Yes, you can currently order a new 2010 SRX. If you want me to locate a dealership in your area I will need your zip code. Thank you,
Mariah GM Customer Service
as to the spare yep in Canada that's what u get, mon ami!
To no avail. I am going through one of the largest dealers in Galveston Houston area.
Each time dealer sends order to GM Cadilliac the response is trailing option is not available yet. I want this factory installed when car is built.
Will this option be available soon or must wait till 2011 Model is produced.
If even then.
Why is it even listed as an option????
Does it have a transmission cooler and 3500lb capacity? What was the price including installation.
I live on west end of Galveston Island and need to evacuate at least once or twice a year pulling the boat
thanks deana
In June, I began having problems with the XM radio. With the screen up, the listing of songs playing near the channel I was listening to popped up and the check mark began jumping all around that screen. It appeared the radio was changing stations, but it remained on the station I was listening to. As songs ended and new ones began, this listing never updated, but the check mark continued jumping all around the screen. Seemed minor, but annoying. I could select "back" or press the radio button to get back to the main listening screen.
This problem increased in frequency while we were on a recent road trip. It became so annoying that I lowered the screen. That's when a whole new set of problems occurred. The channels actually changed stations--jumping all around--in the lower screen mode. Frustrating.
I called the dealer and they said it was my programming. I called XM radio and they said it was the manufacturer's problem. Then the reverse camera screen became distorted, but not all the time.
Car is now back at the dealer. They said they have to drive it around to duplicate the problem which irks me to know end. They said it may be a loose connection or may have to replace the radio. No estimated timeframe. Grrr.
I'm hoping this is not a bad sign about the overall reliability with the car. Yikes!
On a side note: Has anyone noticed that the XM navigation has the car's position off by about 1.5 miles? It's very frustrating when it says, "Turn left here." But really your turn is further down the road, or (worse!!), "You have arrived at your destination." And, you are in a busy area and have to continue driving around searching.
We still use our Garmin Nuvi and put the XM Navigation on silent mode now. Interesting the two different routes they sometimes suggest. Yes, I've experimented with the various route options, too. We've learned to trust the Nuvi over the XM Navigation in the SRX. The SRX doesn't recognize a road that leads to our house; thus, directs us the around another block or two. So, untrustworthy. It's sent us through 30MPH residential areas to connect to a major Interstate when if we'd turned the other direction the Interstate connection was RIGHT THERE.
Anyone else notice these things?
Thanks for the feedback, in advance.
I'd appreciate any feedback on your experiences with it.
I see they have dicontinued production on the 2.8 Turbo, I can only assume this is because of issues.
I DID NOT RECEIVE ANY NOTICE FOR THIS RECALL: POWERING STEERING HOSE/CLAMP, (PARTS HAVE BEEN REPLACED) HOWEVER; FOUND OUT AFTER BEING ASSERTIVE WITH THE SERVICE DEPT IN JAN 2011 REGARDING OTHER ISSUES WITH THE LEMON THAT I OWN. AND ALSO THE STRUT MOUNTS, WHICH I HAVE NOT FOUND A RECALL AS OF YET. PARTS ON BACK ORDER. SERVICE WRITER WOULD NOT PROVIDE ME THE PAPERWORK, BULLETIN OR RECALL REPORT. HOWEVER, I HAVE MANAGED TO FIND THEM ONLINE.
Have you taken it to the dealer to see if they could get it to work correctly?
Christina
GM Customer Service
Glad to hear this resolved your problems. If you have any other questions comments or concerns please feel free to email me directly.
Christina
GM Customer Service
If you are still under warranty the software updates should be free. Please consult with your dealership for any additional information about vehicle updates.
Amber N.
GM Customer Care
