Visitor Agreement.
First tank of fuel with my Rubi yielded 18 mpg with 75% city driving. I am actually impressed since I drive 8 blocks to work and back. One other thing I am amazed at is how fast it warms up on a cold day. It reaches optimum temperature within 3 or 4 minutes of idling. Come to think of it, my wife's liberty warms up just as fast.
I have mopar steering box skid, teraflex gas skid, 2.5" rancho suspension, 1" MORE motor mount lift, 1.25" JKS body lift, rims, 32 BFG A/Ts, CB and spare tire mounted bike rack which I don't care for. I would rather have one mounted from the reciever. Don't use my carpet and I have huskey liners.
Soon I hope to regear, add ARBs front and rear, a belt driven on board air, flat skid and SYE.
I meant to say the engine skid, sorry. Nobody has installed the tummy tucker low profile skid plate eh?
This is the link that we need to use to tell Edmunds.com to put Jeep back on the town hall homepage. It's frustrating that Jeep gets more posts than most other makes but we have to click 5 times to get here. I have already filled out the form 11 times.
I don't have a problem with my 4cyc truck at all. My 4 cyc Jeep I couldn't stand though. The 6cyc Jeep is nice for me. I seem to average 15mpg. I drive a little fast on freeways and have a lift and 32s though. The poor aerodynamics starts to really show in gas mileage when you drive faster.
mac,
You are probably right then. I was just going by driving other autos and assumed the wrangler was similiar.
Here is another option for a flat tranny skid. I like how it is 2 pieces.
http://tinyurl.com/zo6k
The teraflex one does not seem to hold up very well.
When I get one, I am probably getting one from a local guy.
So far I have only heard good things about the tummy tucker but I have no first hand experience.
If you are only wanting to have less clicks, then bookmark this page.
http://tinyurl.com/zo81
One click to the wrangler discussion. Plus you see all the other wrangler discussions to check out.
rear part number is 5086623ab, dealer cost $577, retail is $862.
front part number is 5086618aa, dealer cost is $646, retail is $1080.
Functional off-road stuff:
- JKS disconnects
- 31x10.5 trXus MTs
- Kilby gas tank skid
- Skid Row engine skid
- Skid Row steering box skid
- ARB compressor
- Staun deflators
Things that make the Jeep better as a DD:
- heated front seats
- Painless Aux fuse panel for accesories
- speaker upgrades (Boston NX 5.25"F and 6.5"R) JLAudio 6w0 in factory console on a separate amp.
- IPF e-code lenses
- bikini, duster, and windjammer combo
- soft doors for summer
- Energy poly anti-sway bar bushings
Things to be installed (sitting in my basement or waiting to be picked up):
- Rubicon flares
- Rear swing out tire carrier/bumper
Things on the short list:
- OME lift
- SYE
- small body lift and belly up
- winch
Down the road:
- ARBs F/R and regear at the same time
Almost embarrased to admit it in public, but the Jeep has been sitting for the last three weeks due to work and the holidays. Need to pull it out this week and put a wreath on the grille to play Santa.
-twylie
- bad starter @ 8k miles. This was an intermittant problem, but once I was able to finally diagnose it (crawl under the jeep and tap it with a rubber mallet while my wife tried to start it), the servicing dealer replaced it the next week with no issues since.
- rear main seal leaking @ 13k miles. Not a leak such that I get oil in the garage, but more of a weeping down the back side of the engine. I am holding out until spring to get it replaced right before my warranty expires. My understanding is this is a common probelm with the 4.0, but not terribly difficult or expensive to remedy.
That's it for me. My TJ has less than 19k miles on it now, but it has been used enough to have proven itself as capable and fun in the 33 months we've had it. It continues to put a smile on my face when I drive it and is still much more competant off-road than its driver :-)
-twylie
2: Exhaust manifold cracked at around 30k and was replaced under warranty. Design was subsequently changed and current vehicles no longer have what was a fairly common problem.
3: Just before 36k a rear axle shaft seal started to leak. Replaced under warranty along with the wheel bearing.
4: Around 40k the steering pump bearing started to whine. Replaced it myself for $5.
5: About 45k I replaced a rear wheel cylinder which wasn't actually leaking but was damp under the boot. Didn't like the look of it, so I replaced it with one from AutoZone for $12.
Other than that I just do routine maintenance at the minimum recommended intervals (B schedule).
Then I traded it in this week for a new 04 Khaki Rubicon, pre-trail rated badge.
The driver's side dash, just above the steering column, makes loud cracking sounds now that it is cold out, so loud in fact that my fiancee asked "What the #$@! is that noise, is your jeep falling apart!"
As for problems, I dunno what happened before, but I've had to fix:
1. Exhaust Manifold - typical issue with 97's
2. Catalytic - died at 85,000
3. Valve Cover - loose cuz some idiot didn't tighten it properly
4. Pinion seal leaks from front diff
5. Radiator leak - replaced it with a real metal one, no plastic
It's been going well since my repairs. I dont' consider oil changes and other fluid changes repairs as they extend the life.
