How many miles do you have on your Lincoln LS?
brandonslsbrandonsls Member Posts: 1
edited October 2017 in Lincoln
Hey everyone. I was just curious how many miles people have on there Lincoln LS's. I am just about to hit 250K on mine and it feels like a milestone. Every place I take my car people say how beautiful it looks, and so many people ask me how long I have had it, assuming it's brand new. I bought it with a few thousand miles on it 3 years a 3 months ago. Anyhoo, just curious about peoples miles, thanks.
  • socalcarlsocalcarl Member Posts: 7
    2004 LS Ultimate 3.9 V8 :shades:
    Had it about a year, got it with 30K, now has 52K
  • toomanyfumestoomanyfumes Member Posts: 1,019
    Wait, you put almost 250k on it in just over 3 Years?
    Mine's an '05 with 54K. I only put about 6K a year on it 'cause I ride my motorcycle all summer.
    2012 Mustang Premium, 2013 Lincoln MKX Elite, 2007 Mitsubishi Outlander.
  • hambonhambon Member Posts: 1
    I have 165000 on a 02 lse i bought it when it had 11000
  • larryk0202larryk0202 Member Posts: 3
    I have a 2001 and just turned 83K on it. No major problems with the car yet, just regular scheduled maintanence.
  • cfrey81cfrey81 Member Posts: 2
    edited May 2010
    Bought '00 LS in '05 with 38K...as of today I am pushing 210k. Not many problems till now with misfiring crap. Love the car tho and I ALWAYS drive it like it should be...as if I were on the Autobahn :D
  • car1615car1615 Member Posts: 2
    I have a '01 LS with 116,000. bought it with 20k. It's been expensive to maintain.. but rides & looks great!
  • jokersmithjokersmith Member Posts: 12
    I have an '05 LSE that just turned 50K. She is a great car despite the numerous trips to the dealer for the failed COPS and the hesitation.
    59K on my '05. replaced the DCCV (dual climate control valve), and of course, three COPS.
  • gk_lsegk_lse Member Posts: 4
    I also have a 2002 LSE with 105K miles on it. Had no issues until it passed 100K and now it's been non-stop (COPS, fuel pump, radiator and now Advancetrac) since December.
  • loanguyloanguy Member Posts: 1
    Several months ago I purchased a 2001 LS V8 with only 16,400 miles on it. It now has 20,200 on it and ready for first oil change.
  • jpal2626jpal2626 Member Posts: 2
    I have an 02 lse pushing around 125k. This machine is a beast looks like i just drove it off the lot. The only problem i have had with it is the ignition coils. I found if you use the techtronic shitft it will burn them out 10X faster. other than that she drives like a dream.
  • antoniukantoniuk Member Posts: 8
    Bought an 06 last year with 28k it now has 40k. Good to know others have over 250k miles on the car. I love the car and plan on keeping it as long as possible
  • jroysterjroyster Member Posts: 2
    I bought a used '05 LS V6 back in '05 with about 22K miles. Now coming up on 215K. All the ignition coils have been changed. plugs changed at 129K.
    I have had some issues which I didn't have with my last two cars (both Nissan Altimas), The transmission doesn't shift to D5, so I get the infamous 'E' when I get up to 55-60mph, but the car still runs smoothly.
    Most of my driving is on the highway, so not a lot of starting/stopping. Probably the main reason it's lasted so long. I plan to drive it until it disintegrates...
  • heydudesheydudes Member Posts: 43
    Wow, that's a lotta miles! :)
    My 2001 manual transmission V6 has almost 135,000 miles and I am about to perform the first tuneup. Only item I've spent much money on (besides GAS) is tires. I'm on my 3rd set. Always Firestones.
  • jahsdadjahsdad Member Posts: 3
    I have a 2000 Lincoln Ls that has 125K. No major problem besides ignition coils, but now when I start the start i get a cloud of white smoke from the exhaust. Only when I start the car. Do anyone know what this could be?
  • akirbyakirby Member Posts: 8,062
    Is it smoke or steam? It might just be condensation in the exhaust - if so it would dissipate very quickly. If it sticks around then it sounds like coolant which would most likely mean a blown head gasket. Check the oil for milky fluid and/or check the coolant for oil. You can also get a compression test done.
  • jen0jen0 Member Posts: 10
    I have a 2002 LS (V8) that just hit 209,000 miles! runs great still - alot of electrical problems though.
  • totaljetttotaljett Member Posts: 26
    I'm at 175,000 miles at this point.
    I have a 2002 LS. I have had and am still having ignition coil problems. It actually sets the check engine light on - it's a "clyinder misfire" at least that's what it's called on my car. Yeah it's a V8 so there is 8 seperate coils! at $95.00 EACH. I have replaced 4 of the 8 with Ford parts. Now I have a cylinder #7 misfire. But my car has 209,000 miles almost 210. I have alot of issues.
  • kargkarg Member Posts: 20
    You can pick up a new coil pack from any advance auto/autozone type store for $53 or so. Don't overpay for the Ford part.
