known. So perhaps more people really are getting out and explore the great outdoors.
The long range weather forecast sounds good at this point, and the leaf color oughta be just about peak for the weekend.
Jim said he is gonna try to make it back to TB this Saturday too... might even have the Little Woman with him.
How bout the rest of ya? Any of you that live within a few hours of here, just BRING IT ON!
Tom
Tom - if only I lived closer to you, I'd be there in a heartbeat! It sounds like great fun, so I hope that the weather holds for you. I'm envious!
Could it be leaking from the valve cover and running down the back of the engine? That would be much better than a rear main leaking.
Mac?
Tom
If it was oil that was spraying out while the engine was running, then dripping down while it was off, it would still be dripping while the engine ran.
Easiest way to find a leak like that is to start with a clean engine.
I cleaned the engine with an engine cleaner and let it sit a day. Then I drove it. The leak appeared to be coming from the oil pan, but following it up, I found the leak in the back of the valve cover (some knothead hadn't even tightened the bolts). I resealed it and tightened to spec (55 in/lbs I think). No problems with an oil leak any more. And it did drip after not running. Oil had accumulated higher up on the engine somewhere and dripped later. So it is worth it to at least check it out and rule that out. It is a simple and easy fix, even if you have to take off a few things to get to the valve cover.
-Paul
This past weekend, we had a boy scout campout. We had a helo take us up to the top of a mountain for our open air camping. Coming down was a wicked trail that many jeeps have come up. There was a lot of BIG ruts, severe inclines, narrow passes, slick rock, etc on a 2 mile trail that climbs up over 2000 feet in that 2 mile distance. We hiked the 16 boys down that trail.
I would LOVE to take a Wrangler on that. Problem is, if you mess up on that trail, you could very easily careen into a DEEP valley. There was a rusted out old Willy's jeep that didn't make it in one of those ravines. You would definitely need all terrains on that trail with a lower tire pressure. I didn't feel comfortable taking my Grand Cherokee with street tires on that trail, though with its Quadra drive, I'm sure could make it with the right tires. Wish I had pics of some of the jeeps taking the trail... TJ's YJ's... *sigh*
This weekend though is my anniversary so my wife and I are going to Hawaii. I've rented a Wrangler.
-Paul
I'm really happy with my purchase, and the advice of this group proved invaluable.
If I can get my hands on a digital camera, I'll post some pics.
Thanks, Mike
I have a 97 TJ that is my daughter's daily car, but I'm seriously considering another wrangler as my 'beater' so I don't rack up the miles on my other two cars.
I have to admit, listening to Tom talk about the wheeling and seeing the trails I was hiking on this weekend, I think I'm getting the Jeep Fever.
Maybe my trip this weekend will cure that.
Probly not... guess that is why I rented one.
-Paul
Paul - You are just now figuring out that you have Wrangler fever? From the sounds of things you've had it for a while! Just think about how much fun you can have in the mountains. Sunday as we came back from the Sierras we stopped at Costco (Bakersfield) and picked up a book on SUV trails on the west side of the Sierras. There are such wonderful sounding trails - I can't wait to go back up that direction. Next time we go I'll insist on taking the Wranger, regardless of the cost of gas!
Just seeing those trails this weekend made me want to steal my friend's Sport and go at em.
The trails I'm talking about are just north of Mojave and the 'new' section of hiway 58 that just opened. If you look up that way, you can see a trail heading to the top. That is the one!
-Paul
Gary
-Paul
Not sure if you seen these or not Tom but I stumpled arcross it and thought i would pass it along.
http://www.muttslinger.com/whatis.html
http://www.ultimate4wheeldriveperformance.com/muttslinger.htm
Paul,
I having been wheeling with several quadra drive grands. I like seeing them tackling the same obstacles. I think they both run 4" lifts now. One of them sent me a picture last year pulling out a H2 when they were on a snow run.
I know that they closed part of that area and made it into a desert tortoise preserve, but that was a long time ago. Are you talking about that area or are you closer to Randsburg? I'm actually more familiar with the area further east - Barstow to 4 Corners. Always looking for a way around 4 Corners at the end of a 3 day weekend!
The first time I went off-roading in a vehicle not owned by the US Army was in an almost brand new Grand Cherokee. The guy who owned it got it stuck and my husband ended up getting it out. But somehow it isn't the same - the Wrangler is so much more fun somehow. Can't explain it, but it just is.
Guess old Ross Allen does fine just riding in the back. I make him get out and have someone babysit him when I go through anything that's risky for him.
Wish you could get into Gill's for some chatting! When ya gonna get set up for that?
Tom
As for wheeling the grand, as long as I get some decent all terrains I'll feel more comfortable doing it. I doubt she'll let me do a lift on it.
I agree, mtn, that a Wrangler has that more rugged feeling to it. It is more exhilarating because the grand is very cushy inside. Makes me feel like Thurston Howell on Gilligan's Island, but with a CD player.
That's why my Hawaii trip includes a Wrangler and not a Grand.
-Paul
black, 5spd, 37k miles
Steelhorse tubular bumpers front and rear
Canyon wheels
hard top only
hard top winch setup
bikini top
Yakima racks and hitch
14,500
The body looks in great shape and I'm looking into its maintenance history. Sound interesting?
-Paul
Tom