-Paul
The hard top paint blistered and peeled just above the windshield. DC paid the body shop of my choice to repaint the whole top. (The dealer where I bought her did not have their own body shop.)
I had a leak that the TJ's are famous for. The passenger side floor board would get a pool of water in it after a rain. Turned out to be the lack of a good seal around the heater box where it goes through the fire wall. Dealer fixed it in one visit. No problem since then with that.
Turn signals quit working, and the stalk had to be replaced. One trip to diagnose the problem, and one trip after the part came in.
All of those problems were within the first few months after I got Thelma Jane, and she has been trouble-free ever since.
I have received nothing but friendly, efficient service from the dealer where I bought her and the dealer where I had the turn signal stalk replaced (handier for me to go there, since it is in the same town where I work).
Tom
Have you hugged your Jeep today?
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
2" Procomp spring and shock lift
31 x 10.50 BFG Mud Terrain T/A KM tires
AR767 15" x 8" wheels with 4" Backspacing
Detroit Soft Locker in the rear
Warn 9.5 Ti winch
Kilby gas tank skid
Sun Performance rocker guards
Teraflex steering box skid
Hope to someday have ARB lockers front and back and bigger lift and tires.
Tom
As I've said before I've never owned a 5spd before but I must admit that I'm getting to love it. I still stall it once here and there, just need a little more time. The thing I'm learning to love is using the gears and engine to control the downhill speed. Where I live the back roads are all hills and it's so much nicer to just drop it into third and let it idle down the hill instead of having to worry about breaking and everything.
Well just had to get a post in today, so there it is.
Still working on those pictures, the weather was horrible here today. Had rain, sleet, and snow
Tony
- at the 3000 mile checkup - the dealership informed me that the rear main seal appeared to be beginning to leak. No oil on the garage floor that I noticed. Fixed under warranty a few weeks later (had to order a part).
- When I picked up the Jeep from the repair, noticed the clutch was clicking. Fixed under warranty - they replaced the clutch master and slave assembly and have had no further issues (had to order the parts).
- They also adjusted the linkage on the 4 wheel drive handle (I was having a very difficult time getting Tweety into 4 wheel drive - literally had to pull over to argue with the handle (I won). Works like a charm now (so far two snowstorms and no arguments).
- Also had to have the lock adjusted on the console between the seats as it wouldn't lock.
All of the repairs have been covered under warranty. The dealership I purchased Tweety from has been a pleasure to work with so far.
I have no complaints. There are always some hiccups with a new vehicle. Love my Jeep.
Only modification if you can call it that so far has been adding a hitch. New headlights are in my future however.
DO NOT USE THE CLUTCH TO HOLD YOUR JEEP ON A HILL!
When you have to stop at a light or for whatever reason, and the Jeep wants to roll backwards when the clutch is in, you are NOT supposed to try to hold the Jeep by letting the clutch partially out! That will wear out a clutch in no time.
Just thought it wouldn't hurt to point that out.
Tom
Walt
Speaking of tire diameter, it seems that my speedometer is actually closer to being correct with the bigger tires.
Tom
-A/C compressor went out and it was replaced under warranty.
-The rear passenger side axle seal leaked. Fixed under warranty with no problems. They said the axle shaft was warped.
-Rear main seal leak. Fixed under warranty.
-I had a popping noise from the rear. Dealer blamed the suspension lift. Had it checked and it was fine. I brought it back to the dealer and they still blamed the suspension lift and would not open the diff. I took it somewhere else and the spider gears were replaced.
I also have an issue with the front brakes/calipers on the GC. I hear there is a TSB for the brakes, which involves replacing the rotors and calipers (something about caliper retraction), so I may do that myself in the spring with aftermarket brakes.
But overall, I've loved our GC as much as our TJ. I just need some AT's on it, instead of the street tires. I've found the BFG AT KO's are fairly quiet on the road, probably quieter than the Dueler HT's on the GC.
-Paul
My '98 Sport is bone stock. When I bought it I had planned on a lift and lockers after the warranty wore off, but by then I realized that I didn't really need them for what I was doing (of course, I'd probably do more if I had them...). I get a pretty consistent 20 mpg with almost all freeway/high speed rural roads with large elevation gains (I live at about 6,000 feet and work at sea level), traveling under 70 mph in no wind. If it is windy or I go faster than 70, forget the gas mileage.
I had to replace my exhaust manifold (with the redesigned part!), the fuel filler tube, and had the dash gauge problem common with my model year (dash gauges would disappear and the air bag light would come on - intermittent problem. No parts needed to fix, did it myself with a friend's help). I have 2 unresolved issues - my AC needs servicing, and my back tailgate rattles - partly because the rubber has dried out and partly because three screws keep rattling loose.