    Also - if you change them yourself - just make sure the plug well doesn't have any oil or moisture in it - that is what causes them to misfires.
  • cutman1cutman1 Member Posts: 1
    I have a 2001 Lincoln LS - V8. 210,000 miles! Regular maintenance - oil changes every 5-7 thousand miles. I changed plugs at 100 and 200K. Changed out the tranny fluid around 110k. I had to get a new clock spring for the steering wheel controls, and change a window regulator a few years ago. I discovered Wagner ceramic brake pads and good quality rotors go a long way for a smooth ride in this car. In the last 10k miles, i've had to change 2 coils, and am told they will all start going now. This really isn't a big deal....a bit over $100 per coil for a mechanic to do it. This is the best car I've ever owned! It's still a solid, smooth riding car, and all the gadgets still work! Too bad they stopped making them.
  • msgtusmcmsgtusmc Member Posts: 4
    2000 LS Base V6, 83,000
    I have 211,000 miles on my 02 LS V8
  • esalazaresalazar Member Posts: 21
    2004 lincoln has 73,000. I hope mine reaches them miles and more. I just replaced all 8 coils on it. Now it runs like a champ. I already replaced the water bottle. Upper radiator hose. Thermostat and the housing. Check engine light kept coming on. I think all these problems were caused by faulty ignition coil. Now it runs so good. Like I just pulled it out the lot. I hope it stays that way. I did all the work on it myself. So that there saved me lots of money. Oh I also added seafoam. Thats alot of miles on your car. What is your secret, to keep it running with that many miles? :)
  • jen64jen64 Member Posts: 3
    Yeah I have changed out like 5 of the 8 coils some twice and plugs a few times. I have heard alot of the LS's have coil problems. Yeah one year I had a hell of a time with them. Plus when you have a cylinder misfire it makes ur check engine light come on and u can't pass an inspection. It's ridiculos. The car now has 213,000 miles on it. I just do my oil changes regualrly and that's it. I find the less I mess with this car the better. I have dumped thousands into this car. I just had to dump $435.00 to getm y heat working again. Actually I'm $600 something into it because I took it to Midas to have them "diagnois" F**in morons charged me for two hours of labor @ $81.00/hr to mis-diagnois my car. They told me it was my heater control valve, well they are idoits cause it wasn't that. I then brought it to a "radiator specialist" and he told me it was an acuator - NOPE. to make a long story short I drove around with no heat for three months (and I live in NH) froze my [non-permissible content removed] off. I ended up having to bring my car over to VT to see my parents mechanic - 30 years experience with Fords, and works on hot rods, this guy is a genius. I am totally impressed. Plus he didnt charge me to find out why my heat wasn't working and then when he got up in there found there was another aux. motor that wasn't working. Instead of replacing at $130.00 he repaired it for $15.00. It was a B**ch of a job- what isn't with this car.
  • desertstraydesertstray Member Posts: 2
    I just acquired one with 310K
  • msbev9msbev9 Member Posts: 1
    @desertsray......How's it holding up and was it well maintained?  Contemplating buying a perfectly maintained 2000 with 289K for $1600.  Runs super smooth and very clean.
  • stundinastundina Member Posts: 5
    The coils are very important on this car,oil Leaks must be sealed,you can buy new coils at rockauto.com for 17$,not very hard for anyone to install,may as well do the plugs at the same time,blow out the spark plug holes with compressed air befor removing the plugs
    Mine has 210,000,needs clock spring for stearing wheel buttons,everything else is very good
  • zandorzandor Member Posts: 67
    I had a 1998 Lincoln Mark VIII with the same coil problem. Around 60k or so one of them failed. Then a few months later 2 more went bad. That was around 2005 or so. The second time I just changed all of them. No coil problems after that. By 2005 there was an updated part available. I wonder if that applies to the LS as well. Different car, different engine (Mark VIII had the 32V 4.6L mod motor), but it sounds like the same issue and I wouldn't be surprised if they all used the same coils.
  • sharyn43sharyn43 Member Posts: 10
    101,000 miles haven't had to change the coils
  • hotlinchotlinc Member Posts: 7
    There are fewer and fewer LS's on the road these days. My 2000 (original owner) V6 with Sport Package and all options has about 156,000 trouble-free miles. I have always kept it off the road in the winter to avoid the salty NW PA winter roads. Looks like a Florida car underneath (and all over.)
  • gking4001gking4001 Member Posts: 2
    Hi I have a 2001 Lincoln Ls. It has 264,000 miles on it and it runs perfect and is s daily driver and has been for 8 years. Just keep the oil changed and try and run the best of fluids. I only run fully synthetic motor in the engine and transmission. Trust me you will live the difference on the road and not beside it. I will check back in once i hit 200,000 miles wish me luck guys.
    Tip, get your coils from ebay. You can get a whole set for $30 to 40 bucks mostly. Thanks
  • kyfdxkyfdx Moderator Posts: 275,907
    V8 or V6?