When my Noble Black Steed was about 6 months old, we were involved in an accident on I405 (hit the wall and Toyota pickup that was crossing into my lane right in front of me). 2 new rims, 4 new tires, new running board, new front side panels, both sides, and both side mirrors, and a U joint. I'm glad it wasn't my insurance paying for all that!
It has over 114,000 miles on the odometer and is still going strong.
-twylie
-Paul
Mine are dark as night when driving and want to fix em. Can the controllers from later models (round dials) fit into a 97 TJ?
-Paul
Oh well still only been 2 days with her and adjusting. Don't worry Tom I don't use the clutch to hold her on hills
Does everyone here follow the idiot shift lights? I'm on so many back roads where 4th gear holds a stead 1500rpm and yet it's always telling me to shift to 5th. I did once and the next hill I came to she just didn't want to go up. So now I just leave her in 4th. Out on the flats I'll put her in 5th.
Thanks for the help.
Tony
Auto
Dan 35 axle (sorry Tom)
Bestop trail cover and full cover
black with tan top
upgraded factory stereo with sub
dual tops (hard top with a Safari top and hellas)
fog lamps
40,000 miles
VERY clean inside and out, no visible wear
engine bay very dusty, but only a slight oil mess around drain plug
2" lift
31" tires
Canyon wheels
Tow hitch to tow dirtbike only
All evaluations are mine and not from a pro mechanic, but tire wear looked normal/even. Tranny had no history or appearance of leaking. Original owner.
Wanting 16,900 for it. Sound interesting?
-Paul
I know what you mean about not being able to take advantage of all these incredible rebates etc. I can't dump the Taco yet either - still owe too much on it. I'm really frustrated over that! If there is any way you can make it work, go for it!
I ended up buying my Wrangler from the dealer in Ontario, but wasn't impressed. Don-A-Vee would have given me a better deal. I've heard good things about the dealer in Lancaster, if you want to drive that far. I don't think much of the dealers in either Bakersfield or Santa Clarita, but have never talked money to either one, so I could be wrong. It just seemed to me that the salespeople I've talked to there don't know much about their products.
Nope....... too little gas, or you're letting up on the clutch too quickly!
Skid Row LCA and engine skid plates
DC steering box skid plate
4XDoc rocker and rear end skid
Kilby gas tank skid
Seat covers and Husky floor mats
Have now removed the rear end and gas tank skid.
Problems have been:
Several check engine lights caused by me pinching the gas line coming out of the tank when I put on the Kilby, plus Kilby and rear skid rubbing each other.
Drive shaft, belt tensioner, pulley, belt, water pump have all been replaced under warranty.
The Sport has never stranded me over left me on the side of the road. All the problems have been identified when I took it to the shop.
I have no problem with buying another Jeep in the future and intend to get a diesel Liberty in a couple of years.
Still a happy camper.
here are my problems with tazz
paint chiping under passenger door
heater seal leak
windshield leak
engine light stays on
all fixed under warrenty
mods:
seat covers
polk front speakers
alpine rear speakers
kenwood amp
hood & winshield graphics
TJ emblem on side
windows tinted
30 payments $8500 left for payoff
Keep JEEPIN
Don't get me wrong - my Noble Black Steed has been worth every cent I paid for it so I'm not unhappy. It is just that I don't like playing all the games that many car dealers play, and Ontario plays them all. I got the impression that Don-A-Vee was less likely to play them. Of course, things could have changed in the almost 6 years since I bought my Wrangler.
oceantoad - So how are things in Central Texas? About the same? Since I can't do anything about the Taco until spring at the earliest, I'm thinking about that diesel Liberty too. I'll be interested in finding out if it will be worth waiting for.
bama - I didn't realize you put the TJ decals on. I've thought about doing that but just haven't done it - I sure like the looks of them.
I haven't told my wife about the Sahara yet. I think if she saw it, she'd love it, but would think the 16,900 for it would be too much (I will have to remind her that very little would need to be done to make it the way I want it).
I know Tom will tell me that I need the D44, but I seriously doubt I'll offroad to that extreme, and if I did, I would use an older one that didn't cost that much.
-Paul
Got the fender fixed for $250.00. Looks great
Got the A/C fixed (twice) for about $150.00. Works OK.
That's about it.
I think I got a steal.
One thing I noticed when looking for used Jeeps was that most of them smelled like a wet sock. They are often owned by people that don't take very good care of them, so when you find a good one, jump on it.
Tom: I just registered for Gill's so I can get some pics up of Amy that I just took. She's a bit dirty but hey that's what Jeeps are meant for
Tony
Also, as geepers already said, forget the stupid shift light. Just ignore it.
I'm pretty sure that what geepers said about it being a fuel economy thing is true. I believe I shift about the time the light comes on, but not BECAUSE the light comes on. It just seems to match my driving style, I guess.
Tom
Well I hope that it works this time
Mtngal: I know what you mean about 2nd gear. it's all slow and go around town now thanks to the season so I just get to second keep the engine going a little. It's nice to be able to crawl. Even in my old Corola(auto) I couldn't go that slow.
Tony
